unable to install eclipse [message #154701] |
Wed, 31 May 2006 23:19 |
Originally posted by: itpurt.gmail.com
i am unable to install eclipse. i have downloaded the files. when i
attempt to run the .exe file, i get a error, unable to access jarfile
startup.jar. why is this happening. what have i done wrong. please help
thank you in advance
Re: unable to install eclipse [message #154837 is a reply to message #154701] |
Thu, 01 June 2006 14:09 |
Originally posted by: jefmyers.us.ibm.com
This usually means that your unzip client was not configured to maintain
directory structure when expanding the zip archive. Look for an option
to do this in your unzip client.
- Jeff
Re: unable to install eclipse [message #155142 is a reply to message #154701] |
Fri, 02 June 2006 17:23 |
Originally posted by: fabian.juarez.gmail.com
I have the same problem but into a Solaris box.
If I attempt to access to eclipse (binary) but the program don't run...
If I attempt to run startup.jar... the response is the same.
What I need to do if I wish launch the IDE.
My Eclipse downloaded file was: eclipse-SDK-3.1.2-solaris-motif.zip and
I had unzipped it via CLI...
Thanks in advance!
Fabián Alejandro Juárez Martínez
Intel Pentium 4 a 3.06 GHz
PCChips M925G
512 MB DDR
DD 40 GB
DVD+RW 4X
Sun Solaris 10 1/05 x86
SunOS helios 5.10 Generic_Patch_118844-30 i86pc i386 i86pc
¡Usando Evolution 1.4.6.330!
FUDForum. Page generated in 0.08421 seconds
