Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Hibernate map does not have the required flag set
Hibernate map does not have the required flag set [message #117564] Wed, 09 April 2008 23:13 Go to next message
Yigal Spinner is currently offline Yigal SpinnerFriend
In my eCore file I have attributes that are set to required.
In the TENEO release: v200709051239, the mapping file will create the
attribute "not-null=true".
In the TENEO release: v200804071116, the mapping file has the attribute
"not-null=false".
What changed and how can I fix it?
Yigal.
Re: Hibernate map does not have the required flag set [message #117597 is a reply to message #117564] Thu, 10 April 2008 06:36 Go to previous messageGo to next message
Martin Taal is currently offline Martin TaalFriend
Hi Yigal,
The logic for determining nullability of columns/properties has changed in the latest build. One
reason is this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=225717
A reason why even required properties get a nullable column is: in case of single-table inheritance
mapping all properties will get a not-null=false because different objects (with different sets of
properties) are stored in one table, so in case of single_table even mandatory properties will have
columns will allow null-values.
However, this part of the logic should not have changed from the build of september to now.
Can you post (a part of) the ecore and the resulting mapping for that part?
gr. Martin
> "not-null=false".
> Yigal.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Hibernate map does not have the required flag set [message #117829 is a reply to message #117597] Fri, 11 April 2008 21:15 Go to previous messageGo to next message
--------------070507040902090001020300
Martin
I'm attaching a partial of my eCore. The Part is based on "EntityItem".
Based on previous release of EMF 2.3.1, setting the lower bound to 1 and
upper bound to one indicates that the attribute is required.
In this class the attributes "EntityName" and "name" are set that way.
In the previous release of TENEO I would get a required field. However
now I get no required.
Yigal
Martin Taal wrote:
> Hi Yigal,
> in the latest build. One reason is this bugzilla:
> of single-table inheritance mapping all properties will get a
> mandatory properties will have columns will allow null-values.
> gr. Martin
>> attribute "not-null=false".
>> Yigal.
name="PartialEcore.txt"
Content-Disposition: inline;
filename="PartialEcore.txt"
<eClassifiers xsi:type="ecore:EClass" name="EntityItem" abstract="true">
<eAnnotations source="http://www.eclipse.org/emf/2002/GenModel">
<details key="documentation" value="An Entity Item defines the base entity for the repository. An entity is something in the modeled universe and it typically identified by a surrogate key."/>
</eAnnotations>
<eAnnotations source="http://www.eclipse.org/emf/2002/Ecore">
<details key="constraints" value="data"/>
</eAnnotations>
<eOperations name="sort" ordered="false" lowerBound="1"/>
<eOperations name="setDefault" ordered="false" lowerBound="1">
<eParameters name="entityName" ordered="false" lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eOperations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="id" ordered="false" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt" iD="true">
<details key="documentation" value="&lt;p>The internal ID of the entity. This ID is a unique ID generated when the entity is inserted into the repository"/>
</eAnnotations>
</eStructuralFeatures>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="entityName" ordered="false"
lowerBound="1" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString">
<details key="documentation" value="&lt;p> The external ID of the repository object by which the user will refer to the entity. Also called visible ID."/>
</eAnnotations>
<eAnnotations source="teneo.jpa">
<details key="appinfo" value="@Column(length=&quot;64&quot; )"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lockType" ordered="false"
lowerBound="1" eType="#//LockEType" defaultValueLiteral="Available">
<details key="documentation" value="&lt;p>The type of lock applied to a relationship"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="defined" ordered="false"
lowerBound="1" eType="#//entityValidEType" defaultValueLiteral="valid">
<details key="documentation" value="&lt;p>Identifies whether objects are default objects or have been defined before."/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="shortDescription" ordered="false"
<details key="documentation" value="&lt;p>Short description of an object"/>
</eAnnotations>
<details key="appinfo" value="@Column(length=&quot;128&quot; )"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="longDescription" ordered="false"
eType="#//EntityDescription" containment="true"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" ordered="false" lowerBound="1"
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EReference" name="entitytype" ordered="false"
lowerBound="1" eType="#//ToolResourceRegistry"/>
</eClassifiers>
--------------070507040902090001020300--
Re: Hibernate map does not have the required flag set [message #117841 is a reply to message #117829] Fri, 11 April 2008 22:35 Go to previous messageGo to next message
Hi Yigal,
The EntityName attribute has a column annotation which does not set the nullable property (of the
Column annotation). The main change since september is that if there is a column annotation then the
nullability of the column annotation determines the nullability of the column tag in the hibernate
mapping.
