Re: [CDO] Can't migrate ecore file in Eclipse 3.3 [message #91809 is a reply to message #91794] |
Wed, 25 July 2007 20:54 |
Originally posted by: stepper.sympedia.de
Mark,
I already planned to ask whether you are still using CDO. I'm working on
a complete rewrite of both Net4j and CDO for over half a year.
Everything is even much better now ;-) Are you interested in trying it?
I could send you a Team PSF to checkout the latest code. Of course its
written for Eclipse 3.3 and EMF 2.3. The version you are currently using
is really old and I hope that I won't have to migrate it to 3.3. Of
course if you really need it... ;-)
Cheers
/Eike
Mark schrieb:
> I have recently installed Eclipse 3.3, and all the associated plugins
> for EMF, etc.
> I then installed the most recently released CDO plugins, created a
> simple ecore file and then tried to migrate the ecore file.
> When I make the selection I get a popup that states that the CDO
> client plugin is not in the workspace, shoudl it import...as source
> plugin.
> I select OK and then get an error that follows. Is this possibly an
> issue with Eclipse 3.3 and CDO or something else.?
> Mark.
> java.lang.NoSuchMethodError:
> org.eclipse.pde.internal.ui.wizards.imports.PluginImportWiza rd.getImportOperation(Lorg/eclipse/swt/widgets/Shell;I[Lorg/ eclipse/pde/core/plugin/IPluginModelBase;Z)Lorg/eclipse/jfac e/operation/IRunnableWithProgress;
> at
> org.eclipse.emf.cdo.utilities.migrator.MigratorUtil.importCl ientPlugin(MigratorUtil.java:358)
> at
> org.eclipse.emf.cdo.utilities.migrator.internal.actions.Abst ractFileAction.ensureClientProject(AbstractFileAction.java:1 42)
> at
> org.eclipse.emf.cdo.utilities.migrator.internal.actions.Abst ractFileAction.run(AbstractFileAction.java:87)
> at
> org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:256)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:545)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
> at
> org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1101)
> at
> org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3319)
> at
> org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
> at
> org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at
> org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
Re: [CDO] Can't migrate ecore file in Eclipse 3.3 [message #95130 is a reply to message #95100] |
Fri, 31 August 2007 19:49 |
--------------010109020003060404020502
Mark schrieb:
> bump
What's this??
BTW. we just moved Net4j and CDO from the Technology to the Modeling
project.
Here are the new PSFs...
Cheers
/Eike
