Home » Language IDEs » ServerTools (WTP) » Tomcat 5.0 on Gentoo with WTP
Tomcat 5.0 on Gentoo with WTP [message #115611] Sun, 03 July 2005 12:18 Go to next message
how can i configure Eclipse Web Tools for Tomcat server on Gentoo ? Tomcat 5 on
Gentoo is installed in following way :
/usr/share/tomcat-5/bin
/usr/share/tomcat-5/common/endorsed
/usr/share/tomcat-5/common/lib
/usr/share/tomcat-5/lib
/usr/share/tomcat-5/server/lib
/usr/share/tomcat-5/server/webapps (standard webapps - admin, manager)
/var/lib/tomcat-5/default/conf
/var/lib/tomcat-5/default/logs
/var/lib/tomcat-5/default/temp
/var/lib/tomcat-5/default/webapps (other webapps)
/var/lib/tomcat-5/default/work
So, Tomcat 5 is divided into 2 parts and due this Eclipse says that any of two directories
(/usr/share/tomcat-5 or /var/lib/tomcat-5) is not valid Tomcat 5 installation directory.
It's somehow possible to make it work with WTP ? Or should i create special tomcat-5
installation just for development ?
Frantisek Augusztin
Re: Tomcat 5.0 on Gentoo with WTP [message #115910 is a reply to message #115611] Mon, 04 July 2005 14:16 Go to previous messageGo to next message
Originally posted by: jarek.holgersson.tele2.se
Frantisek Augusztin wrote:
> Hello,
> Thanks
> Frantisek Augusztin
Hi Frantisek,
Did you try with tomcat-plugin? http://www.sysdeo.com/eclipse/tomcatplugin
It would fix probs with appdeployment under your tomcat.
Jarek
Re: Tomcat 5.0 on Gentoo with WTP [message #115921 is a reply to message #115910] Mon, 04 July 2005 16:23 Go to previous messageGo to next message
Thanks, but i wanted to use WTP. I resolved the problem with special instance
of Tomcat just for WTP. It's not the best solution, but it works.
Frantisek Augusztin
Re: Tomcat 5.0 on Gentoo with WTP [message #116279 is a reply to message #115611] Tue, 05 July 2005 09:26 Go to previous message
Hi Frantisek,
You are welcome to an enhancement request in Bug database to see if you
can have your use case covered. Tomcat runtimes and servers don't
currently support separately specified catalina_home and catalina_base.
However, the default Tomcat server does run in this fashion, but
doesn't allow you to specify the catalina_base. It will appear under a
directory like ".metadata\.plugins\org.eclipse.wst.server.core\tmp?".
If you create multiple servers from the same runtime, you will get
multiple "tmp?" directories, if that is in any way useful.
Larry
> Hello,
> Thanks
> Frantisek Augusztin
Previous Topic:Deploymentdescriptor works only with JBoss4.0
Next Topic:What happened to java flexible projects
Current Time: Thu Apr 17 12:14:41 EDT 2025
Powered by FUDForum. Page generated in 0.03611 seconds
