Home » Modeling » TMF (Xtext) » resource descriptions in unit tests
resource descriptions in unit tests [message #879607] Thu, 31 May 2012 14:04 Go to next message
Vlad Dumitrescu is currently offline Vlad DumitrescuFriend
Hi!
I tried to write unit tests to check the descriptions for the resources, but I can't make it work with models created from strings.
val module = parser.parse('''
     code here
val res = module.eResource
val descriptionIndex = indexProvider.getResourceDescriptions(res)
The descriptionIndex is always empty. I suppose this information is created by the builder and I have to call it first, but how do I do that? Or maybe I am doing it all wrong?
best regards,
Vlad
Re: resource descriptions in unit tests [message #879614 is a reply to message #879607] Thu, 31 May 2012 14:15 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
i cannot reproduce this.
can you share a complete runnable example. and make sure you imported the correct ResourceDescriptionsProvider
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: resource descriptions in unit tests [message #880006 is a reply to message #879614] Fri, 01 June 2012 09:15 Go to previous messageGo to next message
I found the problem: I am declaring several file extensions for the language files and the ParserHelper uses their concatenation when creating a synthetic name for a resource.
	@Inject
	@Named(Constants.FILE_EXTENSIONS)
	public String fileExtension;
I suppose that parsing the value and taking the first extension will fix this. Something like
	protected URI computeUnusedUri(ResourceSet resourceSet) {
		String name = "__synthetic";
                String ext = firstItem(fileExtension)
		for (int i = 0; i < Integer.MAX_VALUE; i++) {
			URI syntheticUri = URI.createURI(name + i + "." + ext);
			if (resourceSet.getResource(syntheticUri, false) == null)
				return syntheticUri;
		throw new IllegalStateException();
	private String firstItem(String list) {
	    list = list.trim();
	    int ix = list.indexOf(',');
            if(ix<0)
                return list;
	    return list.substring(0, ix);
best regards,
Vlad
[Updated on: Fri, 01 June 2012 09:15]
Report message to a moderator
Re: resource descriptions in unit tests [message #880009 is a reply to message #880006] Fri, 01 June 2012 09:21 Go to previous messageGo to next message
Please file a bugzilla
Re: resource descriptions in unit tests [message #880021 is a reply to message #880009] Fri, 01 June 2012 09:36 Go to previous message
Done! https://bugs.eclipse.org/bugs/show_bug.cgi?id=381335
/Vlad
Previous Topic:How do I create a FOR loop that runs once?
Next Topic:Xtext hangs
Current Time: Thu Dec 03 08:47:44 GMT 2020
Powered by FUDForum. Page generated in 0.01447 seconds
