No such item "J2EE Web Module" [message #116889] |
Wed, 06 July 2005 14:14  |
I'm trying to follow the help instructions that came with eclipse about
how to build a web service. It says to select a J2EE Web Module like this:
Create a Web project
1. Open File -> New -> Other... -> Web -> J2EE Web Module to create a new
flexible project and Web module .
Well, there is no such entry. The only ones I see are these:
CSS
Dynamic Web Project
HTML
JavaScript
JSP
Servlet
Static Web Project
Note that there is a J2EE option at the same lever as Web, but it contains
only these options:
Applicaiton Client Project
Connector Project
J2EE Enterprise Application Project
So, is the help file wrong (and if so, what SHOULD be selected) or is the
wizard broken?
Thanks!
Re: No such item "J2EE Web Module" [message #118899 is a reply to message #116889] |
Sat, 09 July 2005 20:19  |
I have the same here, I am using WTP 1.0M5, so I am guessing something has
changed between M4 and M5.
But mine could be different, I am using EJB projects (used to WSAD) and the
tutorial says EJB Module, but mine has EJB Project.
Could be a naming thing.
"Darrin" <darrin_p_s@att.net> wrote in message
news:4a73c2beef8054ec6d4a32504291e5ae$1@www.eclipse.org...
> this:
> Create a Web project 1. Open File -> New -> Other... -> Web -> J2EE Web
> Module to create a new flexible project and Web module .
> CSS
> Dynamic Web Project
> HTML
> JavaScript
> JSP
> Servlet
> Static Web Project
> only these options:
> Connector Project
> wizard broken?
> Thanks!
FUDForum. Page generated in 0.03184 seconds
