JComboBox an VE ??? [message #94884] |
Mon, 27 June 2005 03:57  |
Originally posted by: lars.bergholm.sifu.se
The VE doesn't show the combobox when it is initialized with items?
Does anybody now how to deal with this
private JComboBox getJCBR113() {
String[] ChoicesStrings = { "Yes", "No", "N/A" };
if (jCBR113 == null) {
jCBR113 = new JComboBox(ChicesStrings);
jCBR113.setBounds(182, 29, 64, 19);
jCBR113.setSelectedIndex(0);
return jCBR113;
When using
jCBR113 = new JComboBox(); it is ok and shows up in the VE
but using the code above returns 'ChicesStrings too complicated'
and Index out of bounds (as a result of the first error ?)
Thanks for any help
Re: JComboBox an VE ??? [message #94974 is a reply to message #94900] |
Mon, 27 June 2005 10:24  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Up until VE 1.1 I20050623 driver, the code you used would not be able to
instantiate the JComboBox. The I20050623 driver is a developement driver
for working with Eclipse 3.1RC3. It will not work on Eclipse 3.0.x and
it is not available through update manager since it is not a final
release yet. You will need to download it and the requirements to use it.
Lars wrote:
> I just found out there is an newer version of the VE
> I have visual editor 1.0.2.1
> (But Update on the helpmenu doesn't find it)
> Trying to install some other way...
Rich Kulp
Re: JComboBox an VE ??? [message #608083 is a reply to message #94884] |
Mon, 27 June 2005 04:44  |
Re: JComboBox an VE ??? [message #608094 is a reply to message #94900] |
Rich Kulp
FUDForum. Page generated in 0.03510 seconds
