Re: java editor source no longer builds [message #150557 is a reply to message #150393] |
Tue, 02 May 2006 10:17 |
Originally posted by: daniel.megert.eclipse.org
bhomass wrote:
>I set up a project to go over source code in the java editor plugin example.
>The plugin itself does run, but apparently its source suffers from eclipse
>3.1 upgrade. After making some adjustment for org.eclipse.jface.text, I
>still end with one error in JavaEditor.java file.
Make sure you use the sample code from 3.1 and import the 3.1 plug-ins.
Dani
>The type org.eclipse.ui.texteditor.StatusTextEditor cannot be resolved. It
>is indirectly referenced from required .class files
>Has anyone found a solution to this?
FUDForum. Page generated in 0.05075 seconds
