Breakpoints Not Being Set [message #895622] |
Fri, 13 July 2012 20:25 |
wd40bomber7 P Messages: 3 Registered: July 2012 |
Junior Member |
Ok I have eclipse Juno Release, build id 20120614-1722
And my gdb version is 7.4-2012.04 and is running on Ubuntu
Whenever I set breakpoints I get a whole bunch of errors that look like this:
Error in re-setting breakpoint 1: Function "/home/acct/Documents/eclipse/Project Name/Src Files/Settings.cpp:112" not defined.
Error in re-setting breakpoint 2: Function "/home/acct/Documents/eclipse/Project Name/Src Files/Utilities.cpp:20" not defined.
I changed a few details of the path for privacy's sake.
Anyways, I can't seem to find this exact error anywhere else but doing things manually with gdb by itself works. When I use GDB by itself I use source files in another directory actually, could this be caused just because there are spaces in the path? That would be stupid right?
Edit: Confirmed! The glitch appears to be in gdb itself. (I tried to insert the link but it wont let me) Though unlike that link states, it seems to fail on files with spaces in the directory names as well as the file names. That's absolutely ridiculous. Oh well, does anyone know how I can go about downgrading or upgrading GDB to a version that works?
[Updated on: Fri, 13 July 2012 20:39] Report message to a moderator
FUDForum. Page generated in 1.02196 seconds
