Home » Language IDEs » C / C++ IDE (CDT) » Setting dynamically build environment
Setting dynamically build environment [message #901730] Tue, 14 August 2012 07:39 Go to next message
Hi all,
My makefile needs some environment variables which are defined by bash script:
. set_variables.sh  //script setting variables
make //makefile using variables setting above
I try to reproduce this process on Eclipse CDT using external tools to execute "set_variables.sh" before build in project build properties. But each time, i lose variables setting in script when make is carried out. I know we can set build environment variable statically but i can't use it.
So, is there a way to set dynamically build environment?
Re: Setting dynamically build environment [message #901928 is a reply to message #901730] Wed, 15 August 2012 02:45 Go to previous messageGo to next message
External tools have their own "universe" of environment variables and do not share it with the build command. You can change your build command to
. set_variables.sh && make
Re: Setting dynamically build environment [message #903911 is a reply to message #901928] Mon, 27 August 2012 04:56 Go to previous message
Unfortunately, nothing occurs. The set_variable.sh is not executed.
Previous Topic:Selecting the application to run according to the current active build configuration
Next Topic:Can't start Indigo
Current Time: Mon Jun 16 09:02:44 EDT 2025
Powered by FUDForum. Page generated in 0.04060 seconds
