Home » Archived » Visual Editor (VE) » Start of a data binding framework released--help requested
Start of a data binding framework released--help requested [message #95574] |
Thu, 30 June 2005 17:46  |
All,
The VE team yesterday released the start of a data binding framework
into CVS.
We believe that this framework belongs in VE because the framework is
architected in a way that we can support both Swing and SWT data binding
from the same code base, consistent with our charter. We also can bind
controls to any back-end--from plain old Java objects to EJB3 or Db4o
(http://www.db4o.com) [full disclosure, I work for db4objects, the
leading open-source object database company].
Currently this framework implements binding between plain old Java
objects and an SWT Text control, along with data validation based on
regular expressions, Java code, or just the data type of the Java
property being edited. Stubs are in the code showing how it can easily
be extended to support editing using any SWT control and any data back-end.
The VE team currently does not have plans to provide tooling support for
this library, but we had it, so we thought we'd release it. :-) Since
we don't have data binding in any of the VE plan documents yet, please
consider this released on an unofficial basis only for now. Of course,
we would love to see what the community could come up in terms of
completing it and adding tooling support, and we would support the
community in any efforts to do so.
You can check out the new library (called Sweet) from CVS:
Host: dev.eclipse.org
Repository: /home/tools/
Package: org.eclipse.ve.sweet
The class org.eclipse.ve.sweet.test.TestSweet is a simple tutorial
showing how to use most of the framework's features.
Dave Orme
Visual Editor Project lead
http://www.db4o.com -- The Open-source Java Object Database
http://xswt.sf.net -- XML-based SWT page description language
Re: Start of a data binding framework released--help requested [message #95890 is a reply to message #95574] |
Sun, 03 July 2005 09:43   |
Dave,
Is it possible bind nested properties.For example :
bean Address with properties:
String street
String city
String state
bean Person
String name
int age
Address address
binding :
Text street = new Text(shell, SWT.BORDER);
ObjectEditorFactory.factory = new JavaObjectEditorFactory();
personEditor = ObjectEditorFactory.edit(person);
personEditor.bind(name, "Name");
personEditor.bind(age, "Age");
personEditor.bind(street,"address.street");
and one question :
why binding properties have first upper character (Name,Age), except simple
property name name,age ... ?
Haris Peco
David J. Orme wrote:
> All,
> into CVS.
> back-end.
> Best regards,
> Dave Orme
Re: Start of a data binding framework released--help requested [message #95920 is a reply to message #95890] |
Sun, 03 July 2005 19:54   |
snpe wrote:
> Dave,
> String street
> String city
> String state
> bean Person
> String name
> int age
> Address address
> binding :
Not this way. You would need to:
IObjectEditor personEditor = ObjectEditorFactory.edit(person);
IObjectEditor addressEditor =
ObjectEditorFactory.edit(person.getAddress());
addressEditor.bind(street,"Street");
Right now there is no way to automatically link these editors, but it
wouldn't be hard to write a MasterDetailController to generically manage
this 1:1 master-detail relationship. Something that could work like:
new MasterDetailController(personEditor, "Address", addressEditor);
where the MasterDetailController registers itself as an
IInputChangeListener on personEditor, automatically receives the
"Address" property value when personEditor's input changes, and then
sets the resulting address object as the input on addressEditor.
All that's required in order to do this is to add the
IInputChangeListener callback in IObjectEditor, and to code the
MasterDetailController.
> and one question :
To handle some legacy db4o situations. :-) I really want folks to
always use upper case property names always, so this probably should be
changed to force this.
Thanks for the observation.
Dave Orme
Re: Start of a data binding framework released--help requested [message #95934 is a reply to message #95920] |
Sun, 03 July 2005 20:28   |
I just added the IInputChangeListener event to IObjectEditor but I won't
get a chance to implement the MasterDetailController right now. In case
you or someone else wants to, here's what needs to happen:
* MasterDetailController must implement IImputChangeListener.
* It must include a disconnect() method that unregisters itself from the
IObjectEditor to which it is registered as an IInputChangeListener.
* One convenient way to establish a master-detail link would be to
include something like the constructor I showed in my previous example.
* When the MasterDetailController gets an inputChanging() event, it
should ask the detail object's editor to commit() any changes. If the
detail object editor cannot commit(), inputChanging() should return
false to abort the input change operation.
* When the MasterDetailController gets the inputChanged() event, it
should reload the detail object from the new master object's property
and set the new detail object as the input in the detail object editor.
Dave Orme
> snpe wrote:
>> Dave,
>> String street
>> String city
>> String state
>> bean Person
>> String name
>> int age
>> Address address
>> binding :
>> and one question :
>> simple
> Best regards,
> Dave Orme
Re: Start of a data binding framework released--help requested [message #95976 is a reply to message #95934] |
Sun, 03 July 2005 23:46   |
Dave,
see spring-rcp binding (swing only) (www.springframework.org)
spring rcp have feature bind like this :
bind(component,"address.street")
It is great, but don't support swt
regards
> Best regards,
> Dave Orme
>> snpe wrote:
>>> Dave,
>>> String street
>>> String city
>>> String state
>>> bean Person
>>> String name
>>> int age
>>> Address address
>>> binding :
>>> and one question :
>>> simple
>> Best regards,
>> Dave Orme
Re: Start of a data binding framework released--help requested [message #96133 is a reply to message #95990] |
Tue, 05 July 2005 10:16   |
Konstantin Scheglov wrote:
> David J. Orme:
>> into CVS.
