Home » Eclipse Projects » GEF » Refreshing from EditPart
Refreshing from EditPart [message #85040] Tue, 24 June 2003 18:31 Go to next message
Originally posted by: ar9357.sbc.com
is it possible to refresh view from EditPart.
with respect to logic example, how do i refresh the view.
thanks for any feedback or information on this.
Re: Refreshing from EditPart [message #85057 is a reply to message #85040] Tue, 24 June 2003 19:52 Go to previous messageGo to next message
In the logic example, edit parts listen to their model with a
PropertyChangeListener. refreshVisuals() is called from the propertyChange()
method and the view is refreshed in refreshVisuals().
Re: Refreshing from EditPart [message #85248 is a reply to message #85057] Wed, 25 June 2003 11:01 Go to previous messageGo to next message
Iam able to change the model and figure as you described.
But the image/label is overlapping with or without overriding
propertyChange method.
propertyChange()
Re: Refreshing from EditPart [message #85277 is a reply to message #85248] Wed, 25 June 2003 11:19 Go to previous messageGo to next message
What do you mean by "overlapping"?
> propertyChange()
Re: Refreshing from EditPart [message #85306 is a reply to message #85277] Wed, 25 June 2003 11:44 Go to previous messageGo to next message
Initially i have set figure with new Label("initial name").
Iam changing both figure and model dynammically by calling
figure.setImage(new Label("display name"))
model.setName("newname")
when i do this figure is getting set with "new name" but the "initial
name" retaining as it is.
or is it just enough to change the model and fire event programatically to
refresh the visuals.
> > propertyChange()
Re: Refreshing from EditPart [message #85337 is a reply to message #85306] Wed, 25 June 2003 11:49 Go to previous messageGo to next message
"Anil" <ar9357@sbc.com> wrote in message news:bdcg01$bad$1@rogue.oti.com...
Always change only the model, and the figure will be refreshed to reflect
the model's contents.
This point is stressed in an upcoming article on getting started with GEF.
> > > propertyChange()
Re: Refreshing from EditPart [message #85347 is a reply to message #85337] Wed, 25 June 2003 11:59 Go to previous messageGo to next message
yes i did get a reference to the model in EditPart and modified the same.
In order to reflect the changes i have overridden method called
propertyChange which calls refreshVisuals, but the view/figure is not
getting updated.
pls let me know whether the step followed are correct or not.
Randy Hudson wrote:
> \"Anil\" <ar9357@sbc.com> wrote in message news:bdcg01$bad$1@rogue.oti.com...
> > Initially i have set figure with new Label(\"initial name\").
> > figure.setImage(new Label(\"display name\"))
> > model.setName(\"newname\")
> > when i do this figure is getting set with \"new name\" but the \"initial
> > name\" retaining as it is.
> the model\'s contents.
> > Eric Bordeau wrote:
> > > What do you mean by \"overlapping\"?
> > > > propertyChange()
Re: Refreshing from EditPart [message #85362 is a reply to message #85347] Wed, 25 June 2003 12:14 Go to previous message
You shouldn't edit your model in your edit parts. You should generate commands
via edit policies and execute the commands on the command stack. The commands
will modify the model and then your model should notify listeners of a property
change event. When propertyChange() is called, call refreshVisuals().
> getting updated.
>>>>>propertyChange()
Previous Topic:rounded connections
Next Topic:Automatic Tests for Graphical Editors
Current Time: Fri Nov 07 13:21:25 EST 2025
Powered by FUDForum. Page generated in 0.04584 seconds