The default value of nullable in ColumnImpl is true, so if nullable is not set in the column
annotation then the resulting column will be nullable.
This could be improved so that the system checks if nullable is set in the column annotation and if
not, use the isrequired from the eattribute.
I will change this in the coming days.
gr. Martin
Yigal wrote:
> Martin
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> changed in the latest build. One reason is this bugzilla:
>> case of single-table inheritance mapping all properties will get a
>> part?
>> gr. Martin
>>> Yigal.
The Netherlands
Re: Hibernate map does not have the required flag set [message #117941 is a reply to message #117841] Sat, 12 April 2008 13:26 Go to previous messageGo to next message
Martin,
I agree with your final note that the system needs to be more flexible.
I do not think we need to have double data files.
Today, I have two files, one is the eCore file and another file is a
smart utility I wrote that modifies the eCore file and adds the JPA
annotations for length and validation.
I'm using the IBM product RSA to design my application and it has
limitation on setting the eCore. Each time we change the the design, we
need to regenerate the eCore and lose all annotation (except documents).
The RSA uses the internal eCore values of lower bound = 1 for required.
I can had into my tool to had the nullability smart, but I would prefer
it too be part of the eCore.
thanks
Yigal
Martin Taal wrote:
> Hi Yigal,
> nullable property (of the Column annotation). The main change since
> september is that if there is a column annotation then the nullability
> the hibernate mapping.
> not set in the column annotation then the resulting column will be
> nullable.
> the column annotation and if not, use the isrequired from the eattribute.
> gr. Martin
> Yigal wrote:
>> Martin
>> and upper bound to one indicates that the attribute is required.
>> However now I get no required.
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> part?
>>> gr. Martin
>>>> the attribute "not-null=true".
>>>> Yigal.
Re: Hibernate map does not have the required flag set [message #117954 is a reply to message #117941] Sat, 12 April 2008 13:58 Go to previous messageGo to next message
I'm adding the UML2 newsgroup to the "to" list of the reply to ask if
it's true that UML's Ecore stereotype support doesn't support specifying
Ecore EAnnotations? I did notice that exporting an Ecore model
containing extended metadata annotations doesn't seem to preserve them,
even when I choose to "Process" the annotations. Lack of support for
EAnnotations seems very unfortunate. Ecore -> XSD -> Ecore preserves
annotations so it would be awfully nice if Ecore -> UML2 -> Ecore were
capable of that as well. Given that UML extends EModelElement I can
imagine it should be possible...
Yigal wrote:
> Martin,
> we need to regenerate the eCore and lose all annotation (except
> documents).
> prefer it too be part of the eCore.
> thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> the nullable property (of the Column annotation). The main change
>> the column tag in the hibernate mapping.
>> is not set in the column annotation then the resulting column will be
>> nullable.
>> in the column annotation and if not, use the isrequired from the
>> eattribute.
>> gr. Martin
>> Yigal wrote:
>>> Martin
>>> "EntityItem".
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> even mandatory properties will have columns will allow null-values.
>>>> that part?
>>>> gr. Martin
>>>>> Yigal.
Re: Hibernate map does not have the required flag set [message #117981 is a reply to message #117941] Sat, 12 April 2008 19:37 Go to previous messageGo to next message
Hi Yigal,
I am not sure that your last post is so much of a Teneo topic, Ed already answered on this one. One
question though, why don't you use a separate xml file for the annotations:
http://www.elver.org/hibernate/ejb3_format.html#xml
then your utility can generate the xml once and Teneo can use the xml.
I will change Teneo so that when nullability is not set explicitly in the column annotation then
required (lowerbound) is used. So for this you don't need to change your code.
gr. Martin
Yigal wrote:
> Martin,
> thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> nullable.
>> gr. Martin
>> Yigal wrote:
>>> Martin
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> that part?
>>>> gr. Martin
>>>>> Yigal.
The Netherlands
Re: Hibernate map does not have the required flag set [message #118306 is a reply to message #117954] Mon, 14 April 2008 13:54 Go to previous message
Originally posted by: Kenn.Hussey.embarcadero.com
Ed,
Support for extended metadata has been provided by UML2 for some time, via
the Ecore profile; note that you need to enable the 'Ecore Tagged Values'
option. Support for generic Ecore annotations was added during the current
development cycle via the 'Annotation Details' option - see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=184249.
