Home » Archived » Test and Performance Tools Platform (TPTP) » JBossAgent immediately terminates after start
JBossAgent immediately terminates after start [message #8387] |
Mon, 07 March 2005 09:29  |
--------------070101000002000305080607
i would like to get the JBossAgent running
by selecting:
Run --> Profiling --> J2EE Applications Server - JBoss --> New --> Run
but it immediatly dies after the start (see Agent Controller servicelog.log in attachment ) .
Where can i get some information about configuring and using the JBossAgent?
Holger
Content-Type: text/x-log;
name="servicelog.log"
Content-Disposition: inline;
filename="servicelog.log"
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60004AED4108095A2692AAFB1" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22003" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60004F2FA0BCEFC5A27ABF9BD" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60004F7A06D1851300C90ABF7" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60004FDC8342A8A542C93C4F6" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA6000502844AC365470EFFB660" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60005051C22D8B3F72C5E744F" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60005057D0A397AF21EA6C35C" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA600050755277FAE144B8394F6" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA60005079841F324B0374A52E8" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:05:26.000000Z" globalInstanceId="k22C5FA6000509A45CB7566911F93FA2" msg="Cannot bind to client handling socket 4 using port 10002. Make sure the port is free and no other RAC is using the same port." severity="55" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22003" subComponent="framework/RAServer/messagePump.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE700038AE81D2C81EE76F6D307" msg="Service starting" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22054" subComponent="framework/RAServerConfig/RAServerConfigBinding2.cpp " componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003989764B28EEE71094FD3" msg="Successfully loaded plugin: org.eclipse.hyades.datacollection" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE700039B3A63186AC14C0EB9DA" msg="Successfully loaded plugin: org.eclipse.hyades.logging.parsers" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE700039F78536029E21141DEB9" msg="Successfully loaded plugin: org.eclipse.hyades.test" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003AB4C3EAD38683FC0E6A7" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.jmxagent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003ADB956389FC20331973A" msg="Successfully loaded plugin: org.eclipse.hyades.perfmon.linux" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003AE5215C63E3604CDE262" msg="Active configuration set to: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003B0C466894223569E094F" msg="Loaded configuration: default" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:06:31.000000Z" globalInstanceId="k22C5FE70003B13067C185FE1A5C254B" msg="Service started successfully" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:12:56.000000Z" globalInstanceId="k22C6168000779E92DE40E82417DBB95" msg="Incoming connection request on socket 8 from 0x100007f" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22054" subComponent="framework/RAServer/messagePump.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:12:56.000000Z" globalInstanceId="k22C616800077D33369AB23B1475D96B" msg="Connection accepted on socket 8" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:18.000000Z" globalInstanceId="k22C617E0009018A1491403023291AA4" msg="Incoming connection request on socket 9 from 0x100007f" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:18.000000Z" globalInstanceId="k22C617E0009038022F2FB0D3B34373D" msg="Connection accepted on socket 9" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:26.000000Z" globalInstanceId="k22C6186000936CE3677D6D92381CB80" msg="Attempting to launch process : JBossAgent (null)" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22054" subComponent="framework/RAServer/launcher.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:26.000000Z" globalInstanceId="k22C6186000D6D593633BBB205BF7328" msg="Incoming connection request from agent JBossAgent in process 22127 with uuid UUID-1110204806-874414-1245975137-569314866" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:26.000000Z" globalInstanceId="k22C6186000D6DF06F0D6E5B175700AB" msg="Registered Agent UUID-1110204806-874414-1245975137-569314866." severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:27.000000Z" globalInstanceId="k22C6187000D3F956290CF3F5130254C" msg="Preparing Agent active" severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22054" subComponent="framework/RAServer/RACommS.