Content-Type: text/xml;
name="cdo.psf"
Content-Disposition: inline;
filename="cdo.psf"
PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiPz4NCjxwc2Yg dmVyc2lvbj0i
Mi4wIj4NCjxwcm92aWRlciBpZD0ib3JnLmVjbGlwc2UudGVhbS5jdnMuY29y ZS5jdnNuYXR1
cmUiPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpkZXYuZWNs aXBzZS5vcmc6
L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlwc2UuZW1mL29yZy5lY2xpcHNl LmVtZi5jZG8v
cGx1Z2lucy9vcmcuZWNsaXBzZS5lbWYuY2RvLG9yZy5lY2xpcHNlLmVtZi5j ZG8iLz4NCjxw
cm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpleHRzc2g6ZGV2LmVjbGlwc2Uub3Jn Oi9jdnNyb290
L21vZGVsaW5nLG9yZy5lY2xpcHNlLmVtZi9vcmcuZWNsaXBzZS5lbWYuY2Rv L3BsdWdpbnMv
b3JnLmVjbGlwc2UuZW1mLmNkby1mZWF0dXJlLG9yZy5lY2xpcHNlLmVtZi5j ZG8tZmVhdHVy
ZSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpkZXYuZWNs aXBzZS5vcmc6
ZG9jL29yZy5lY2xpcHNlLmVtZi5jZG8uZG9jLG9yZy5lY2xpcHNlLmVtZi5j ZG8uZG9jIi8+
DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xpcHNl Lm9yZzovY3Zz
cm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2UuZW1m LmNkby9kb2Mv
b3JnLmVjbGlwc2UuZW1mLmNkby5kb2MtZmVhdHVyZSxvcmcuZWNsaXBzZS5l bWYuY2RvLmRv
Yy1mZWF0dXJlIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3No OmRldi5lY2xp
cHNlLm9yZzovY3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3Jn LmVjbGlwc2Uu
ZW1mLmNkby9wbHVnaW5zL29yZy5lY2xpcHNlLmVtZi5jZG8uZWRpdCxvcmcu ZWNsaXBzZS5l
bWYuY2RvLmVkaXQiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpleHRz c2g6ZGV2LmVj
bGlwc2Uub3JnOi9jdnNyb290L21vZGVsaW5nLG9yZy5lY2xpcHNlLmVtZi9v cmcuZWNsaXBz
ZS5lbWYuY2RvL2V4YW1wbGVzL29yZy5lY2xpcHNlLmVtZi5jZG8uZXhhbXBs ZXMtZmVhdHVy
ZSxvcmcuZWNsaXBzZS5lbWYuY2RvLmV4YW1wbGVzLWZlYXR1cmUiLz4NCjxw cm9qZWN0IHJl
ZmVyZW5jZT0iMS4wLDpleHRzc2g6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290 L21vZGVsaW5n
LG9yZy5lY2xpcHNlLmVtZi9vcmcuZWNsaXBzZS5lbWYuY2RvL3BsdWdpbnMv b3JnLmVjbGlw
c2UuZW1mLmNkby5wcm90b2NvbCxvcmcuZWNsaXBzZS5lbWYuY2RvLnByb3Rv Y29sIi8+DQo8
cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xpcHNlLm9y ZzovY3Zzcm9v
dC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2UuZW1mLmNk by9wbHVnaW5z
L29yZy5lY2xpcHNlLmVtZi5jZG8uc2VydmVyLG9yZy5lY2xpcHNlLmVtZi5j ZG8uc2VydmVy
Ii8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xp cHNlLm9yZzov
Y3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2Uu ZW1mLmNkby9w
bHVnaW5zL29yZy5lY2xpcHNlLmVtZi5jZG8uc2VydmVyLWZlYXR1cmUsb3Jn LmVjbGlwc2Uu
ZW1mLmNkby5zZXJ2ZXItZmVhdHVyZSIvPg0KPHByb2plY3QgcmVmZXJlbmNl PSIxLjAsOmV4
dHNzaDpkZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVj bGlwc2UuZW1m
L29yZy5lY2xpcHNlLmVtZi5jZG8vcGx1Z2lucy9vcmcuZWNsaXBzZS5lbWYu Y2RvLnNlcnZl
