Re: What is the best way to diagnose an Eclipse instance from an external java/eclipse application. [message #84227 is a reply to message #84160] |
Fri, 16 March 2007 15:43 |
Pascal Rapicault Messages: 333 Registered: July 2009 Location: Ottawa |
If you know where the plugins are located on disk and you have access to the
config.ini, you could determine which version of osgi you deal with, load it
as a regular jar (not running it) and use the state reader from here.
Now that I have stepped back from the details of your questions, it seems to
me that you would really want to take a close look at the work that Ikuo has
been doing on the org.eclipse.equinox.frameworkadmin API / service
(http://wiki.eclipse.org/index.php/Equinox_FrameworkAdmin) and maybe extend
/ fix this to do what I was describing above. Also note that even though
this is a service it can be used in a non-osgi based java program
( http://wiki.eclipse.org/index.php/Using_FrameworkAdmin_from_ Java_programs).
PaScaL
"Christophe Elek" <Christophe.Elek@gmail.com> wrote in message
news:Xns98F4E7D6AE0C9celekcaibmcom@206.191.52.34...
> "Pascal Rapicault" <pascal_rapicault@ca.ibm.com> wrote in
> news:etcc3j$ivl$1
> @utils.eclipse.org:
>> the problem with option 2 and 3 are that it
> you missed th erest of the sentence :)
> Aaron,
> Case number #1 (i do not like it but..)
> We start using osgi 3.3, if this fails we send a return code to our
> luncher
> nad we try with osgi 3.2
> case #2 (not sure if this will work)
> When we know the location of the eclipse we want to diagnose, we somhow
> launch an RCP using the OSGI of that location
> This is also your case #2, now Pascal could help us understand how easy or
> not it is to generate a config.ini on the fly, pointing to the bundle we
> bring as well as the OSGI bundle of the target eclipse, yet preventing
> disturbing the eclipse we are debugging..
> Christophe Elek
> Serviceability Architect
> IBM Software Group - Rational
Re: What is the best way to diagnose an Eclipse instance from an external java/eclipse application. [message #84257 is a reply to message #84227] |
Fri, 16 March 2007 20:21 |
Christophe Elek Messages: 21 Registered: July 2009 |
Junior Member |
news:etedvr$ih1$1@utils.eclipse.org:
> to the config.ini, you could determine which version of osgi you deal
> with, load it as a regular jar (not running it) and use the state
> reader from here.
Oh, gotcha, we find the osgi jar, load it using our file classloader and
use the API on the jar... k, we'll try that
> seems to me that you would really want to take a close look at the
> work that Ikuo has been doing on the
Ok, we will look at that too, thanks ... :)
Christophe Elek
FUDForum. Page generated in 0.02759 seconds
