Home » Modeling » TMF (Xtext) » Confused about the map function(Replacing Xtend collect in Xtend2)
Confused about the map function [message #868547] Wed, 02 May 2012 07:45 Go to next message
Axel Guckelsberger is currently offline Axel GuckelsbergerFriend
Hi all,
during migration from Xtend/Xpand to Xtend2 I have the following problem with the new collect syntax.
Let's say we have a World which contains multiple Country elements. Every country contains multiple Company elements.
If I do
    def getSortedCompanies(World it) {
    	getAllCompanies.sortBy(e|e.sortOrder)
    def getAllCompanies(World it) {
        countries.map(e|e.companies)
the field sortOrder is not visible in the first rule.
If I do
        countries.map(e|e.companies) as Iterable<Company>
I get an error message in the generated Java file as conversion from List<EList<Company>> to Iterable<Company> is not possible.
This is why I did
        countries.map(e|e.companies) as List<Company>
But when trying to run the Xtend generator it crashes with:
Caused by: java.lang.ClassCastException: org.eclipse.emf.ecore.util.EObjectContainmentWithInverseEList cannot be cast to ....Company
I think the problem is that I have a List of EList elements while I should have only a List.
What am I overlooking?
TIA
Axel
[Updated on: Wed, 02 May 2012 07:46]
Report message to a moderator
Re: Confused about the map function [message #868556 is a reply to message #868547] Wed, 02 May 2012 08:06 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
Hi you have to explicitly call flatten for iterables of iterable
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Confused about the map function [message #868562 is a reply to message #868556] Wed, 02 May 2012 08:22 Go to previous message
Thanks Christian.
This version works:
        countries.map(e|e.companies).flatten.toList as List<Country>
Previous Topic:EOF not matching RULE_EOL
Next Topic:How accessing file complete location ?
Current Time: Sat Dec 05 00:36:28 GMT 2020
Powered by FUDForum. Page generated in 0.01972 seconds
