Home » Language IDEs » C / C++ IDE (CDT) » Debug view does not show variables
Debug view does not show variables [message #817032] Fri, 09 March 2012 09:57
Hello everybody,
I have the problem, that I want to debug a C++ program. After some tricks I got it compile using eclipse and g++ under windows. I started debugging with gdb and all worked well.
After some time I wanted to check some local variables in the debug view of eclipse. They were not there. This is definitively not a problem of optimization as there is no optimization turned on.
Also I found that the whole variable list seems to be "out of sync". I stepped into some procedures and the local variables did not even change. I can now go forward in code and not more modifications happen. Just frozen.
If I try to refresh by selecting another stack frame and going back again, no more variables are shown. Neither local nor global nor the 'this'-pointer. A restart of the debug session does not bring them back; I have to restart eclipse.
I unfortunately can't say, when I happened; suddenly the variable list does not work anymore.
Can you tell me if you have similar problems?
For me this looks like a bug. Do you agree?
PS: I am using Eclipse Indigo.
[Updated on: Fri, 09 March 2012 10:07] by Moderator
Previous Topic:eclipse metadata !!!!!
Next Topic:no sourece available for xxxxx
Current Time: Mon Jun 16 06:25:45 EDT 2025
Powered by FUDForum. Page generated in 0.04843 seconds