ci5kYixvcmcuZWNsaXBzZS5lbWYuY2RvLnNlcnZlci5kYiIvPg0KPHByb2pl Y3QgcmVmZXJl
bmNlPSIxLjAsOmV4dHNzaDpkZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3QvbW9k ZWxpbmcsb3Jn
LmVjbGlwc2UuZW1mL29yZy5lY2xpcHNlLmVtZi5jZG8vdGVzdHMvb3JnLmVj bGlwc2UuZW1m
LmNkby50ZXN0cyxvcmcuZWNsaXBzZS5lbWYuY2RvLnRlc3RzIi8+DQo8cHJv amVjdCByZWZl
cmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC9t b2RlbGluZyxv
cmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2UuZW1mLmNkby90ZXN0cy9vcmcu ZWNsaXBzZS5l
bWYuY2RvLnRlc3RzLWZlYXR1cmUsb3JnLmVjbGlwc2UuZW1mLmNkby50ZXN0 cy1mZWF0dXJl
Y3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2Uu ZW1mLmNkby90
ZXN0cy9vcmcuZWNsaXBzZS5lbWYuY2RvLnRlc3RzLm1vZGVsMSxvcmcuZWNs aXBzZS5lbWYu
Y2RvLnRlc3RzLm1vZGVsMSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAs OmV4dHNzaDpk
ZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlwc2Uu ZW1mL29yZy5l
Y2xpcHNlLmVtZi5jZG8vdGVzdHMvb3JnLmVjbGlwc2UuZW1mLmNkby50ZXN0 cy5tb2RlbDEu
ZWRpdCxvcmcuZWNsaXBzZS5lbWYuY2RvLnRlc3RzLm1vZGVsMS5lZGl0Ii8+ DQo8cHJvamVj
dCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xpcHNlLm9yZzovY3Zz cm9vdC9tb2Rl
bGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2UuZW1mLmNkby90ZXN0 cy9vcmcuZWNs
aXBzZS5lbWYuY2RvLnRlc3RzLm1vZGVsMS5lZGl0b3Isb3JnLmVjbGlwc2Uu ZW1mLmNkby50
ZXN0cy5tb2RlbDEuZWRpdG9yIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEu MCw6ZXh0c3No
OmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBz ZS5lbWYvb3Jn
LmVjbGlwc2UuZW1mLmNkby9wbHVnaW5zL29yZy5lY2xpcHNlLmVtZi5jZG8u dWksb3JnLmVj
bGlwc2UuZW1mLmNkby51aSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAs OmV4dHNzaDpk
Y2xpcHNlLmVtZi5jZG8vcGx1Z2lucy9vcmcuZWNsaXBzZS5lbWYuY2RvLndl YXZlcixvcmcu
ZWNsaXBzZS5lbWYuY2RvLndlYXZlciIvPg0KPHByb2plY3QgcmVmZXJlbmNl PSIxLjAsOmV4
L29yZy5lY2xpcHNlLmVtZi5jZG8vcGx1Z2lucy9vcmcuZWNsaXBzZS5lbWYu Y2RvLndlYXZl
ci5hamR0LG9yZy5lY2xpcHNlLmVtZi5jZG8ud2VhdmVyLmFqZHQiLz4NCjxw cm9qZWN0IHJl
c2UuZW1mLmNkby53ZWF2ZXIudWksb3JnLmVjbGlwc2UuZW1mLmNkby53ZWF2 ZXIudWkiLz4N
CjwvcHJvdmlkZXI+DQo8L3BzZj4=
name="net4j.psf"
filename="net4j.psf"
L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlwc2UuZW1mL29yZy5lY2xpcHNl LmVtZi5uZXQ0
ai90ZXN0cy9vcmcuZWNsaXBzZS5hbnQub3B0aW9uYWwuanVuaXQsb3JnLmVj bGlwc2UuYW50
Lm9wdGlvbmFsLmp1bml0Ii8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6 ZXh0c3NoOmRl
di5lY2xpcHNlLm9yZzovY3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5l bWYvb3JnLmVj
bGlwc2UuZW1mLm5ldDRqL3BsdWdpbnMvb3JnLmVjbGlwc2UubmV0NGosb3Jn LmVjbGlwc2Uu
bmV0NGoiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpleHRzc2g6ZGV2 LmVjbGlwc2Uu
