Home » Language IDEs » C / C++ IDE (CDT) » difference between compiling in terminal or eclipse
difference between compiling in terminal or eclipse [message #818262] Sun, 11 March 2012 05:55 Go to next message
is there any difference about when i compile on eclipse or in my terminal?
because when i compile in my terminal theres no problem but
when i compile using eclipse.. "sometime" it said make error 1
and when i say sometime its really random because i remember using the same code
and like... T
the whole thing with the errors is sometime it dont even say theres an error when compiling,
i must totally press freshen updated files for the indexer to see them lol.
not saying that eclipse CDT suck but im just wondering whats that error..
[Updated on: Sun, 11 March 2012 06:00] by Moderator
Re: difference between compiling in terminal or eclipse [message #818556 is a reply to message #818262] Sun, 11 March 2012 16:52 Go to previous messageGo to next message
What's the full error? Does it just say "error 1"?
Re: difference between compiling in terminal or eclipse [message #818973 is a reply to message #818556] Mon, 12 March 2012 06:31 Go to previous messageGo to next message
Do you use the same compiler in Eclipse and in your terminal?
Re: difference between compiling in terminal or eclipse [message #820398 is a reply to message #818973] Wed, 14 March 2012 00:20 Go to previous messageGo to next message
the full error is make error 1
i use linux fedora by the way
yes i do use the same compiler
Re: difference between compiling in terminal or eclipse [message #820452 is a reply to message #820398] Wed, 14 March 2012 02:23 Go to previous messageGo to next message
*bump* the problem is the IDE useally dont tell all the errors and instead it write "make error 1"
Re: difference between compiling in terminal or eclipse [message #820455 is a reply to message #820452] Wed, 14 March 2012 02:28 Go to previous message
*bumping a bump* i found my error.. it seem i had a syntax error while including the library lol sorry guys
Previous Topic:CDT won't install on Indigo
Next Topic:gcc compiler and jtag device
Current Time: Wed Jun 18 00:37:00 EDT 2025
Powered by FUDForum. Page generated in 0.27347 seconds