> [cut]
>> for this library, but we had it, so we thought we'd release it. :-)
>> Since we don't have data binding in any of the VE plan documents yet,
>> please consider this released on an unofficial basis only for now. Of
>> course, we would love to see what the community could come up in terms
>> of completing it and adding tooling support, and we would support the
> I would like contribute to this project as part of my work for
> Instantiations. But right now I have question: why not use some existing
> data binding framework (such as JGoodies, https://binding.dev.java.net)
> as base and implement SWT/JFace support on top of it? Do we really need
> create new binding framework from scratch?
Here's why I think a fresh approach is helpful compared to existing ones:
- Support for multiple back-ends and multiple front-ends should be
designed in, not included as an afterthought. For example, given this
code, one could now write a Hibernate-aware back-end really quickly.
Which brings me to the next point:
- I believe that binding frameworks need explicit support for
transactional behavior. Getting the data between your Java model
objects and your UI is only 2/3 of the problem. The rest is setting
your modified Java objects back into the persistent store, calling
commit() or rollback() on the transaction at the right times, etc. The
framework should do this automatically.
- The approach here integrates binding and validation seamlessly. For
all the simple cases (where the data type determines the type of
validation rules required), you don't have to even think about
validation--it's done automatically. Validation should automatically be
integrated into the object's transactional behavior with the underlying
persistence mechanism, whatever that is.
Dave Orme
Re: Start of a data binding framework released--help requested [message #96572 is a reply to message #96133] |
Thu, 07 July 2005 11:51  |
Gili and I were talking about this yesterday, and he added another
reason/suggestion:
Eclipse's data binding framework should be based on, integrate with, and
use JFace whenever possible since JFace is Eclipse's (currently
somewhat primitive) data binding framework.
I have done some refactoring to implement this, so anyone who has the
code should update to the latest CVS version.
Dave
Re: Start of a data binding framework released--help requested [message #608935 is a reply to message #95574] |
Dave,
String street
String city
String state
bean Person
String name
int age
Address address
binding :
and one question :
Haris Peco
> All,
> into CVS.
> back-end.
> Best regards,
> Dave Orme
Re: Start of a data binding framework released--help requested [message #608938 is a reply to message #95890] |
snpe wrote:
> Dave,
> String street
> String city
> String state
> bean Person
> String name
> int age
> Address address
> binding :
> and one question :
Dave Orme
Re: Start of a data binding framework released--help requested [message #608939 is a reply to message #95920] |
Dave Orme
> snpe wrote:
>> Dave,
>> String street
>> String city
>> String state
>> bean Person
>> String name
>> int age
>> Address address
>> binding :
>> and one question :
>> simple
> Best regards,
> Dave Orme
Re: Start of a data binding framework released--help requested [message #608940 is a reply to message #95920] |
Sun, 03 July 2005 20:33  |
>> and one question :
>> simple
Actually, I'm wrong here. It's this way so that if someone defines
fields using lower-case initial letters (like usual), but adds a getter
with camel caps (like usual), Sweet will automatically pick up the
getter and use that.
Dave Orme
Re: Start of a data binding framework released--help requested [message #608944 is a reply to message #95934] |
Dave,
regards
> Best regards,
> Dave Orme
>> snpe wrote:
>>> Dave,
>>> String street
>>> String city
>>> String state
>>> bean Person
>>> String name
>>> int age
>>> Address address
>>> binding :
>>> and one question :
>>> simple
>> Best regards,
>> Dave Orme
Re: Start of a data binding framework released--help requested [message #608946 is a reply to message #95574] |
Sun, 03 July 2005 23:44  |
David J. Orme:
> into CVS.
[cut]
SY, Konstantin Scheglov
Re: Start of a data binding framework released--help requested [message #608948 is a reply to message #95976] |
Sun, 03 July 2005 23:47  |
snpe:
There is also Commons-Beans library from Jakarta that supports access
to inner properties. May be it would be good to use it...
Re: Start of a data binding framework released--help requested [message #608957 is a reply to message #96004] |
Tue, 05 July 2005 09:37  |
> snpe:
That might be a good idea.
However, if this is the only feature we need from Commons Beans, it is
probably a better idea to just implement it ourselves if that's what
people want in order to avoid adding a dependency that we force everyone
to drag in. It would be really simple to implement...
I'm happy to look at patches. :-)
Dave Orme
Re: Start of a data binding framework released--help requested [message #608958 is a reply to message #95990] |
> David J. Orme:
>> into CVS.
> [cut]
Dave Orme
Re: Start of a data binding framework released--help requested [message #608988 is a reply to message #96133] |
reason/suggestion:
Dave
Current Time: Fri Jun 13 10:38:56 EDT 2025
Powered by FUDForum. Page generated in 0.06656 seconds
