Home » Modeling » GMF (Graphical Modeling Framework) » Really strange bug with label
Really strange bug with label [message #121728] Wed, 25 April 2007 08:45 Go to next message
I've got a node with two containers. Each container contains labels,
that we can add with a button. While my second container works perfectly
well (and was done sometimes ago), the first one doesn't display the
label, but instead the default text, or nothing if there is none. Even
if the user enter text when adding it or with the 'properties' view it
doesn't work.
I deleted generated files, regenerated .gmfgen and regenerated Java
files but the problem persists.
Any ideas ? I'm really stuck.
Generated code for label part is here : http://rafb.net/p/uohiCp46.html
Youmm.
Re: Really strange bug with label [message #121768 is a reply to message #121728] Wed, 25 April 2007 09:17 Go to previous messageGo to next message
Even more strange : when I triple(?!) click the label I can edit it and
then the text is correctly refreshed and displayed.
Re: Really strange bug with label [message #121793 is a reply to message #121768] Wed, 25 April 2007 10:47 Go to previous messageGo to next message
Ok I found the bug. It's was hard but I did it ;)
I defined my own version of equals and hashCode in AttributeImpl.java,
the class which contains the text of the label.
Why is there such a problem ? Can't I define my own equals method in the
class of the model ?
Youmm
Re: Really strange bug with label [message #121831 is a reply to message #121793] Wed, 25 April 2007 12:55 Go to previous messageGo to next message
Youmm,
I've had the same problem once and it really was hard to find it! My conclusion
is that it generally makes little sense to override the equals and hashcode
methods, since when considering the eContainer property of an EObject, no
EObjects that are not == are equal (only when they are not part of a resource).
In any case, it confuses GEF/GMFs checks for changes that are needed for
efficiently updating the EditPart and Figure hierarchies.
Hallvard
Youmm P. wrote:
>> and then the text is correctly refreshed and displayed.
> Youmm
Re: Really strange bug with label [message #121844 is a reply to message #121831] Wed, 25 April 2007 13:25 Go to previous messageGo to next message
--------------080603020701010109010703
Hallvard,
It's been suggested I make equals and hashCode final in
BasicEObjectImpl, which is a good idea, but I can't risk breaking
existing clients who are doing bad things but might be getting away with
it in their limited use cases. The EObject API now includes this
statement in the Javadoc:
The framework also assumes that implementations will not specialize
|equals(Object)| (nor |hashCode()|) so that "|==|" can be always
used for equality testing; |EcoreUtil.equals| should be used for
doing structural equality testing.
Hallvard Tr
Re: Really strange bug with label [message #121944 is a reply to message #121844] Thu, 26 April 2007 04:32 Go to previous messageGo to next message
Hum. OK thanks, EcoreUtil.equals is what I need.
In my own opinion, == should be used for references testing, and equals
method for structural testing. Just like a Java API should be.
Re: Really strange bug with label [message #121983 is a reply to message #121944] Thu, 26 April 2007 07:06 Go to previous messageGo to next message
Youmm,
You should think about the implications of that statement though. For
something to be structurally one could even argue that the container
should be taken into account and even if it's not, any kind of equality
test would involve visiting an arbitrarily big subtree. This would make
hashCode so expensive you'd likely need to cache the value. Then you'd
get into the issue that any change to anything in the entire structure
will change equality, or even if your hashCode only looked at local
fields, any change in value would change the hashCode so that, in either
case, any map (other than an IdentifyHashMap) holding the value has a
key would be corrupted. This is likely why DOM supports isEqualNode but
doesn't make equals itself be based on structural equality, and yet DOM
is still a Java API.
> equals method for structural testing. Just like a Java API should be.
Re: Really strange bug with label [message #122010 is a reply to message #121983] Thu, 26 April 2007 09:00 Go to previous messageGo to next message
That's a good point. In this case equals should not be used at all. So
if there is this kind of refresh bugs I suppose, upper in the hierarchy,
equals is called on an EObject and inheritance plays its role and call
my equals.
Why is equals called instead of '==' ? Or perhaps there is a useful
definition of Equals in EObject (or in its parents) that is used
internally. In this case they should used their own equals method (like
emfEquals) to avoid client classes to reimplement equals, no ?
Re: Really strange bug with label [message #122023 is a reply to message #122010] Thu, 26 April 2007 09:52 Go to previous message
--------------080705070607080903070202
Youmm,
Often equals is called indirectly. For example, if you add the object to
a HashSet or as the key of a HashMap, then equals will end up being
called. And when two lists containing EObjects are tested for equality,
equals is used to compare them (although EMF's extended list
implementation will use == for EObject containing list and will hence be
*far *more efficient, but will appear to misbehave if .equals is
overridden in the derived EObjectImpl).
>> equality test would involve visiting an arbitrarily big subtree. This
>> would make
> hierarchy, equals is called on an EObject and inheritance plays its
> role and call my equals.
> (like emfEquals) to avoid client classes to reimplement equals, no ?
<html>
<head>
</head>
Youmm,<br>
<br>
to a HashSet or as the key of a HashMap, then equals will end up being
called.&nbsp; And when two lists containing EObjects are tested for
equality, equals is used to compare them (although EMF's extended list
be <b>far </b>more efficient, but will appear to misbehave if .equals
is overridden in the derived EObjectImpl).<br>
<br>
<br>
Youmm P. wrote:
<blockquote cite="midf0q83a$33g$1@build.eclipse.org" type="cite"><br>
<blockquote type="cite">something to be structurally one could even
argue that the container should be taken into account and even if it's
not, any kind of equality test would involve visiting an arbitrarily
big subtree. This would make </blockquote>
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080705070607080903070202--
Previous Topic:how to show the dependencies of several ecore-models in a single ecore_diagram?
Next Topic:Can I modify GMF's Print Dialog ?
Current Time: Tue Jul 22 15:14:00 EDT 2025
Powered by FUDForum. Page generated in 0.17658 seconds
