Re: [Transaction] Redo(Undo)ActionWrapper memory leak? [message #84512 is a reply to message #84425] |
Tue, 22 May 2007 15:11  |
--------------030905090503040608080001
Grzegorz,
The generated editors do this in their dispose, which should cause the
EditingDomainActionBarContributor to call deactivate().
if (getActionBarContributor().getActiveEditor() == this)
getActionBarContributor().setActiveEditor(null);
I'm not sure I understand exactly what you think the dispose method
should do for the EditingDomainActionBarContributor, but if you explain,
what you think is needed and why, it might be something we could add.
Also, please use the EMF newsgroup for asking about transaction now that
this component has graduated from EMFT and moved to EMF. (I've added it
to the "to" list.)
Grzegorz Bia
Re: [Transaction] Redo(Undo)ActionWrapper memory leak? [message #606765 is a reply to message #84425] |
Ed Merks Messages: 31703 Registered: July 2009 |
Grzegorz,
to the "to" list.)
Grzegorz Bia
Ed Merks
FUDForum. Page generated in 0.01702 seconds
