[Teneo] org.jpox.sco.exceptions.NullsNotAllowedException on resource.save() [message #117510] |
Wed, 09 April 2008 17:31  |
Originally posted by: vnikolov.us.ibm.com
Hello Martin,
I've experienced a problem when trying to save a detached resource. Here
is the stack trace:
Exception in thread "main"
org.jpox.sco.exceptions.NullsNotAllowedException: Nulls are not allowed
for field writers: class = org.eclipse.example.library.impl.LibraryImpl,
field = writers
at org.jpox.sco.ArrayList.add(ArrayList.java:768)
org.eclipse.emf.teneo.jpox.JpoxUtil.updateListWithListElemen ts(JpoxUtil.java:155)
org.eclipse.emf.teneo.jpox.elist.EListWrapper.attachCopy(ELi stWrapper.java:494)
org.jpox.state.AttachFieldManager.storeObjectField(AttachFie ldManager.java:157)
org.jpox.state.StateManagerImpl.providedObjectField(StateMan agerImpl.java:2771)
org.eclipse.example.library.impl.LibraryImpl.jdoProvideField (LibraryImpl.java)
org.eclipse.example.library.impl.LibraryImpl.jdoProvideField s(LibraryImpl.java)
org.jpox.state.StateManagerImpl.provideFields(StateManagerIm pl.java:3115)
org.jpox.state.StateManagerImpl.internalAttachCopy(StateMana gerImpl.java:4389)
at org.jpox.state.StateManagerImpl.attachCopy(StateManagerImpl. java:4331)
org.jpox.AbstractPersistenceManager.attachCopy(AbstractPersi stenceManager.java:1431)
org.jpox.AbstractPersistenceManager.internalMakePersistent(A bstractPersistenceManager.java:1161)
org.jpox.AbstractPersistenceManager.makePersistent(AbstractP ersistenceManager.java:1277)
org.eclipse.emf.teneo.jpox.resource.JPOXResource.saveResourc e(JPOXResource.java:381)
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:348)
at package1.MainClass.main(MainClass.java:111)
While detached - when I add an element to the end of an EList and then
call resource.save() - it works fine. If I try to add an element in the
middle of an EList and call resource.save() - the exception above is
thrown. What I have observed is when attachedList.add(newpos, obj) fails
the INDEX column in the respective table in the DB gets inconsistent.
Do you have any ideas? Is there something I'm missing?
I have prepared a small testcase which I'm going to send it to you via mail.
I'm using Teneo v0.8.0.
Thank you,
Vladimir
Re: [Teneo] org.jpox.sco.exceptions.NullsNotAllowedException on resource.save() [message #117635 is a reply to message #117510] |
Thu, 10 April 2008 08:22  |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Vladimir,
Thanks for the testcase it helped to find the bug. I solved the bug and will commit it to cvs shortly.
FYI the following occured:
The new object was added to the list at a specific position, at resource.save the detached list is
matched with the current list in the db and the list in the db is updated. The update action first
adds the new writer to the list (at the end) and then moves it to the correct location. The move
operation first did a remove and then an add (with index). This remove resulted in a remove of the
writer of the db, eventhough it was present in the list in another location.
This resulted in the new writer not being persisted (or actually it was persisted but removed
immediately), no exception was thrown so the old writer was moved to index 1. When reading the list
in the next run this resulted in a null entry in the list at position 0.
I changed the update logic to not do remove.
Note the above situation probably only occurs in case of detached objects.
gr. Martin
Vladimir Nikolov wrote:
> Hello Martin,
> is the stack trace:
> field = writers
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> mail.
> Thank you,
> Vladimir
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.jpox.sco.exceptions.NullsNotAllowedException on resource.save() [message #616179 is a reply to message #117510] |
Hi Vladimir,
gr. Martin
> Hello Martin,
> is the stack trace:
> field = writers
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> mail.
> Thank you,
> Vladimir
The Netherlands
FUDForum. Page generated in 0.02365 seconds
