Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Not able to install successfully
[AGR] Not able to install successfully [message #88503] Wed, 22 November 2006 15:29 Go to next message
Originally posted by: praveeng.adobe.com
After installing the eclipse and TPTP by following the steps below:
Follow the steps below to create a TPTP's automated GUI test suite:
1.. Automated GUI test suites must be stored in a plug-in project in order
for required plug-ins of verification hooks to be resolved (section 2.3
provides more details). Create an Eclipse plug-in: File Menu > New > Project
> Plug-in Development > Plug-in Project > Next.
2.. Specify 'TestContainer' as the Project name > Next > Make sure the
option 'This plug-in will make contributions to the UI' is checked' > Next >
Uncheck the option 'Create a plug-in using one of the templates' > Finish.
3.. Create a new folder that will contain the test suite: Right Click the
Project > New > Folder > Specify 'test-resources' as the name of the folder
> Finish.
4.. Create a new package under the source directory: Right Click the 'src'
Directory > New > Package > Specify 'org.eclipse.tests.verification.hooks'
as the name of the package > Finish.
5.. Create the automated test suite: File Menu > New > Other > Test >
Select TPTP Automated GUI Test (see figure 2.1) > Next. The first wizard
page will allow you to specify the location of the class that will contain
methods corresponding to each inserted verification hook.
------------------------------------------------------------ ------------------------------------------------------------ --------I am not able to see "Test" in the list of Wizards as described in thelinkhttp://www.eclipse.org/tptp/test/documents/userguides /Intro-Auto-GUI.htmlsection 2.0.Any help will be much appreciated.Thanks,Praveen.
Re: [AGR] Not able to install successfully [message #88625 is a reply to message #88503] Thu, 23 November 2006 10:52 Go to previous message
You probably don't have the right combination of drivers and dependencies.
Here's what you need from
http://www.eclipse.org/tptp/home/downloads/downloads.php:
1) Download All - Runtime under "TPTP Runtime and SDK"
2) Download AGR under "Technology Preview" "Automated GUI Recording"
3) Download "Eclipse SDK 3.2.1" and "Eclipse Modeling Framework (EMF and
XSD) SDK" under "Requirements"
see
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-2-0.html#1.1
for more details.
Ali Mehregani
"Praveen Gupta" <praveeng@adobe.com> wrote in message
news:ek2buj$f76$1@utils.eclipse.org...
> order
> Project
> folder
> > Finish.
> 'src'
Previous Topic:Not able to see "Test" in the list of Wizards
Next Topic:[AGR] Information on the Object Mine?
Current Time: Tue Jul 22 15:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.08386 seconds
