CDT: Problem in Debugging C Program [message #161184] |
Mon, 17 July 2006 08:12 |
Originally posted by: aaremnair.gmail.com
I am running
Eclipse SDK
Version: 3.2.0
Build id: M20060629-1905
on Windows 2000 ver 5.00.2195 SP4
The program runs OK.
However, if it is executed in debug I get the message: "source not found".
The stack is as below:
TailRecursion.exe [C/C++ Local Application]
gdb Debugger (7/17/06 12:29 PM) (Suspended)
Thread [1] (Suspended)
1 main() at
\cygdrive\d\EclipseWorkspace\TailRecursion\TailRecursion.c:4 1
0x0040117e
Thread [2] (Suspended)
gdb (7/17/06 12:29 PM)
D:\EclipseWorkspace\TailRecursion\Debug\TailRecursion.exe (7/17/06 12:29
PM)
The source file is present in the directory:
I suspect there is some problem with setting \cygdrive\d.
How do I set the gdb to ignore this and go to the latter part of the path?
FUDForum. Page generated in 0.08924 seconds