b3JnOi9jdnNyb290L21vZGVsaW5nLG9yZy5lY2xpcHNlLmVtZi9vcmcuZWNs aXBzZS5lbWYu
bmV0NGovcGx1Z2lucy9vcmcuZWNsaXBzZS5uZXQ0ai1mZWF0dXJlLG9yZy5l Y2xpcHNlLm5l
dDRqLWZlYXR1cmUiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpleHRz c2g6ZGV2LmVj
ZS5lbWYubmV0NGovcGx1Z2lucy9vcmcuZWNsaXBzZS5uZXQ0ai5kYixvcmcu ZWNsaXBzZS5u
ZXQ0ai5kYiIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpk ZXYuZWNsaXBz
ZS5vcmc6L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlwc2UuZW1mL29yZy5l Y2xpcHNlLmVt
Zi5uZXQ0ai9wbHVnaW5zL29yZy5lY2xpcHNlLm5ldDRqLmRiLWZlYXR1cmUs b3JnLmVjbGlw
c2UubmV0NGouZGItZmVhdHVyZSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIx LjAsOmV4dHNz
aDpkZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlw c2UuZW1mL29y
Zy5lY2xpcHNlLmVtZi5uZXQ0ai9wbHVnaW5zL29yZy5lY2xpcHNlLm5ldDRq LmRiLmRlcmJ5
LG9yZy5lY2xpcHNlLm5ldDRqLmRiLmRlcmJ5Ii8+DQo8cHJvamVjdCByZWZl cmVuY2U9IjEu
MCw6ZXh0c3NoOmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC9tb2RlbGluZyxv cmcuZWNsaXBz
ZS5lbWYvb3JnLmVjbGlwc2UuZW1mLm5ldDRqL3BsdWdpbnMvb3JnLmVjbGlw c2UubmV0NGou
ZGVidWcsb3JnLmVjbGlwc2UubmV0NGouZGVidWciLz4NCjxwcm9qZWN0IHJl ZmVyZW5jZT0i
MS4wLDpleHRzc2g6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290L21vZGVsaW5n LG9yZy5lY2xp
cHNlLmVtZi9vcmcuZWNsaXBzZS5lbWYubmV0NGovZG9jL29yZy5lY2xpcHNl Lm5ldDRqLmRv
YyxvcmcuZWNsaXBzZS5uZXQ0ai5kb2MiLz4NCjxwcm9qZWN0IHJlZmVyZW5j ZT0iMS4wLDpl
eHRzc2g6ZGV2LmVjbGlwc2Uub3JnOi9jdnNyb290L21vZGVsaW5nLG9yZy5l Y2xpcHNlLmVt
Zi9vcmcuZWNsaXBzZS5lbWYubmV0NGovZG9jL29yZy5lY2xpcHNlLm5ldDRq LmRvYy1mZWF0
dXJlLG9yZy5lY2xpcHNlLm5ldDRqLmRvYy1mZWF0dXJlIi8+DQo8cHJvamVj dCByZWZlcmVu
Y2U9IjEuMCw6ZXh0c3NoOmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC9tb2Rl bGluZyxvcmcu
ZWNsaXBzZS5lbWYvb3JnLmVjbGlwc2UuZW1mLm5ldDRqL2V4YW1wbGVzL29y Zy5lY2xpcHNl
Lm5ldDRqLmV4YW1wbGVzLWZlYXR1cmUsb3JnLmVjbGlwc2UubmV0NGouZXhh bXBsZXMtZmVh
dHVyZSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpkZXYu ZWNsaXBzZS5v
cmc6L2N2c3Jvb3QvbW9kZWxpbmcsb3JnLmVjbGlwc2UuZW1mL29yZy5lY2xp cHNlLmVtZi5u
ZXQ0ai9leGFtcGxlcy9vcmcuZWNsaXBzZS5uZXQ0ai5qbXMsb3JnLmVjbGlw c2UubmV0NGou
am1zIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5l Y2xpcHNlLm9y
ZzovY3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNsaXBzZS5lbWYvb3JnLmVjbGlw c2UuZW1mLm5l
dDRqL2V4YW1wbGVzL29yZy5lY2xpcHNlLm5ldDRqLmptcy5hZG1pbixvcmcu ZWNsaXBzZS5u
ZXQ0ai5qbXMuYWRtaW4iLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpl eHRzc2g6ZGV2
LmVjbGlwc2Uub3JnOi9jdnNyb290L21vZGVsaW5nLG9yZy5lY2xpcHNlLmVt Zi9vcmcuZWNs
aXBzZS5lbWYubmV0NGovZXhhbXBsZXMvb3JnLmVjbGlwc2UubmV0NGouam1z LmFwaSxvcmcu
ZWNsaXBzZS5uZXQ0ai5qbXMuYXBpIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9 IjEuMCw6ZXh0
