want to get started writing an editor [message #162970] |
Mon, 31 July 2006 22:42 |
Originally posted by: adamshaw.cs.uchicago.edu
Greetings --
I need to get off the ground with Eclipse. I am just beginning a project
to develop a front-end in Eclipse for the programming language ML. As a
first step, I would be happy to build an editor that colors keywords and
comments and maybe manages indentation in some sensible way.
The Eclipse API is large and I'm having a hard time getting a foothold
anywhere -- in other words, I'm not sure where to start hacking. Does
anyone have any words of wisdom as to how to get started? Is there an
especially good tutorial or sample project for getting up to speed?
Thanks in advance for any responses.
Adam Shaw
University of Chicago
Re: want to get started writing an editor [message #163027 is a reply to message #162970] |
Tue, 01 August 2006 12:34 |
Originally posted by: jefmyers.us.ibm.com
Adam,
Have you looked at the sample project templates provided by the New
Plug-in Project wizard? One of the samples is a basic xml editor with
syntax highlighting, etc. You can use that code as a starting point for
your editor.
Hope this helps,
- Jeff
FUDForum. Page generated in 0.08663 seconds
