hooking up xml outline view to custom xml contentType [message #103411] |
Fri, 13 May 2005 07:46  |
next issue on my line:
I have created a custom contentType in my plugin.xml:
<?eclipse version="3.0"?>
<plugin
id="org.mozilla.solid"
name="Whack Plug-in"
version="1.0.0"
provider-name="Axel Hecht"
class="whack.WhackPlugin">
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
file-extensions="xul"
priority="high"
name="Mozilla XUL Content Type"
id="xul"
base-type="org.eclipse.core.runtime.xml"
default-charset="UTF-8" />
</extension>
<extension
point="org.eclipse.wst.sse.ui.extendedconfiguration">
<configuration type="contentoutlineconfiguration"
class=" org.eclipse.wst.xml.ui.internal.views.contentoutline.XMLCont entOutlineConfiguration "
target="org.mozilla.solid.xul" />
</extension>
</plugin>
Most of the stuff in the plugin.xml works, just the outline in the
running instance claims that an outline view for my editor wouldn't be
available.
(The editor is a multipage editor with
org.eclipse.wst.xml.ui.internal.provisional.StructuredTextEd itorXML as
one of it's pages, which works like charm)
Any hints?
Axel
Re: hooking up xml outline view to custom xml contentType [message #103677 is a reply to message #103509] |
Fri, 13 May 2005 13:57   |
Nitin Dahyabhai wrote:
> Axel Hecht wrote:
>> Thanks for the tip, but I basically want to do it the other way around.
>> You created a custom outline for xml types, I want the the standard
>> xml outline for my custom type.
>> The odd thing is, the same content as plain.xml opens in the XML
>> Source Page Editor and has an outline, the content as plain.xul opens
>> in my editor with the XML SourcePageEditor as a page and doesn't.
>> do I need to debug anything?
> If the Outline or Properties views are open, activating an editor will
> cause them to call .getAdapter() on your editor part for
> IContentOutlinePage and IPropertySheetPage. If you've embedded a
> StructuredTextEditor instance, you might just need to pass on those
> requests to it. In general, you might want to forward any getAdapter()
> calls you're not handling on your own to the StructuredTextEditor instance.
Aaaaahhhh, that works. Thanks a lot.
Now I see a java.lang.NullPointerException
with the stacktrace below, does that ring a bell with anyone?
Axel
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1484)
org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchema Impl.java:2309)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDCon creteComponentImpl.java:1219)
org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSche maImpl.java:832)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:471)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:977)
org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchem aDirectiveImpl.java:398)
at org.eclipse.xsd.impl.XSDImportImpl.importSchema(XSDImportImp l.java:476)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveSchema(XSDSchemaIm pl.java:2115)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveNamedComponent(XSD SchemaImpl.java:2138)
org.eclipse.xsd.impl.XSDSchemaImpl.resolveAttributeDeclarati on(XSDSchemaImpl.java:2163)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.resolveAttribu teDeclaration(XSDConcreteComponentImpl.java:2471)
org.eclipse.xsd.impl.XSDAttributeDeclarationImpl.patch(XSDAt tributeDeclarationImpl.java:203)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcr eteComponentImpl.java:526)
org.eclipse.xsd.impl.XSDAttributeUseImpl.patch(XSDAttributeU seImpl.java:738)
org.eclipse.xsd.impl.XSDNamedComponentImpl.patch(XSDNamedCom ponentImpl.java:727)
org.eclipse.xsd.impl.XSDTypeDefinitionImpl.patch(XSDTypeDefi nitionImpl.java:249)
org.eclipse.xsd.impl.XSDComplexTypeDefinitionImpl.patch(XSDC omplexTypeDefinitionImpl.java:994)
org.eclipse.xsd.impl.XSDElementDeclarationImpl.patch(XSDElem entDeclarationImpl.java:546)
at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java: 1488)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:832)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:249)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:264)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:349)
org.eclipse.xsd.impl.XSDSchemaImpl.getSchemaForSchema(XSDSch emaImpl.java:614)
at org.eclipse.xsd.impl.XSDSchemaImpl.createSchema(XSDSchemaImp l.java:420)
org.eclipse.xsd.util.XSDResourceImpl.handleSchemaElement(XSD ResourceImpl.java:518)
org.eclipse.xsd.util.XSDResourceImpl.findSchemas(XSDResource Impl.java:484)
at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl. java:413)
org.eclipse.wst.xsd.contentmodel.internal.XSDImpl.buildXSDMo del(XSDImpl.java:211)
org.eclipse.wst.xsd.contentmodel.internal.XSDImpl.buildCMDoc ument(XSDImpl.java:172)
org.eclipse.wst.xsd.contentmodel.internal.CMDocumentFactoryX SD.createCMDocument(CMDocumentFactoryXSD.java:61)
org.eclipse.wst.xml.core.internal.contentmodel.ContentModelM anager.createCMDocument(ContentModelManager.java:56)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl.buildCMDocument(CMDocumentManagerImp l.java:277)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl$AsyncBuildOperation.run(CMDocumentMa nagerImpl.java:262)
org.eclipse.wst.xml.core.internal.contentmodel.modelqueryimp l.CMDocumentManagerImpl$1.run(CMDocumentManagerImpl.java:228 )
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:67)
Re: hooking up xml outline view to custom xml contentType [message #120809 is a reply to message #103469] |
Thu, 14 July 2005 11:46  |
Axel Hecht wrote:
> lars gersmann wrote:
>> huhu axel,
>> take a look at Orangevolt XLST Eclipse Plugin
>> (eclipsexslt.sourceforge.net).
>> i've also implemented an custom xml outline.
>> look into the cvs to see how its done.
>> many regards,
>> lars
> You created a custom outline for xml types, I want the the standard xml
> Source Page Editor and has an outline, the content as plain.xul opens in
> Axel
hi axel,
i've looked into your solid plugin because i am also addicted to xul :-)
i have imported the xulplanet schema but eclipse seems not to work with
xul files ...
back to your mail.
your reply is not really true. i did not reimplement the wtp xml
outline. i just overlay the wtp jnodeinterface using wtp extension
points which is really elegant. not that much code. and its the real wtp
xml outline.
i will add a xul outline configuration to the xslt plugin.
have fun,
lars
FUDForum. Page generated in 0.04278 seconds
