Launch Eclipse App with OSGi-Service [message #99327] |
Fri, 05 October 2007 12:39 |
Originally posted by: Jan-Hendrik.Diederich.bredex.de
I use ".launch" files to launch Eclipse RCP Applications from within
Eclipse. Launching Eclipse RCP apps works flawless. The problem is, I also
want to start an Equinox service "plugin" with the launcher. This works
flawless and easy if I start an OSGi Framework. But I want to start an
Eclipse RCP application which uses OSGi services.
Two examples to make it clear:
First:
- I start an "Eclipse Application" from within Eclipse.
- Works flawless. Except the OSGi service doesn't get started. Its
overwritten .start and .stop methods are never entered. Even its
constructor is never called.
-> This is the target: Launching an already existing Eclipse RCP Application
with my OSGi service.
Second:
- I start an "OSGi Framework" (Equinox).
- My service gets started. Its methods .start (and later .stop) are called.
- The Equinox console opens, where I can input commands (like "ss" for
plugin/bundle states).
-> This is __not__ the target. I want a classic Eclipse RCP Application. But
with new selfmade OSGi services _and_ already existing plugins.
I tried already launching it as an application _and_ a product. I already
added "-Dosgi.framework.extensions=myextensionpackage" to the arguments.
But it didn't work.
Oh, and Eclipse tells me everytime in the "Plugin-Details" Dialog that the
bundle itself has been loaded!
Has anyone an idea how I start OSGi services with an Eclipse launcher in
an Eclipse Application configuration?
Jan Diederich
Re: Launch Eclipse App with OSGi-Service [message #99390 is a reply to message #99327] |
Fri, 05 October 2007 22:42 |
Originally posted by: alex_blewitt.yahoo.com
Same way as in an OSGi app. The bundle will only get started when the classes are accessed; so if nothing accesses them, they won't start. (This assumes you have Bundle-ActivationPolicy: lazy in the manifest.) The alternative is to add the bundle to the osgi.bundles property to start it up when the Eclipse instance starts.
Alex.
Re: Launch Eclipse App with OSGi-Service [message #99436 is a reply to message #99390] |
Mon, 08 October 2007 10:11 |
Thanks for the answer. But I have already tried it with disabled Lazy
Activation. It makes no difference. And if I set the OSGi property
"osgi.bundles=mybundle" my plugin gets activated but I have another
problem. The needed basic bundles including "osgi.eclipse.core.runtime"
aren't loaded. Even if I add them
(osgi.bundles=org.eclipse.equinox.common@2:start,org.eclipse.update.configurator@3:start,org.eclipse.core.runtime@start,myplugin@start),
it won't work. Then it tells me it can't find them. Example:
!ENTRY org.eclipse.osgi 4 0 2007-10-08 11:57:52.945
!MESSAGE Bundle org.eclipse.update.configurator@3:start not found.
And without start-level and method:
"!MESSAGE Bundle org.eclipse.update.configurator not found."
Although the Eclipse dependency checker put them correctly in the
"included plugins" list of the launcher configuration.
Thanks for any ideas,
Jan Diederich
FUDForum. Page generated in 0.03154 seconds
