Error creating "New Dynamic Web Project" [message #113660] |
Fri, 24 June 2005 11:37 |
Originally posted by: rdh23.cornell.edu
Fresh install of:
Eclipse 3.1 RC3
WTP Integration Build I20050623 (and required plugins)
Tomcat 5.5.9 (new install)
Have configured the Tomcat Server in Eclipse "Servers" View
Can publish, start, and stop
Trying to create a new J2EE Web Project:
Context = Test
Target Server = Apache Tomcat 5.5
Module Version = 2.4
Context Root = Test
No support for annotated Java Classes
Click Finish
A new project is created under "Other Projects" with the name Test with:
JRE System Library
Tomcat 5.5 Runtime
and then an error dialog is presented with a stack trace ... the key
piece of info appears to be:
"Cannot find the declaration of element 'project-modules'."
STACK TRACE:
java.lang.reflect.InvocationTargetException
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:357)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:245)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:844)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3070)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2703)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.eclipse.emf.common.util.WrappedException: cvc-elt.1:
org.eclipse.wst.common.internal.emf.resource.EMF2DOMRenderer .loadDocument(EMF2DOMRenderer.java:79)
org.eclipse.wst.common.internal.emf.resource.EMF2DOMRenderer .doLoad(EMF2DOMRenderer.java:60)
org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.basicDoLoad(TranslatorResourceImpl.java:141)
org.eclipse.wst.common.internal.emf.resource.CompatibilityXM IResourceImpl.doLoad(CompatibilityXMIResourceImpl.java:173)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
org.eclipse.wst.common.internal.emf.resource.TranslatorResou rceImpl.load(TranslatorResourceImpl.java:382)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getAndLoadLocalResource(EditModel.java:733)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getResource(EditModel.java:664)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getPrimaryResource(EditModel.java:1492)
org.eclipse.wst.common.internal.emfworkbench.integration.Edi tModel.getPrimaryRootObject(EditModel.java:1473)
org.eclipse.wst.common.componentcore.internal.ModuleStructur alModel.getPrimaryRootObject(ModuleStructuralModel.java:64)
org.eclipse.wst.common.componentcore.internal.StructureEdit. getComponentModelRoot(StructureEdit.java:455)
org.eclipse.wst.common.componentcore.internal.StructureEdit. findComponentByName(StructureEdit.java:714)
org.eclipse.wst.common.componentcore.internal.resources.Virt ualComponent.create(VirtualComponent.java:168)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationOperation.createWebStructure(WebComponentCreati onOperation.java:59)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationOperation.createAndLinkJ2EEComponentsForSingleC omponent(WebComponentCreationOperation.java:54)
org.eclipse.wst.common.componentcore.internal.operation.Comp onentCreationOperation.execute(ComponentCreationOperation.ja va:51)
org.eclipse.jst.j2ee.application.internal.operations.J2EECom ponentCreationOperation.execute(J2EEComponentCreationOperati on.java:68)
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentCreationOperation.execute(WebComponentCreationOperation .java:119)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.doExecute(ExtendableOperationImpl.java:129)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl$1.run(ExtendableOperationImpl.java:109)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1739)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.execute(ExtendableOperationImpl.java:115)
org.eclipse.wst.common.frameworks.internal.ui.RunnableOperat ionWrapper.run(RunnableOperationWrapper.java:32)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
... 38 more
FUDForum. Page generated in 0.02075 seconds
