Incorrect Tool Tip in Ant's build.xml [message #161431] |
Tue, 18 July 2006 14:41 |
Originally posted by: larry.stupidtuesday.com
I have a web app with an Ant build.xml script that works fine, so I know
everything is set up correctly. The problem I am having is with what
appears to be an out-of-synch tool tip.
I have this line in my build.xml file:
<property name="catalina.home"
value="c:\Program Files\Apache Software Foundation\Tomcat 5.5" />
Yet when I place the cursor over "catalin.home" the tool tip gives the
value as "c:\Program Files\eclipse\plugins\org.eclipse.tomcat_4.1.30.1/"
Can someone please explain what's gone wrong and how I can fix it? I
find tool tips displaying the values of properties to be a useful
feature, however, it's not much good if the displayed value is incorrect.
Larry
Re: Incorrect Tool Tip in Ant's build.xml [message #161472 is a reply to message #161456] |
Tue, 18 July 2006 19:29 |
Thanks, Darin.
-- Larry
Darin Swanson wrote:
> The property is defined by a plugin (likely the eclipse.tomcat plugin) and
> that value is showing up in the editor.
> See Windows>Preferences>Ant>Runtime>Global Properties
> There should be a catalina.home with an Eclipse icon in the name column.
> This indicates that the property is applied for builds in the same JRE as
> Eclipse.
> I agree this is less than optimal in the hover but I have not allocated the
> time to look at the problem mostly because no one has asked.
> HTH
> Darins
> "Larry Hannay" <larry@stupidtuesday.com> wrote in message
> news:e9irvh$e4t$1@utils.eclipse.org...
>> Thanks,
>> Larry
FUDForum. Page generated in 0.08729 seconds