c3NoOmRldi5lY2xpcHNlLm9yZzovY3Zzcm9vdC9tb2RlbGluZyxvcmcuZWNs aXBzZS5lbWYv
b3JnLmVjbGlwc2UuZW1mLm5ldDRqL2V4YW1wbGVzL29yZy5lY2xpcHNlLm5l dDRqLmptcy5z
ZXJ2ZXIsb3JnLmVjbGlwc2UubmV0NGouam1zLnNlcnZlciIvPg0KPHByb2pl Y3QgcmVmZXJl
LmVjbGlwc2UuZW1mL29yZy5lY2xpcHNlLmVtZi5uZXQ0ai9leGFtcGxlcy9v cmcuZWNsaXBz
ZS5uZXQ0ai5qbXMuc2VydmVyLmpkYmMsb3JnLmVjbGlwc2UubmV0NGouam1z LnNlcnZlci5q
ZGJjIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3NoOmRldi5l Y2xpcHNlLm9y
dDRqL3Rlc3RzL29yZy5lY2xpcHNlLm5ldDRqLmptcy50ZXN0cyxvcmcuZWNs aXBzZS5uZXQ0
ai5qbXMudGVzdHMiLz4NCjxwcm9qZWN0IHJlZmVyZW5jZT0iMS4wLDpleHRz c2g6ZGV2LmVj
ZS5lbWYubmV0NGovcGx1Z2lucy9vcmcuZWNsaXBzZS5uZXQ0ai5qdm0sb3Jn LmVjbGlwc2Uu
bmV0NGouanZtIi8+DQo8cHJvamVjdCByZWZlcmVuY2U9IjEuMCw6ZXh0c3No OmRldi5lY2xp
ZW1mLm5ldDRqL3BsdWdpbnMvb3JnLmVjbGlwc2UubmV0NGoudGNwLG9yZy5l Y2xpcHNlLm5l
dDRqLnRjcCIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpk ZXYuZWNsaXBz
Zi5uZXQ0ai90ZXN0cy9vcmcuZWNsaXBzZS5uZXQ0ai50ZXN0cyxvcmcuZWNs aXBzZS5uZXQ0
ai50ZXN0cyIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIxLjAsOmV4dHNzaDpk ZXYuZWNsaXBz
Zi5uZXQ0ai90ZXN0cy9vcmcuZWNsaXBzZS5uZXQ0ai50ZXN0cy1mZWF0dXJl LG9yZy5lY2xp
cHNlLm5ldDRqLnRlc3RzLWZlYXR1cmUiLz4NCjxwcm9qZWN0IHJlZmVyZW5j ZT0iMS4wLDpl
Zi9vcmcuZWNsaXBzZS5lbWYubmV0NGovcGx1Z2lucy9vcmcuZWNsaXBzZS5u ZXQ0ai51aSxv
cmcuZWNsaXBzZS5uZXQ0ai51aSIvPg0KPHByb2plY3QgcmVmZXJlbmNlPSIx LjAsOmV4dHNz
Zy5lY2xpcHNlLmVtZi5uZXQ0ai9wbHVnaW5zL29yZy5lY2xpcHNlLm5ldDRq LnVpLWZlYXR1
cmUsb3JnLmVjbGlwc2UubmV0NGoudWktZmVhdHVyZSIvPg0KPHByb2plY3Qg cmVmZXJlbmNl
PSIxLjAsOmV4dHNzaDpkZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3QvbW9kZWxp bmcsb3JnLmVj
bGlwc2UuZW1mL29yZy5lY2xpcHNlLmVtZi5uZXQ0ai9wbHVnaW5zL29yZy5l Y2xpcHNlLm5l
dDRqLnV0aWwsb3JnLmVjbGlwc2UubmV0NGoudXRpbCIvPg0KPHByb2plY3Qg cmVmZXJlbmNl
dDRqLnV0aWwudWksb3JnLmVjbGlwc2UubmV0NGoudXRpbC51aSIvPg0KPHBy b2plY3QgcmVm
ZXJlbmNlPSIxLjAsOmV4dHNzaDpkZXYuZWNsaXBzZS5vcmc6L2N2c3Jvb3Qv bW9kZWxpbmcs
b3JnLmVjbGlwc2UuZW1mL29yZy5lY2xpcHNlLmVtZi5uZXQ0ai90ZXN0cy9v cmcuZWNsaXBz
ZS50ZXN0LG9yZy5lY2xpcHNlLnRlc3QiLz4NCjwvcHJvdmlkZXI+DQo8L3Bz Zj4=
--------------010109020003060404020502--
Re: [CDO] Can't migrate ecore file in Eclipse 3.3 [message #608918 is a reply to message #91794] |
Mark,
Cheers
/Eike
> for EMF, etc.
> plugin.
> Mark.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Can't migrate ecore file in Eclipse 3.3 [message #609596 is a reply to message #95100] |
Mark schrieb:
> bump
What's this??
project.
Cheers
/Eike
name="cdo.psf"
filename="cdo.psf"
name="net4j.psf"
Cheers
/Eike
FUDForum. Page generated in 0.02458 seconds
