Re: Business Theme to new RAP Project [message #141196 is a reply to message #141163] |
Wed, 22 July 2009 14:29 |
Benjamin Muskalla Messages: 338 Registered: July 2009 |
Hi Aleksandar,
you don't need to care about the .launch file itself. See
http://help.eclipse.org/galileo/topic/org.eclipse.rap.help/h elp/html/getting-started/launcher.html#rap
regarding the RAP Launcher.
Just open the "Bundles" tab in your launch configuration you're using to
start your RAP application and check the
"org.eclipse.rap.example.design" project there. This plugin includes the
"business" servlet along with the example implementation of the
interaction design API.
Greets
Ben
Aleksandar Pavlov wrote:
> Hi Ben,
> Thanks for the quick reply.
> I too new to RAP: do you mean the *.launch file? If so, what am I
> suppose to write there.
> Besides the direct answer, would you point me to some documentation
> where this is described (in order to spare your time answering similar
> simple questions).
> Aleks
> P.S.
> Do you mean 'org.eclipse.rap.design.example' project that comes along
> with the last RAP demo?
> Benjamin Muskalla wrote:
>> Hi Aleksandar,
>> you need to add the "org.eclipse.rap.example.design" bundle to your
>> launch config.
>> Greets
>> Ben
>>> Hi friends,
>>> If I understood correctly, one could use the new "Business" look and
>>> feel just by substituting the servlet name for 'business', e.g.
>>> http://localhost:port/business?startup=view.
>>> I tried that for existing project and it worked.
>>> Then I created my own RAP project and this trick is not working. What
>>> am I missing. I also added the themes and branding extension points,
>>> but in vain.
>>> Thank you in advance
>>> Aleks
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: Business Theme to new RAP Project [message #141306 is a reply to message #141296] |
Thu, 23 July 2009 07:19 |
Holger Staudacher Messages: 166 Registered: July 2009 |
Hi Aleksandar,
nice to here that it works. For changing components at the new design
you should get more familiar with the Layout/LayoutSet concept, please
take a look at [1]. We also provide a bundle which change allready the
logo of the new design. Therefore you need to checkout
org.eclipse.rap.examples from CVS Head and take a look at the
plugin.xml. On this we override a LayoutSet for the logo. You can use
this as a template for your own bundle.
To deploy the business design you should simple add this bundle to you
war file. I have never done this before, maybe someone knows it better
Regards Holger
[1]
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/look-and-feel.html
On
2009-07-23 09:07:19 +0200, Aleksandar Pavlov <a.pavlov@bers-soft.com> said:
> Great, that worked,
> May I ask two further questions.
> Is there a document explaining how to customize that look and feel. For
> example I dont need the perspectives navigation, I would like to change
> the 'Example' logo (actually remove all the topmost section). And there
> is a coolbar with a button that is not visible when I switch to the
> 'business' view.
> The second questions is: what should I setup in order to obtain business
> look and feel when I deploy the app as .war file in web container, not
> started from eclipse?
> Thank you for your time and help
> Aleksandar
>> Hi Aleksandar,
regarding
>> the RAP Launcher.
>> Greets
>> Ben
http://eclipsesource.com
Re: Business Theme to new RAP Project [message #141316 is a reply to message #141306] |
Thu, 23 July 2009 07:44 |
Is it possible to customize the layout at perspective level using this
interaction design API ?
For example we want our login perspective to cover the whole screen.
After successfull login, user will directed to business perspective with
normal layout. Currently we use TrimLayout to achieve this, but we're
not too comfortable about it since it's internal API.
Setya
FUDForum. Page generated in 0.03355 seconds
