Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] org.eclipse.emf.teneo.libraries and commons-logging
Re: [Teneo] org.eclipse.emf.teneo.libraries and commons-logging [message #117866 is a reply to message #117816] |
Fri, 11 April 2008 23:37 |
Martin Taal Messages: 5468 Registered: July 2009 |
Adding import-package to the libraries bundle did not seem to work (got build issues). Instead I
changed the dependencies of the other plugins to import-package (instead of the dependency on the
libraries plugin). This worked and all the testcases pass. This approach will also work for you I guess?
This will then be in the next build of Teneo (this weekend).
gr. Martin
Paul Gardiner wrote:
> I am having issues because org.eclipse.emf.teneo requires the
> org.eclipse.emf.teneo.libraries bundle, which exports commons-logging. The
> problem comes up when other bundles are also using commons-logging, and
> interact with bundles using teneo.
> Ideally, it would be nice if the libraries bundle just went away, and you
> put an Import-Package for the commons-logging api's in
> org.eclipse.emf.teneo, but a simple workaround is to put an Import-Package
> in the libraries bundle, so that the internal jar file is only used if
> commons-logging is not present. All that is needed is:
> Import-Package: org.apache.commons.logging
> in org.eclipse.emf.teneo.libraries' manifest file. I am doing that right
> now as a workaround, but would like somethig more permanent.
> Paul
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.eclipse.emf.teneo.libraries and commons-logging [message #117890 is a reply to message #117866] |
Sat, 12 April 2008 00:19 |
Paul Gardiner Messages: 94 Registered: July 2009 |
Member |
Martin,
Thanks a lot. Yes, that sounds great. I'll try it out Monday morning.
Paul
"Martin Taal" <mtaal@elver.org> wrote in message
news:ftosne$5i5$1@build.eclipse.org...
> build issues). Instead I changed the dependencies of the other plugins to
> import-package (instead of the dependency on the libraries plugin). This
> guess?
> gr. Martin
>> The problem comes up when other bundles are also using commons-logging,
>> and interact with bundles using teneo.
>> Import-Package in the libraries bundle, so that the internal jar file is
>> only used if commons-logging is not present. All that is needed is:
>> Thanks,
>> Paul
> The Netherlands
Re: [Teneo] org.eclipse.emf.teneo.libraries and commons-logging [message #616215 is a reply to message #117816] |
gr. Martin
> Paul
The Netherlands
Re: [Teneo] org.eclipse.emf.teneo.libraries and commons-logging [message #616219 is a reply to message #117866] |
Member |
Martin,
Paul
> guess?
> gr. Martin
>> Thanks,
>> Paul
> The Netherlands
Current Time: Fri Apr 19 05:14:53 GMT 2024
Powered by FUDForum. Page generated in 0.03517 seconds
