Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Possible JpoxHelper bug; Custom PMFCreator not honoured
| Possible JpoxHelper bug; Custom PMFCreator not honoured [message #112615] |
Tue, 19 February 2008 04:52  |
Hi!
I'm trying to use Teneo with the standard JPOX plugin (copied to
eclipse/plugins) within an RCP application. According to [1] I need to
create the PersistenceManagerFactory like this:
//set classloader for driver (using classloader from the "rcp.jars" bundle)
ClassLoader clrDriver =
Platform.getBundle("rcp.jars").loadClass("org.h2.Driver").getClassLoader();
map.put("org.jpox.primaryClassLoader", clrDriver);
//set classloader for JPOX (using classloader from the "org.jpox" bundle)
ClassLoader clrJPOX =
Platform.getBundle("org.jpox").loadClass("org.jpox.PersistenceManagerFactoryImpl ").getClassLoader()
PersistenceManagerFactory pmf = JDOHelper.getPersistenceManagerFactory(map,
clrJPOX);
Otherwise, the database driver cannot be loaded. With Teneo this procedure
should involve creating a custom PMFCreator and setting it via:
JpoxHelper.INSTANCE.setPMFCreator(pmfCreator);
This pmfCreator would then create the persistence manager factory in it's
method
getPersistenceManagerFactory()
like the code above. There is one problem however. JpoxDataStore on line 526
in createSchema(), doesn't use JpoxHelper to get a persistence manager
factory, but instead uses JDOHelper. Is that a bug? I'd say yes, because it
uses JpoxHelper in it's initialize() method. Is there a workaround
available? Placing the jpox plugin jar file within another plugin doesn't
work in my case, because I need the extension points which are registered
by the jpox plugin.
Florian
[1] http://www.jpox.org/servlet/wiki/pages/viewpage.action?pageI d=1179712
Florian Hackenberger
| Re: Possible JpoxHelper bug; Custom PMFCreator not honoured [message #112693 is a reply to message #112615] |
Wed, 20 February 2008 10:44   |
Hi Florian,
This indeed seems like a bug, can you enter a bugzilla for this?
For now you can extend the jpoxdatastore and override the createschema method.
gr. Martin
DI Florian Hackenberger wrote:
> Hi!
> clrJPOX);
> method
> by the jpox plugin.
> Cheers,
> Florian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
| Re: Possible JpoxHelper bug; Custom PMFCreator not honoured [message #113196 is a reply to message #113152] |
Mon, 25 February 2008 12:37  |
Hi Florian,
Thanks for reporting several things, I have seen your bugzillas. I will solve them in the next build
(few weeks, before eclipsecon).
gr. martin
> Martin Taal wrote:
>> Hi Florian,
>> method.
> It's the following buzilla entry:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=220145
> BTW: Another workaround is to install the JPOX plugin in eclipse (in order
> to make eclipse find the extension points) and just use the standard
> approach of putting all jars (jpox, jdo, jdbc driver) into one plugin on
> which your teneo enabled project depends. It seems like the extension
> points are actually enabled once the jar within the plugin is loaded, but
> eclipse does not 'see' them during development.
> Cheers,
> Florian
The Netherlands
| Re: Possible JpoxHelper bug; Custom PMFCreator not honoured [message #615519 is a reply to message #112615] |
Hi Florian,
gr. Martin
> Hi!
> clrJPOX);
> method
> by the jpox plugin.
> Cheers,
> Florian
The Netherlands
| Re: Possible JpoxHelper bug; Custom PMFCreator not honoured [message #615554 is a reply to message #112693] |
Mon, 25 February 2008 03:20  |
Martin Taal wrote:
> Hi Florian,
> method.
Florian
| Re: Possible JpoxHelper bug; Custom PMFCreator not honoured [message #615557 is a reply to message #113152] |
Hi Florian,
gr. martin
> Martin Taal wrote:
>> Hi Florian,
>> method.
> Cheers,
> Florian
The Netherlands
Current Time: Sun Nov 09 06:00:09 EST 2025
Powered by FUDForum. Page generated in 0.04505 seconds
