Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Column name for attribute override
Column name for attribute override [message #116797] |
Fri, 04 April 2008 00:50  |
Originally posted by: pavata.vsp.com
This is regarding the column name restriction on inherited field from a
superclass. We have a parent class and subclass hierarchy as Email.xsd and
MyEmail.xsd respectively. A field name emailaddress is inherited from Email
class to MyEmail class and the attribute override column name is
EMAIL_ADDRESS. But teneo overrides the column name as MYEMAIL_ADDRES once it
identifies specified column name starts with parent class name. We don't
understand the need to override the column name when it counters this
situation. The specific class that is performing this is
ClassicMappingContext.class
Can you throw some light on this funtionality? It is forcing us to rename
our class names to some other names which we really don't want to.
- Pavan
Re: Column name for attribute override [message #116882 is a reply to message #116820] |
Fri, 04 April 2008 16:11   |
Hi Martin,
I wanted to confirm with you before I have my own implementation of
mappingcontext. Here is what I am doing.
The superclass annotation is
<xsd:complexType name="Email">
<xsd:annotation><xsd:appinfo source="teneo.jpa">@MappedSuperclass
@Embeddable</xsd:appinfo></xsd:annotation>
<xsd:sequence>
<xsd:element default="" nillable="true" name="emailAddress"
type="xsd:string">
<xsd:annotation>
@Column(name=XXX,nullable="false")
</xsd:appinfo>
<xsd:documentation>
Type of e-mail address [we need codes here]
</xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
and subclass annotation is
<xsd:complexType name="MyEMail">
<xsd:annotation>
@AttributeOverrides({
@AttributeOverride(name="emailAddress", @Transient
column=@Column(name="EMAIL_ADDR", length="50")),
@Table(
name="CMR3607T"
uniqueConstraints = { @UniqueConstraint(columnNames={"EMAIL_SK"})
</xsd:appinfo>
And the column name in the hibernate mapping finally turns out to be
MYEMAIL_ADDR. Can you tell me why it is modifying the name?
- Pavan
"Martin Taal" <mtaal@elver.org> wrote in message
news:ft4h7q$taa$1@build.eclipse.org...
> Hi Pavan,
> Can you post a small xsd sample so I can better understand what you try to
> do?
> btw, you can always replace the mapping context class with your own
> implementation which does what
> you want. See the extensions mechanism of Teneo.
> gr. Martin
> Pavan Tata wrote:
>> and MyEmail.xsd respectively. A field name emailaddress is inherited from
>> Email class to MyEmail class and the attribute override column name is
>> it identifies specified column name starts with parent class name. We
>> don't understand the need to override the column name when it counters
>> this situation. The specific class that is performing this is
>> rename our class names to some other names which we really don't want to.
>> - Pavan
> With Regards, Martin Taal
> Springsite/Elver.org
> Office: Hardwareweg 4, 3821 BV Amersfoort
> Postal: Nassaulaan 7, 3941 EC Doorn
> The Netherlands
> Tel: +31 (0)84 420 2397
> Fax: +31 (0)84 225 9307
> Mail: mtaal@springsite.com - mtaal@elver.org
> Web: www.springsite.com - www.elver.org
Re: Column name for attribute override [message #116895 is a reply to message #116882] |
Fri, 04 April 2008 17:20   |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Pavan,
This renaming is required for the case that an ereference is inherited from a mapped superclass, in
this case the join-column of the e-reference will be placed in another table. If one ereference is
inherited by multiple subtypes then this goes wrong because they then all share the same join column
with foreign keys relating it to different tables, and multiple foreign keys on one column can not
point to different directions.
Currently there are two things which are wrong with this behavior:
- the renaming is not required for eattributes (afaics)
- it ignores the attributeoverrides annotation
I will repair this for the next build (within a few days or earlier).
In the meantime to work around this you can create your own MappingContext.
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #117046 is a reply to message #116882] |
Sun, 06 April 2008 21:01   |
Hi Pavan,
The latest I-build (of today) should solve this issue. Can you check?
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #117141 is a reply to message #117046] |
Mon, 07 April 2008 18:52  |
Martin,
Yep, that fixed it. I really appreciate the fact that you are so quick in
applying these solutions....such a pleasure working you.
- Pavan
news:ftbdo2$ne1$1@build.eclipse.org...
> Hi Pavan,
> gr. Martin
> Pavan Tata wrote:
>> Hi Martin,
>> <xsd:sequence>
>> type="xsd:string">
>> <xsd:annotation>
>> </xsd:appinfo>
>> <xsd:documentation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> <xsd:annotation>
>> @Table(
>> name="CMR3607T"
>> </xsd:appinfo>
>> - Pavan
>>> Hi Pavan,
>>> to do?
>>> gr. Martin
>>> Pavan Tata wrote:
>>>> Hi,
>>>> a superclass. We have a parent class and subclass hierarchy as
>>>> Email.xsd and MyEmail.xsd respectively. A field name emailaddress is
>>>> inherited from Email class to MyEmail class and the attribute override
>>>> column name is EMAIL_ADDRESS. But teneo overrides the column name as
>>>> MYEMAIL_ADDRES once it identifies specified column name starts with
>>>> parent class name. We don't understand the need to override the column
>>>> name when it counters this situation. The specific class that is
>>>> performing this is ClassicMappingContext.class
>>>> to.
>>>> - Pavan
>>> The Netherlands
> The Netherlands
Re: Column name for attribute override [message #616076 is a reply to message #116820] |
Hi Martin,
<xsd:sequence>
type="xsd:string">
<xsd:annotation>
</xsd:appinfo>
<xsd:documentation>
</xsd:annotation>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:schema>
<xsd:annotation>
@Table(
name="CMR3607T"
</xsd:appinfo>
- Pavan
> Hi Pavan,
> do?
> gr. Martin
> Pavan Tata wrote:
>> - Pavan
> The Netherlands
Re: Column name for attribute override [message #616077 is a reply to message #116882] |
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #616089 is a reply to message #116882] |
Hi Pavan,
gr. Martin
Pavan Tata wrote:
> Hi Martin,
> <xsd:sequence>
> type="xsd:string">
> <xsd:annotation>
> </xsd:appinfo>
> <xsd:documentation>
> </xsd:annotation>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:schema>
> <xsd:annotation>
> @Table(
> name="CMR3607T"
> </xsd:appinfo>
> - Pavan
>> Hi Pavan,
>> do?
>> gr. Martin
>> Pavan Tata wrote:
>>> Hi,
>>> - Pavan
>> The Netherlands
The Netherlands
Re: Column name for attribute override [message #616096 is a reply to message #117046] |
Martin,
- Pavan
> Hi Pavan,
> gr. Martin
> Pavan Tata wrote:
>> Hi Martin,
>> <xsd:sequence>
>> type="xsd:string">
>> <xsd:annotation>
>> </xsd:appinfo>
>> <xsd:documentation>
>> </xsd:annotation>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:schema>
>> <xsd:annotation>
>> @Table(
>> name="CMR3607T"
>> </xsd:appinfo>
>> - Pavan
>>> Hi Pavan,
>>> to do?
>>> gr. Martin
>>> Pavan Tata wrote:
>>>> Hi,
>>>> to.
>>>> - Pavan
>>> The Netherlands
> The Netherlands
Current Time: Tue Jun 28 13:37:04 GMT 2022
Powered by FUDForum. Page generated in 0.04270 seconds