Kenn
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:ftqf6s$bsf$1@build.eclipse.org...
> I'm adding the UML2 newsgroup to the "to" list of the reply to ask if it's
> true that UML's Ecore stereotype support doesn't support specifying Ecore
> EAnnotations? I did notice that exporting an Ecore model containing
> extended metadata annotations doesn't seem to preserve them, even when I
> choose to "Process" the annotations. Lack of support for EAnnotations
> seems very unfortunate. Ecore -> XSD -> Ecore preserves annotations so it
> would be awfully nice if Ecore -> UML2 -> Ecore were capable of that as
> well. Given that UML extends EModelElement I can imagine it should be
> possible...
> Yigal wrote:
>> Martin,
>> thanks
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> nullable.
>>> eattribute.
>>> gr. Martin
>>> Yigal wrote:
>>>> Martin
>>>> "EntityItem".
>>>> Yigal
>>>> Martin Taal wrote:
>>>>> Hi Yigal,
>>>>> part?
>>>>> gr. Martin
>>>>>> Yigal.
Re: Hibernate map does not have the required flag set [message #616172 is a reply to message #117564] Thu, 10 April 2008 06:36 Go to previous message
Hi Yigal,
gr. Martin
> "not-null=false".
> Yigal.
The Netherlands
Re: Hibernate map does not have the required flag set [message #616210 is a reply to message #117597] Fri, 11 April 2008 21:15 Go to previous message
Martin
Yigal
Martin Taal wrote:
> Hi Yigal,
> gr. Martin
>> Yigal.
</eAnnotations>
</eAnnotations>
</eOperations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eAnnotations>
</eClassifiers>
Re: Hibernate map does not have the required flag set [message #616212 is a reply to message #117829] Fri, 11 April 2008 22:35 Go to previous message
Hi Yigal,
mapping.
gr. Martin
Yigal wrote:
> Martin
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> part?
>> gr. Martin
>>> Yigal.
The Netherlands
Re: Hibernate map does not have the required flag set [message #616227 is a reply to message #117841] Sat, 12 April 2008 13:26 Go to previous message
Martin,
thanks
Yigal
Martin Taal wrote:
> Hi Yigal,
> nullable.
> gr. Martin
> Yigal wrote:
>> Martin
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> part?
>>> gr. Martin
>>>> Yigal.
Re: Hibernate map does not have the required flag set [message #616229 is a reply to message #117941] Sat, 12 April 2008 13:58 Go to previous message
Yigal wrote:
> Martin,
> documents).
> thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> nullable.
>> eattribute.
>> gr. Martin
>> Yigal wrote:
>>> Martin
>>> "EntityItem".
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> that part?
>>>> gr. Martin
>>>>> Yigal.
Ed Merks
Re: Hibernate map does not have the required flag set [message #616232 is a reply to message #117941] Sat, 12 April 2008 19:37 Go to previous message
Hi Yigal,
gr. Martin
Yigal wrote:
> Martin,
> thanks
> Yigal
> Martin Taal wrote:
>> Hi Yigal,
>> nullable.
>> gr. Martin
>> Yigal wrote:
>>> Martin
>>> Yigal
>>> Martin Taal wrote:
>>>> Hi Yigal,
>>>> that part?
>>>> gr. Martin
>>>>> Yigal.
The Netherlands
Re: Hibernate map does not have the required flag set [message #616290 is a reply to message #117954] Mon, 14 April 2008 13:54 Go to previous message
Kenn Hussey is currently offline Kenn HusseyFriend
Ed,
Kenn
> possible...
> Yigal wrote:
>> Martin,
>> thanks
>> Yigal
>> Martin Taal wrote:
>>> Hi Yigal,
>>> nullable.
>>> eattribute.
>>> gr. Martin
>>> Yigal wrote:
>>>> Martin
>>>> "EntityItem".
>>>> Yigal
>>>> Martin Taal wrote:
>>>>> Hi Yigal,
>>>>> part?
>>>>> gr. Martin
>>>>>> Yigal.
Previous Topic:Re: Eclipse 3.4/emf 2.4
Next Topic:The Hibernate resource query does not work in the latest TENEO build
Current Time: Sun Sep 24 20:19:22 GMT 2023
Powered by FUDForum. Page generated in 0.02872 seconds
