Editor source hover does not work [message #150609] |
Tue, 02 May 2006 13:01 |
Originally posted by: donaldaik.gmail.com
After i downloaded wrong version of Jadclipse (eclipse plugin), i had
errors under eclipse, but then i got correct version and errors
disappeared. Now with this version i have problems with source hover not
working in Editor although it is turned on in preferences. I removed the
jadclipse plugin but still no change, source hover does not work anymore.
Errors i found in error log were:
!ENTRY org.eclipse.ui.workbench 4 2 2006-05-02 09:09:45.691
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jdt.internal.core.SourceMapper.mapSource(Lorg/ec lipse/jdt/core/IType;[C)V
jadclipse.JadclipseSourceMapper.mapSource(JadclipseSourceMap per.java:206)
jadclipse.JadclipseClassFileEditor.doOpenBuffer(JadclipseCla ssFileEditor.java:121)
jadclipse.JadclipseClassFileEditor.init(JadclipseClassFileEd itor.java:56)
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:839)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1420)
at org.eclipse.ui.internal.EditorManager$5.run(EditorManager.ja va:1005)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:816)
org.eclipse.ui.internal.EditorManager.restoreState(EditorMan ager.java:1000)
org.eclipse.ui.internal.WorkbenchPage.restoreState(Workbench Page.java:2751)
org.eclipse.ui.internal.WorkbenchWindow.restoreState(Workben chWindow.java:1932)
at org.eclipse.ui.internal.Workbench.doRestoreState(Workbench.j ava:2857)
at org.eclipse.ui.internal.Workbench.access$14(Workbench.java:2 805)
at org.eclipse.ui.internal.Workbench$19.run(Workbench.java:1681 )
org.eclipse.ui.internal.Workbench.runStartupWithProgress(Wor kbench.java:1421)
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1679)
at org.eclipse.ui.internal.Workbench.access$12(Workbench.java:1 650)
at org.eclipse.ui.internal.Workbench$17.run(Workbench.java:1529 )
at org.eclipse.ui.internal.Workbench.restoreState(Workbench.jav a:1473)
org.eclipse.ui.internal.WorkbenchConfigurer.restoreState(Wor kbenchConfigurer.java:183)
org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:702)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1085)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1847)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.jface 4 2 2006-05-02 09:18:50.759
"org.eclipse.jface".
!STACK 0
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2503)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2436)
org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2428)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2413)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2408)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2393)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:287)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:164)
org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(Open ActionUtil.java:49)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:18 1)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:16 5)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:267)
org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:243)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:296)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 4.open(PackageExplorerPart.java:648)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:810)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:808)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1040)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1139)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:243)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:283)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3346)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2966)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
Strange problem.
FUDForum. Page generated in 0.48669 seconds
