Error when opening a type(CTRL, Shift, T) [message #152872] |
Wed, 17 May 2006 07:05 |
Originally posted by: rmeder.gmail.com
Hi when I try to open a type by pressing CTRL, Shift, T. I find the type I
would like to open to begin working on but eclipse gives me the following
error in a popup box:
"Could not uniquley map the type name to a type". Path is
/workpool4.jar|com.workpool.directory/act/AttributeAction.ja va "
If anybody knows the reson for this error could you please help.
Ryan
Re: Error when opening a type(CTRL, Shift, T) [message #153256 is a reply to message #153123] |
Thu, 18 May 2006 18:22 |
Originally posted by: wharley.bea.com
"Ryan Meder" <rmeder@gmail.com> wrote in message
news:f47f66510061f76e7188d968fc7f09a1$1@www.eclipse.org...
> sorry the link you gave me is a 404 and didnt quite understand what you
> ment by 3.2 rc
> thanks for the help
What Dani means by "RC4" is Eclipse version 3.2, release candidate 4. You
can download this from the Eclipse.org downloads page. Eclipse 3.2 is very
close to being released, and RC4 is definitely a solid and usable version.
The link was a link to bug 139662, in the Eclipse Bugzilla database. (The
link does work for me, by the way.) That bug looks similar to what you hit,
and appears to have existed for several months in the Eclipse 3.2 codebase.
If you take a look at the bug, you may be able to figure out whether it
applies to you. If not.
It would be helpful if you could give more details about exactly what
version of Eclipse you are using, and under what circumstances the bug is
reproducible (e.g., is it only one particular type that you can't get to, or
is it all types; if just one, what is special about that type).
Re: Error when opening a type(CTRL, Shift, T) [message #153648 is a reply to message #153256] |
Mon, 22 May 2006 07:25 |
The bug only appears when i try to open types from the "jar" the project
within eclispe. All other projects seems to work with no problems. I used
to be on version 3.0 and never had the problem but since i upgraded to the
latest version on the download page to Version: 3.1.2 i started
experencing this problem.
Is it advisable to go to the latest version 3.2RC5? Will this solve my
problems, I cannot afford for this version to be buggy and this must still
intergrate with the latest version of my eclispe.
I also found the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=139662
i am under the impressiojn that a patch would be required to be installed
is this true and how would one go about this?
Sorry if my questions are very simple but i am still new to eclipse as an
environment.
Kind Regards,
Ryan
FUDForum. Page generated in 0.08511 seconds
