Home » Archived » M2M (model-to-model transformation) » How do I use both AMW and UML2 modelHandlers?
How do I use both AMW and UML2 modelHandlers? [message #87067] Thu, 24 July 2008 08:06 Go to next message
Originally posted by: sebastien.minguet.gmail.com
Hi everybody,
I am currently working on a transformation and I have a problem with the
modelHandlers
My Transfo takes 5 models as input
A UML2 model
B UML2 profile
C KDM model which previously served as a basis for creation of A
D TRACE model referencing transformation links between A and C
E IKDM model (woven model) containing various links between C elements
and as output a UML2 model O which is an enriched version of A
What I want to do is basically
- copy A in O
- browse E
for every link create a UML Dependency in O
for every element of C referenced by the link, find the matching
element in A using D and set it
as the client/supplier of the dependency
- Apply B on O, and apply stereotypes on the created dependencies
In my launcher modelHanlder are set like this
KDM -> EMF
TRACE -> AMW
WEAVING -> AMW
If I set UML2 with UML2 modelHandler I get an exception
GRAVE: ****** BEGIN Stack Trace
GRAVE: exception:
GRAVE: null
java.lang.reflect.InvocationTargetException
at sun.reflect.GeneratedMethodAccessor72.invoke(Unknown Source)
org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:69)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:143)
org.eclipse.m2m.atl.drivers.emf4atl.ASMEMFModelElement.invok e(ASMEMFModelElement.java:683)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:240)
org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:338)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:171)
org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:101)
org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:299)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:169)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:111)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:87)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:326)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
Caused by: java.lang.ClassCastException:
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModel cannot be cast to
org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getWovenAS MModel(ASMAMWModelElement.java:116)
org.eclipse.gmt.weaver.amw4atl.ASMAMWModelElement.getReferre dElement(ASMAMWModelElement.java:192)
... 35 more
And If set UML2 modelHandler to EMF, it works fine as long as I don't use
applyProfile and appyStereotype
because I get a method not found exception. The problem is I need to use
them :)
Does anyone have an idea? I should probably divide transformation in 2 but
that would mean another copy of the UML model and using the trace model of
the first transformation.
Thanks in advance
Re: How do I use both AMW and UML2 modelHandlers? [message #87147 is a reply to message #87067] Fri, 25 July 2008 10:28 Go to previous messageGo to next message
Originally posted by: Hugo.Bruneliere.univ-nantes.fr
Hi Sebastien,
Sebastien Minguet a écrit :
> Hi everybody,
> modelHandlers
> A UML2 model
> B UML2 profile
> - copy A in O
> - browse E for every link create a UML Dependency in O
> matching element in A using D and set it as the
> KDM -> EMF
> TRACE -> AMW
> WEAVING -> AMW
> GRAVE: exception: GRAVE: null
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> at
> at
> ... 35 more
> use applyProfile and appyStereotype
> them :)
> but that would mean another copy of the UML model and using the trace
> model of the first transformation.
The problem comes from the fact that the current version of the UML
model handler plugin doesn't properly extend the EMF model handler
plugin. It extends directly, like the EMF model handler plugin, the ASM
abstract model handler provided within ATL.
In order for the UML model handler plugin to be compatible with the AMW
model handler, it should be fully implemented by extension of the EMF
model handler plugin:
- The "AtlUML2ModelHandler" class should extend the
"AtlEMFModelHandler" class;
- The "ASMUMLModel" class should extend the "ASMEMFModel" class;
- The "ASMUMLModelElement" class should extend the
"ASMEMFModelElement" class.
It is realizable because most of the code coming from the UML model
handler plugin seems to have been copied from the EMF model handler plugin.
Does anyone intensively using UML2 already perform such an upgrade of
the UML model handler, or is ready to do so?
Hugo
> Thanks in advance
Hugo Bruneliere - R&D Engineer
AtlanMod (INRIA & EMN)
University of Nantes
2, rue de la Houssiniere
44322 Nantes Cedex 3 - France
office +33 2 51 12 58 10 /\ cell.+33 6 07 42 45 30
EMail: hugo.bruneliere@inria.fr
http://www.sciences.univ-nantes.fr/lina/atl/
Re: How do I use both AMW and UML2 modelHandlers? [message #87162 is a reply to message #87147] Mon, 28 July 2008 08:35 Go to previous message
OK Thanks, at least I now know why it does not work. From what I've read
so far, UML2 model handler was created because profile application could
not be handled by EMF (http://wiki.eclipse.org/ATL_Model_Handlers). I
guess this means that there is no way to replace calls to function
applyProfile or applyStereotype by ATL UML2ModelHandler-independant code?
Previous Topic:[ATL] error transformation due to references to UML2
Next Topic:[ATL, XML] Transformation to xml: values between start- and end-tag
Current Time: Tue Jul 22 15:30:22 EDT 2025
Powered by FUDForum. Page generated in 0.03072 seconds
