Can't see all the JavaDoc text when hovering [message #163261] |
Wed, 02 August 2006 08:42 |
Originally posted by: asd.asd.com
When I hover over a method in the method list that appears after I type
"dot" I get some javadoc information in a box. But often I cannot see all
the text, only the first 7 linies or so. How do I scroll through the javadoc
info?
Johs
Re: Can't see all the JavaDoc text when hovering [message #163296 is a reply to message #163261] |
Wed, 02 August 2006 10:04 |
> info?
There is currently no official support for scrolling through the
additional info. On linux/gtk, however, you can scroll the info using
the mouse wheel.
-tom
Re: Can't see all the JavaDoc text when hovering [message #163509 is a reply to message #163261] |
Wed, 02 August 2006 15:15 |
> info?
> Johs
Hit F2 when the hover is visible. This will add scroll bars to the popup
window. Then you can scroll through the rest of the Java doc.
Re: Can't see all the JavaDoc text when hovering [message #163560 is a reply to message #163509] |
Wed, 02 August 2006 17:02 |
"Dave Wegener" <wegener@cboenospam.com> skrev i en meddelelse
news:18561b14a920368a0417d39929a5cdf9$1@www.eclipse.org...
>> javadoc info?
>> Johs
No that does not work in winXP.
Re: Can't see all the JavaDoc text when hovering [message #163573 is a reply to message #163560] |
Wed, 02 August 2006 19:04 |
>>> javadoc info?
>>> Johs
My mistake. The F2 doesn't work when using code assist. It only works
when hovering over a class/method with the mouse.
FUDForum. Page generated in 0.09322 seconds
