Home » Modeling » EMF » [Teneo] Turn off some logging?
[Teneo] Turn off some logging? [message #765041] Tue, 13 December 2011 05:05 Go to next message
I could not find in the documentation the switch that reduces the amount
of logging Teneo puts out. I have several plugins using Teneo and seeing
my teneo settings output for each one is clogging up the log. How do I
turn off those main:HbDataStore - .... log messages?
Thx.
David
Re: [Teneo] Turn off some logging? [message #765052 is a reply to message #765041] Tue, 13 December 2011 05:23 Go to previous messageGo to next message
Hi David,
I could not find it either, maybe this helps:
http://wiki.eclipse.org/CDO/Hibernate_Store/Configuration_and_Setup#How_to_enable_Hibernate_logging
Teneo uses commons logging, it has been a very long time I looked at it... Is log4j also being used? You can find out
how log4j is configured by adding a jvm arg: -Dlog4j.debug
gr. Martin
On 12/13/2011 11:05 AM, David Wynter wrote:
> I could not find in the documentation the switch that reduces the amount of logging Teneo puts out. I have several
> plugins using Teneo and seeing my teneo settings output for each one is clogging up the log. How do I turn off those
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Turn off some logging? [message #765068 is a reply to message #765052] Tue, 13 December 2011 05:59 Go to previous messageGo to next message
Thx.
I have <property name="hibernate.show_sql" value="false"/> already. I
think I must have had that switch confused with another non existent
switch you used to turn off some debug. If it is log4j only then I just
need to work out where the important messages out of teneo are and
exclude the rest, or settle for ERROR level.
David
On 13/12/11 10:23, Martin Taal wrote:
> Hi David,
> it... Is log4j also being used? You can find out how log4j is configured
> gr. Martin
>> Thx.
>> David
Re: [Teneo] Turn off some logging? [message #1398728 is a reply to message #765068] Fri, 11 July 2014 09:46 Go to previous message
I'm facing with the same problem and I cannot get a solution. I cannot manipulate the console logging, I use the standard logging of the teneo hibernate. So I dont have a log4j.properties file. How can I overwrite the teneo's property file? How can I rid of the log messages? What should I do?
Andrew
Previous Topic:What happens to a "loaded resource" when the Ecore editor is closed?
Next Topic:[XCORE] How To Design Question: How to model extensible single instances
Current Time: Sat Apr 19 21:35:48 EDT 2025
Powered by FUDForum. Page generated in 0.04581 seconds