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:27.000000Z" globalInstanceId="k22C6187000D472D5CCE04D3145484D2" msg="Requesting shared memory 1048576 bytes, allocating 1048576 bytes, system max 33554432 bytes" severity="30" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:27.000000Z" globalInstanceId="k22C6187000D4DC3228CC9BE33ABCC1C" msg="Created data channel with name rabuffer0 and CB addr 0x5233e154 buffer addr 0x5233f2ec size in=1048576 size out=1048576" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:27.000000Z" globalInstanceId="k22C6187000D4E7175164B292D4D07E5" msg="Connected to client data channel socket on port 41103 with descriptor 14" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:27.000000Z" globalInstanceId="k22C6187000D4EED2BF6783354DCFB3C" msg="Created flusher thread and about to send message to agent" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:28.000000Z" globalInstanceId="k22C61880002A7A17C163B365A6E3A60" msg="Deregistering agent UUID-1110204806-874414-1245975137-569314866. " severity="10" version="1.0.1">
<sourceComponentId component="Data Collection Engine" componentIdType="Application" location="127.0.0.1" locationType="IPV4" processId="22054" subComponent="framework/RAServer/util.c" componentType="Eclipse_TPTP"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:28.000000Z" globalInstanceId="k22C61880002A94A5F5F801123F6BFD3" msg="Removing agent UUID-1110204806-874414-1245975137-569314866. from client" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:31.000000Z" globalInstanceId="k22C618B0007CBFE4E58E6706C0AD79C" msg="Process 22127 does not exist so scrub it" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2005-03-07T14:13:31.000000Z" globalInstanceId="k22C618B0007CC5D41FE73821A161FC3" msg="Process 22127 exited" severity="10" version="1.0.1">
</situation>
</CommonBaseEvent>
--------------070101000002000305080607--
Re: JBossAgent immediately terminates after start [message #9382 is a reply to message #9309] |
Tue, 08 March 2005 08:27   |
Hi George,
thanks for your dedicated support.
I tried it again with version 3.2A_20050301_1749 but ...
.... it does not work - sorry!
The JBoss agent does the same as before: it terminates immediatly.
The linux agent starts up and shows the descriptors provided by it, but no graphs
are painted in the statistical console.
Btw. after a refresh the statistical console needs up to 30 seconds until
it resumes painting.
Holger
George Christelis wrote:
> Hi Holger,
> I will have to run futher tests against AS 4.1 sp 1 as we have been doing
> our testing on an earlier build. Something you could try in the meanwhile:
> if you have not done so already, grab the 3.2A_20050301_1749 build from the
> TPTP download site. There was a known issue that would cause the agents to
> fail to load. This should at least resolve the linux agent issue while I
> look into the JBoss issues.
> George
> "Holger Machens" <machens@informatik.fh-wiesbaden.de> wrote in message
> news:d0jlo8$p2f$1@www.eclipse.org...
>>Hi George,
>>yes, i have run the SetConfig script and i have set the right directory.
>>I try to 'profile' the newest version of JBoss AS 4.1 sp 1.
>>I'm using TPTP 3.2 with the appropriate plugins (shown on your download
> page).
>>Operating System is the newest Debian Linux 3.2 (Kernel 2.6.) with current
> update packages.
>>I found the same behavior starting the linux system agent.
>>But profiling java applications or attaching to our own logging and
> profiling agents works correct.
>>Holger
>>>Hi Holger,
>>>Have you run the agent controller SetConfig and set the correct JBoss
> home
>>>value? This should point to the base of your jboss installation. What
>>>version of JBoss are you attempting to grab JMX counters from?
>>> George
>>>news:d0hoga$vt1$1@www.eclipse.org...
>>>>Hello,
>>>>by selecting:
>>>JBossAgent?
>>>>Thanks
>>>>Holger
> starting"
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22003"
>>>></situation>
>>>></CommonBaseEvent>
> and no
>>>></situation>
>>>></CommonBaseEvent>
> starting"
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
> version="1.0.1">
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> loaded
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> connection
>>>></situation>
>>>></CommonBaseEvent>
> accepted
>>>></situation>
>>>></CommonBaseEvent>
> connection
>>>></situation>
>>>></CommonBaseEvent>
> accepted
>>>></situation>
>>>></CommonBaseEvent>
>>>></situation>
>>>></CommonBaseEvent>
> connection
> version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
> Agent
> version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
>>>></situation>
>>>></CommonBaseEvent>
> shared
> bytes"
>>>processId="22054"
>>>></situation>
>>>></CommonBaseEvent>
> 0x5233f2ec
>>>></situation>
>>>></CommonBaseEvent>
> client
>>>version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
> version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
> agent
>>>version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
>>>version="1.0.1">
>>>></situation>
>>>></CommonBaseEvent>
> does
>>>></situation>
>>>></CommonBaseEvent>
>>>></situation>
>>>></CommonBaseEvent>
Re: JBossAgent immediately terminates after start [message #12677 is a reply to message #9382] |
Wed, 30 March 2005 11:43   |
Hello?
