Home » Modeling » GMF (Graphical Modeling Framework) » Strange error: GMF duplicates elements
Strange error: GMF duplicates elements [message #87664] Tue, 26 December 2006 06:08
Originally posted by: mricardo.ef.pt
Hi everybody,
I'm struggling to find the source of an error that keeps stubornly
apperaring. At least I know the cause of it :).
The problem is the following:
-- If you see figure1, I have created two field objects with the SAME
id. When I close eclipse and save the diagram, and
restart it again, another field of the same type is created and with
the same Id (that explains the three field objects in figure 1)
And this is the strange error that keeps existing.
-- If you check figure2 (which is a print screen of the resource set)
you can see that correctly shows the existence of only two fields,
even though in the diagram appears three.
-- And this goes on, each time I start eclipse, one additional field
gets created, with the same Id.
-- This ONLY happens when I put the same Id in any object that I create
in the diagram.
-- And yes, I want to be able to place the same id.
Any thoughts why does this happen? I've debugged the application, but I
don't seem to get the root of the error.
I appreciate any help.
Miguel Ricardo
EF - Tecnologias de Informa
  • Attachment: figure1.gif
    (Size: 3.30KB, Downloaded 120 times)
  • Attachment: figure2.gif
    (Size: 10.55KB, Downloaded 96 times)
Previous Topic:Connection Handlers
Next Topic:Is it possible to use GMF without underlying model implemented EMF-model?
Current Time: Tue Jul 22 15:42:18 EDT 2025
Powered by FUDForum. Page generated in 0.06649 seconds
