Home » Modeling » Epsilon » One model + EGL; multiple targets
One model + EGL; multiple targets [message #8255] |
Thu, 08 January 2009 18:07 |
No real name Messages: 92 Registered: July 2009 |
Member |
Hia there,
I was wondering whether anyone has any suggestions for my following
problem. Given a model (from someone else) that can contain an arbitrary
number of instances of the same meta class (e.g., x1, x2 and x3 are in the
model, and are instances of meta class X), I would like to print values
based on each of these instances (which I can find in the model), to
separate files -- for example, to x1.txt, x2.txt and x3.txt.
Since text needs to be printed, EGL seemed the sensible choice. The
difficulty I have is how to use EGL, when one model has been loaded, to
print to several target files... Do you know if this is possible, or
indeed, whether this approach is sensible? Any help would be very much
appreciated.
Thanks!
Re: One model + EGL; multiple targets [message #8288 is a reply to message #8255] |
Thu, 08 January 2009 18:23 |
Dimitrios Kolovos Messages: 1776 Registered: July 2009 |
Hi Edd,
This is feasible. In the following example when the driver.egl template
is executed it calls delegate.egl 10 times, each time with a different
value for parameter foo, and consequently generates 10 txt files.
driver.egl:
for (i in Sequence{1..10}) {
var delegate : Template;
-- Pass parameters to the template
delegate := TemplateFactory.load('delegate.egl');
delegate.populate('foo', i);
delegate.store(i+'.txt', true);
delegate.egl:
[%=foo%]
A more complete example is available in
http://dev.eclipse.org/viewsvn/index.cgi/trunk/examples/org. eclipse.epsilon.examples.egldoc/?root=Modeling_EPSILON
where EGL is used to transform an ECore model into javadoc-like HTML.
Dimitris
Edward Turner wrote:
> Hia there,
> the model, and are instances of meta class X), I would like to print
> values based on each of these instances (which I can find in the model),
> to separate files -- for example, to x1.txt, x2.txt and x3.txt.
> appreciated.
> Thanks!
Re: One model + EGL; multiple targets [message #8320 is a reply to message #8288] |
Fri, 09 January 2009 14:42 |
Member |
Ahh great -- thanks Dimitris.
Sorry, I hadn't seen the documentation for this (I'd mainly been looking
in the Epsilon book). For anyone else, and a reminder to me, there's handy
info at:
http://www.springerlink.com/index/h182m536v0471545.pdf
http://www.eclipse.org/gmt/epsilon/cinema/EglVariables.htm
(look out for TemplateFactory)
Also, something I wasn't 100% sure about, but which was confirmed through
a little test. (This seems obvious now, but will say anyway)... Given
something like:
driver.egl:
var t : Template := TemplateFactory.load('x.egl');
t.populate('obj', SomeObject);
In x.egl: one can refer to the SomeObject object via the parameter
reference obj, and it can reach any other object associated with
SomeObject, by navigating the various associations from obj.
Ta,
Edd
Dimitrios Kolovos wrote:
> Hi Edd,
> driver.egl:
> delegate.egl:
> [%=foo%]
> Cheers,
> Dimitris
>> Hia there,
>> appreciated.
>> Thanks!
Re: One model + EGL; multiple targets [message #8352 is a reply to message #8320] |
Fri, 09 January 2009 15:24 |
Hi Edd,
Glad this helped! I was planning to fill in the EGL section of the book
but at some point it slipped my mind. I'll do that shortly.
Dimitris
> handy info at:
> through a little test. (This seems obvious now, but will say anyway)...
> Given something like:
> driver.egl:
> Ta,
> Edd
>> Hi Edd,
>> template is executed it calls delegate.egl 10 times, each time with a
>> different value for parameter foo, and consequently generates 10 txt
>> files.
>> driver.egl:
>> delegate.egl:
>> [%=foo%]
>> Cheers,
>> Dimitris
>>> Hia there,
>>> arbitrary number of instances of the same meta class (e.g., x1, x2
>>> and x3 are in the model, and are instances of meta class X), I would
>>> like to print values based on each of these instances (which I can
>>> find in the model), to separate files -- for example, to x1.txt,
>>> x2.txt and x3.txt.
>>> to print to several target files... Do you know if this is possible,
>>> or indeed, whether this approach is sensible? Any help would be very
>>> much appreciated.
>>> Thanks!
Re: One model + EGL; multiple targets [message #8442 is a reply to message #8412] |
Fri, 09 January 2009 18:10 |
Hi Edd,
I (think) I've fixed it. Please update the org.eclipse.epsilon.workflow
project to pick up the fix.
Dimitris
> Hi Edd,
> It seems to be a bug indeed. Could you please file a bug report? I'll
> look into it tomorrow morning.
