Home » Archived » Visual Editor (VE) » IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated
IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90041] Sun, 08 May 2005 00:55 Go to next message
Originally posted by: no.ddress.here
Installed VE with the correct dependencies for 3.1M6. When I use the
Visual Class wizard, I get a frame which looks correct.
However, if I click on the content pane, the properties view shows a
"debugGraphicsOptions" property with the value "IWAV0104E ERROR - Value
not one of the enumerated values"
Visual composition does not work: dropping a button on the content pane
looks correct and a getJButton() method is created, but VE does not
generate the expected linking code (jContentPane.add(getJButton() ... ))
in getContentPane() method.
Cleaning the workspace does not help. Switching to a completely new and
empty workspace *does* enable VE to work as expected. I have too much
good stuff in my current workspace to manually transfer the projects.
Any clues as to the problem and a (practical) way to fix up my existing
workspace?
!SESSION 2005-05-07 21:24:33.157
eclipse.buildId=I20050401-1645
java.version=1.5.0
Command-line arguments: -os win32 -ws win32 -arch x86 -clean -data D:
\DevFiles\EclipseWorkSpace31M6
!ENTRY org.eclipse.jem.proxy 2 0 2005-05-07 21:24:33.157
!MESSAGE java.lang.RuntimeException
at org.eclipse.jem.internal.proxy.initParser.Static.evaluate
(Static.java:123)
org.eclipse.jem.internal.proxy.initParser.InitializationStri ngParser.eva
luate(InitializationStringParser.java:157)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un
(ConnectionHandler.java:236)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n
(ConnectionThread.java:47)
!ENTRY org.eclipse.ve.java.core 2 0 2005-05-07 21:24:33.167
!MESSAGE
+++ Warning +++: Sat May 07 21:24:33 PDT 2005 Unable to create
enumeration value for DebugGraphics.NONE_OPTION
!MESSAGE Exception thrown.
!STACK 0
java.lang.InstantiationException: IWAV0125E "DebugGraphics.NONE_OPTION"
is too complicated to be evaluated
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.create
BeanProxy(REMStandardBeanProxyFactory.java:262)
org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstan
ce(REMAbstractBeanTypeProxy.java:536)
org.eclipse.jem.internal.proxy.remote.REMIntegerTypeBeanType Proxy.newIns
tance(REMIntegerTypeBeanTypeProxy.java:103)
org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tEnumeratedV
alues(EnumeratedLabelProvider.java:51)
org.eclipse.ve.internal.java.core.EnumeratedLabelProvider.ge tText
(EnumeratedLabelProvider.java:90)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValu
eAsString(AbstractPropertySheetEntry.java:722)
at org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try
(PropertySheetViewer.java:1220)
at org.eclipse.ui.views.properties.PropertySheetViewer.createIt em
(PropertySheetViewer.java:359)
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf
(PropertySheetViewer.java:1177)
at org.eclipse.ui.views.properties.PropertySheetViewer.access$2
(PropertySheetViewer.java:1101)
$3.childEntriesChanged(PropertySheetViewer.java:308)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChi
ldEntriesChanged(AbstractPropertySheetEntry.java:373)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refresh
ChildEntries(AbstractPropertySheetEntry.java:831)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValu
es(AbstractPropertySheetEntry.java:1013)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput
(PropertySheetViewer.java:875)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged
(PropertySheetPage.java:392)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelec
tionChanged(EToolsPropertySheetPage.java:230)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2
(EToolsPropertySheetPage.java:223)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e
$1.run(EToolsPropertySheetPage.java:216)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages
(Synchronizer.java:118)
at org.eclipse.swt.widgets.Display.runAsyncMessages
(Display.java:2871)
at org.eclipse.swt.widgets.Display.readAndDispatch
(Display.java:2530)
at org.eclipse.ui.internal.Workbench.runEventLoop
(Workbench.java:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench
(Workbench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench
(PlatformUI.java:143)
at org.eclipse.ui.internal.ide.IDEApplication.run
(IDEApplication.java:103)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run
(PlatformActivator.java:228)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run
(EclipseStarter.java:344)
(EclipseStarter.java:156)
at sun.reflect.NativeMethodAccessorImpl.invoke
(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90075 is a reply to message #90041] Sun, 08 May 2005 12:37 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Found part of your problem. You have dt.jar in your classpath somewhere.
This is Sun's version of the Swing beaninfo, and it conflicts with ours,
but there is no way to override theirs. You don't need it, it has
nothing but beaninfo stuff in it.
That cause the problem with the debugGraphicsOption. After you remove
the jar you will need to do a clean all projects build because we need
to clear out some cached info.
Rich Kulp
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90104 is a reply to message #90075] Sun, 08 May 2005 15:00 Go to previous messageGo to next message
In article <d5lfll$pf0$1@news.eclipse.org>, richkulp@us.NO_SPAM.ibm.com
says...
Great catch! Did have the dt.jar in for the legacy reason that it
contains the SwingBeanInfo.class (but, it has been dropped as of Java 5,
so I had pulled the class out anyway - just did not think to remove the
jar).
Everything is now working as expected.
Thanks again.
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #90118 is a reply to message #90104] Sun, 08 May 2005 15:22 Go to previous message
Actually I'm glad you came up with this problem! A few weeks ago I was
tearing my hair out working with another person getting a similar error.
But I couldn't track it down. In her case it was a property that we had
supplied an enumeration for and I couldn't see how our BeanInfo could
come up bad like that.
Your case was the key to finding the problem because for you it was
debugGraphicsOption. We don't even provide an enumeration for that
property! So that clued me in to there being another BeanInfo and I was
able to track it down to dt.jar then. Thanks!
> says...
> jar).
> Thanks again.
Rich Kulp
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607361 is a reply to message #90041] Sun, 08 May 2005 12:37 Go to previous message
Rich Kulp
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607363 is a reply to message #90075] Sun, 08 May 2005 15:00 Go to previous message
says...
jar).
Thanks again.
Re: IWAV0125E "DebugGraphics.NONE_OPTION" is too complicated [message #607364 is a reply to message #90104] Sun, 08 May 2005 15:22 Go to previous message
> says...
> jar).
> Thanks again.
Rich Kulp
Previous Topic:Edit policy
Next Topic:Clarifications on using BeanInfo customizers?
Current Time: Tue Jun 24 22:49:38 EDT 2025
Powered by FUDForum. Page generated in 1.11147 seconds
