Home » Archived » M2M (model-to-model transformation) » [ATL] can't using a UML modeler(Papyrus) to generate metamodels(KM3 , ecore)
[ATL] can't using a UML modeler(Papyrus) to generate metamodels(KM3 , ecore) [message #100613] Tue, 24 February 2009 19:41
Hi Everybody
I get some problem about using a UML modeler to generate metamodels
From this website
http://www.eclipse.org/m2m/atl/usecases/UML2MOF/userGuide.ph p
We can see the using UML Tool generated metamodels example
Follow the steps
1. install the Papyrus for UML (Ver 1.11.0)
2. install ATL
3. install the ATLuseCase from
Papyrus sources (subversion repository)
https://speedy.supelec.fr/Papyrus/svn/Papyrus/extensions/ATL UseCases/releases/1.8.1/
Then
this is my screenshot
http://img17.imageshack.us/my.php?image=45335086.jpg or
http://img17.imageshack.us/img17/626/45335086.jpg
the module option is same to the use guide's screenshot
http://www.eclipse.org/m2m/atl/usecases/UML2MOF/img/moduleSe lection.PNG
When I setup and click "Run"
There is nothing about transformation outputs
Anybody know , did I fail to install some plug-in or softwares?
and There is my log
!ENTRY org.eclipse.osgi 2 0 2009-02-23 13:00:24.875
!MESSAGE The activator com.cea.papyrus.gen.umlwithatl.uml2ecore.Activator
for bundle com.cea.papyrus.gen.umlwithatl.uml2ecore is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
com.cea.papyrus.gen.umlwithatl.uml2ecore.Activator for bundle
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction$21.run(SecureAc tion.java:406)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:404)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
com.cea.papyrus.extensionpoints.transformation.definition.Tr ansformation.getModuleInstance(Unknown
Source)
com.cea.papyrus.extensionpoints.transformation.definition.Tr ansformation.getModule(Unknown
Source)
com.cea.papyrus.extensionpoints.transformation.launch.Launch TransformationDelegate.launch(Unknown
Source)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
Caused by: java.lang.ClassNotFoundException:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 20 more
Root exception:
Source)
Source)
Source)
!ENTRY com.cea.papyrus.extensionpoints.transformation 4 0 2009-02-23
13:00:24.875
!MESSAGE could not get transformation instance
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
com.cea.papyrus.gen.umlwithatl.uml2ecore was unable to load class
com.cea.papyrus.gen.umlwithatl.uml2ecore.UML2EcoreModule.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
Source)
Source)
Source)
org.eclipse.core.runtime.CoreException[1]:
Source)
Source)
Source)
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2009-02-23 13:00:24.875
!MESSAGE Plug-in com.cea.papyrus.gen.umlwithatl.uml2ecore was unable to
load class com.cea.papyrus.gen.umlwithatl.uml2ecore.UML2EcoreModule.
!STACK 0
Source)
Source)
Source)
13:00:24.875
!MESSAGE
!STACK 0
Source)
Thank you very much
micromilua
Previous Topic:[ATL] Problem with UML elementImport on Emf VM
Next Topic:MtATL2009 CfP
Current Time: Tue Jul 22 15:52:52 EDT 2025
Powered by FUDForum. Page generated in 0.03083 seconds