> Dimitris
>> Just a quick follow up q,
>> Given a driver egl script, such as the one you defined, when running
>> this via an Ant task (and not a launch configuration) it leads to the
>> error:
>> [Driver.egl] Internal error: java.lang.IllegalArgumentException: URI
>> is not absolute
>> [Driver.egl] at java.net.URI.toURL[URI.java:1080]
>> [Driver.egl] at
>> org.eclipse.epsilon.egl.EglModule.parse[EglModule.java:97]
>> [Driver.egl] at
>> org.eclipse.epsilon.egl.types.EglTemplate.<init>[EglTemplate.java:48]
>> [Driver.egl] at
>> org.eclipse.epsilon.egl.types.EglFileGeneratingTemplate.<init >[EglFileGeneratingTemplate.java:50]
>> [Driver.egl] at
>> org.eclipse.epsilon.egl.template.FileGeneratingTemplateFacto ry.load[FileGeneratingTemplateFactory.java:51]
>> . when the Ant task is as follows:
>> <epsilon.egl src="Driver.egl">
>> <model ref="X"/>
>> </epsilon.egl>
>> (and I've tried adding a target attribute to the epsilon.egl task,
>> even though I don't really want to specify the target here -- it is
>> determined by the egl script. Either way, I got the error).
>> I was wondering whether this was because of some conflict when
>> internally setting the target files for the egl?? If this is a bug I
>> can submit a report.
>> Ta again,
>> Edd
Re: One model + EGL; multiple targets [message #8472 is a reply to message #8442] |
Mon, 12 January 2009 13:09 |
Member |
Hi Dimitris,
Yes, that's great -- all seems fine and dandy now! (and I've submitted a
bug report so it's recorded)
Ta,
Edd
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> Dimitris
>>> error:
>>> is not absolute
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> <model ref="X"/>
>>> </epsilon.egl>
>>> Ta again,
>>> Edd
Re: One model + EGL; multiple targets [message #8502 is a reply to message #8472] |
Mon, 12 January 2009 13:11 |
Great! Just for the record the related bug is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=260702
Dimitris
> Hi Dimitris,
> Ta,
> Edd
>> Hi Edd,
>> org.eclipse.epsilon.workflow project to pick up the fix.
>> Cheers,
>> Dimitris
>>> Hi Edd,
>>> Dimitris
>>>> the error:
>>>> URI is not absolute
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> <model ref="X"/>
>>>> </epsilon.egl>
>>>> Ta again,
>>>> Edd
Re: One model + EGL; multiple targets [message #563646 is a reply to message #8255] |
Hi Edd,
driver.egl:
delegate.egl:
[%=foo%]
Dimitris
> Hia there,
> appreciated.
> Thanks!
Re: One model + EGL; multiple targets [message #563667 is a reply to message #8288] |
Member |
info at:
something like:
driver.egl:
Ta,
Edd
> Hi Edd,
> driver.egl:
> delegate.egl:
> [%=foo%]
> Cheers,
> Dimitris
>> Hia there,
>> appreciated.
>> Thanks!
Re: One model + EGL; multiple targets [message #563691 is a reply to message #8320] |
Hi Edd,
Dimitris
> handy info at:
> driver.egl:
> Ta,
> Edd
>> Hi Edd,
>> files.
>> driver.egl:
>> delegate.egl:
>> [%=foo%]
>> Cheers,
>> Dimitris
>>> Hia there,
>>> x2.txt and x3.txt.
>>> much appreciated.
>>> Thanks!
Re: One model + EGL; multiple targets [message #563749 is a reply to message #8412] |
Hi Edd,
Dimitris
> Hi Edd,
> Dimitris
>> error:
>> is not absolute
>> [Driver.egl] at
>> [Driver.egl] at
>> [Driver.egl] at
>> [Driver.egl] at
>> <model ref="X"/>
>> </epsilon.egl>
>> Ta again,
>> Edd
Re: One model + EGL; multiple targets [message #563757 is a reply to message #8442] |
Member |
Hi Dimitris,
Ta,
Edd
> Hi Edd,
> Cheers,
> Dimitris
>> Hi Edd,
>> Dimitris
>>> error:
>>> is not absolute
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> [Driver.egl] at
>>> <model ref="X"/>
>>> </epsilon.egl>
>>> Ta again,
>>> Edd
Re: One model + EGL; multiple targets [message #563780 is a reply to message #8472] |
Dimitris
> Hi Dimitris,
> Ta,
> Edd
>> Hi Edd,
>> Cheers,
>> Dimitris
>>> Hi Edd,
>>> Dimitris
>>>> the error:
>>>> URI is not absolute
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> [Driver.egl] at
>>>> <model ref="X"/>
>>>> </epsilon.egl>
>>>> Ta again,
>>>> Edd
Current Time: Thu Apr 25 21:05:52 GMT 2024
Powered by FUDForum. Page generated in 0.04503 seconds