Any ideas or comments?
Holger
Holger Machens wrote:
> Hi George,
> no graphs
> Holger
>> Hi Holger,
>> meanwhile:
>> from the
>> agents to
>> George
>>> Hi George,
>> page).
>>> current
>> update packages.
>>> Holger
>>>> Hi Holger,
>> home
>>>> George
>>>>> Hello,
>>>>> by selecting:
>>>> JBossAgent?
>>>>> Thanks
>>>>> Holger
>> starting"
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>>>> version="1.0.1">
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> started
>>>> processId="22003"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> and no
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> starting"
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>> version="1.0.1">
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> loaded
>>>> version="1.0.1">
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> started
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> connection
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> accepted
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> connection
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> accepted
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> connection
>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> Agent
>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> Agent
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> shared
>> bytes"
>>>> processId="22054"
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> 0x5233f2ec
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> client
>>>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> flusher
>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> agent
>>>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>> version="1.0.1">
>>>>> </situation>
>>>>> </CommonBaseEvent>
>> does
>>>>> </situation>
>>>>> </CommonBaseEvent>
>>>>> </situation>
>>>>> </CommonBaseEvent>
Re: JBossAgent immediately terminates after start [message #13544 is a reply to message #12677] |
Tue, 05 April 2005 07:15   |
Hi Holger,
I have managed to get to the bottom of this. The JMX implementation has
changed quite drastically between JBoss 3.2x and 4.0 sp1. There is no
backward compatability, so the agent's JMX connection mechanism needs to be
changed accordingly. I am busy on this now. Once I have been able to test
and verify the code I will send you an update.
George
news:d2el1u$i4q$1@news.eclipse.org...
> Hello?
> Holger
> > Hi George,
> > no graphs
until
> > Holger
> >> Hi Holger,
doing
> >> meanwhile:
> >> from the
> >> agents to
I
> >> George
> >>> Hi George,
directory.
download
> >> page).
> >>> current
> >> update packages.
> >>> Holger
> >>>> Hi Holger,
> >> home
> >>>> George
message
> >>>>> Hello,
> >>>>> by selecting:
Run
> >>>> JBossAgent?
> >>>>> Thanks
> >>>>> Holger
> >> starting"
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >>>> version="1.0.1">
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >>>> started
locationType="IPV4"
> >>>> processId="22003"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
to
> >> and no
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> starting"
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >> version="1.0.1">
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> loaded
> >>>> version="1.0.1">
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >>>> started
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> connection
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> accepted
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> connection
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> accepted
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
to
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> connection
> >> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> Agent
> >> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >>>> Agent
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> shared
> >> bytes"
locationType="IPV4"
> >>>> processId="22054"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> 0x5233f2ec
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >> client
> >>>> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >>>> flusher
> >> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
msg="Deregistering
> >> agent
> >>>> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
agent
severity="10"
> >>>> version="1.0.1">
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
22127
> >> does
locationType="IPV4"
> >>>>> </situation>
> >>>>> </CommonBaseEvent>
> >>>> globalIn
Re: JBossAgent immediately terminates after start [message #13735 is a reply to message #13544] |
Wed, 06 April 2005 04:15  |
Hi George,
thank you for your answer.
A fixed version would be great.
But there is one question left: What's wrong with the linux agent?
>>>no graphs
Please don't hurry with this questions, i think you might have
tasks with higher priority. But it would be nice to have the
linux agent running until end of next week, because i would like to
present the functionallity to our cooperation partner.
Holger
> Hi Holger,
> George
>>Hello?
>>Holger
>>>Hi George,
>>>no graphs
> until
>>>Holger
>>>>Hi Holger,
> doing
>>>>meanwhile:
>>>>from the
>>>>agents to
> I
>>>> George
>>>>>Hi George,
> directory.
> download
>>>>page).
>>>>>current
>>>>update packages.
>>>>>Holger
>>>>>>Hi Holger,
>>>>home
>>>>>> George
> message
>>>>>>>Hello,
>>>>>>>by selecting:
> Run
>>>>>>JBossAgent?
>>>>>>>Thanks
>>>>>>>Holger
Current Time: Sat Jul 19 11:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.07989 seconds
