Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] eContainer has not been saved?
Re: [Teneo] eContainer has not been saved? [message #83936 is a reply to message #83921] |
Fri, 18 May 2007 09:38   |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Anthony,
Was the eContainer null in the object after the save? Where/how was it set to null (you can set a
breakpoint to check out who then nullifies the eContainer)?
Which object was in which resource, was the child in resource 1 and the parent in resource 2, or
both in the same resource?
gr. Martin
Anthony wrote:
> I had some many-To-one eobject to save,
> before executing HibernateResource's mySession.saveOrUpdate(obj)
> I saw the eContainer is correct.
> No exception was thrown, but in Mysql DB, the eContainer was null.
> The container was init by other resource than the resource init the
> contained object.
> Is it the reason?
> Anthony
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] eContainer has not been saved? [message #83949 is a reply to message #83936] |
Fri, 18 May 2007 10:14   |
Anthony Lee Messages: 114 Registered: July 2009 |
Martin,
I add preFlush() and postFlush in my Interceptor, I could see that all
the eContainer is correct before flush and after flush. It is not set
null at all. But the field present eContainer is null.
The parent is load in resource 1 , and the child is load in resource
2.
Thanks.
Anthony
> Hi Anthony,
> set to null (you can set a breakpoint to check out who then nullifies
> the eContainer)? Which object was in which resource, was the child in
> resource 1 and the parent in resource 2, or both in the same resource?
> gr. Martin
> Anthony wrote:
>> the
>> contained object.
>> Is it the reason?
>> Anthony
Re: [Teneo] eContainer has not been saved? [message #83964 is a reply to message #83949] |
Fri, 18 May 2007 10:22   |
But the field in DB present eContainer is null.
Anthony
> Martin,
all
> 2.
> Thanks.
> Anthony
>> Hi Anthony,
it
resource?
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> the
>>> contained object.
>>> Is it the reason?
>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #83979 is a reply to message #83949] |
Fri, 18 May 2007 14:04   |
Anthony,
So before the save eContainer is not null and after the save it is null?
Did you set a breakpoint in the eBasicSetContainer method?
gr. Martin
Anthony wrote:
> Martin,
> 2.
> Thanks.
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> the
>>> contained object.
>>> Is it the reason?
>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #83994 is a reply to message #83979] |
Fri, 18 May 2007 14:16   |
Martin,
No. It is not null before and after the saving.
Just it is not set in DB.
I think that's related to Hibernate .
I have another question to ask:
As I need to adapt to db2 tables ,
I have to write the mapping file .
I want to know if below meta arrtibutes must be inside the class ?
<meta attribute="eclassName">Customer</meta>
<meta attribute="epackage">http:///sndmodel.ecore</meta>
Best regard,
Anthony
> Anthony,
> null? Did you set a breakpoint in the eBasicSetContainer method?
> gr. Martin
> Anthony wrote:
>> Martin,
>> all
>> resource
>> 2.
>> Thanks.
>> Anthony
>>> Hi Anthony,
>>> it set to null (you can set a breakpoint to check out who then
>>> nullifies the eContainer)? Which object was in which resource, was
>>> the child in resource 1 and the parent in resource 2, or both in the
>>> same resource?
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi,
>>>> the
>>>> contained object.
>>>> Is it the reason?
>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84009 is a reply to message #83994] |
Fri, 18 May 2007 14:30   |
Anthony,
Can you post the mapping file (or for one type which has an econtainer)?
No the meta attributes are not required for Teneo. They are for future use.
gr. Martin
Anthony wrote:
> Martin,
> Best regard,
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> all
>>> resource
>>> 2.
>>> Thanks.
>>> Anthony
>>>> Hi Anthony,
>>>> same resource?
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> the
>>>>> contained object.
>>>>> Is it the reason?
>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84023 is a reply to message #84009] |
Fri, 18 May 2007 14:40   |
Martin,
ProductRegistry is Product's container.
<subclass entity-name="Product" abstract="false" lazy="false"
extends="NamedElement" discriminator-value="Product">
<meta attribute="eclassName">Product</meta>
<property name="productId" lazy="false" insert="true"
update="true" not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false"
name="`productid`"/>
</property>
<many-to-one name="productRegistry" entity-
name="ProductRegistry" cascade="merge,persist,save-update,lock,refresh"
lazy="false" insert="false" update="false" not-null="false">
name="`product_productregistry_id`"/>
</many-to-one>
</subclass>
<class entity-name="ProductRegistry" abstract="false" lazy="false"
discriminator-value="ProductRegistry" table="`productregistry`">
<meta attribute="eclassName">ProductRegistry</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPro
pertyHandler">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp erty
Handler">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="modelName" lazy="false" insert="true"
update="true" not-null="true" unique="false" type="java.lang.String">
<column not-null="true" unique="false"
name="`modelname`"/>
</property>
</class>
Anthony
> Anthony,
> econtainer)?
> use. gr. Martin
> Anthony wrote:
>> Martin,
>> Best regard,
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> that all
>>>> set null at all. But the field present eContainer is null.
>>>> resource
>>>> 2.
>>>> Thanks.
>>>> Anthony
>>>>> Hi Anthony,
>>>>> was it set to null (you can set a breakpoint to check out who then
>>>>> the same resource?
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> null.
>>>>>> init the
>>>>>> contained object.
>>>>>> Is it the reason?
>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84039 is a reply to message #84023] |
Fri, 18 May 2007 14:43   |
Can you set a breakpoint in the method HbDataStore.addContainerMapping to check if it is called?
This method adds the econtainer mapping to the hbm mapping.
gr. Martin
Anthony wrote:
> Martin,
> </property>
> </many-to-one>
> </subclass>
> pertyHandler">
> </id>
> Handler">
> </version>
> </property>
> </class>
> Anthony
>> Anthony,
>> econtainer)?
>> use. gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Best regard,
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> that all
>>>>> resource
>>>>> 2.
>>>>> Thanks.
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> the same resource?
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> null.
>>>>>>> init the
>>>>>>> contained object.
>>>>>>> Is it the reason?
>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84157 is a reply to message #84142] |
Sat, 19 May 2007 11:31   |
Okay, one thing I find strange is that there is an econtainer field in the product but it does not
do addcontainermapping for this type.
Can you try the following:
override the HbSessionDataStore and the addContainerMapping method with the method below.
The only change I made is that in this method if a isContainer ereference is found no econtainer
mapping is added. Also you need to replace the code NAME_IS_PRODUCT with something meaningfull. It
is not a nice solution but it can help to identify how to solve this.
* Adds a econtainer mapping to the class mapping, is only called for eclasses which do not have
* am explicit feature which points to the container
protected void addContainerMapping(PersistentClass pc) {
// always first check if the super class should have a container mapping
if (pc.getSuperclass() != null) {
addContainerMapping(pc.getSuperclass());
if (!isContained(pc) && !NAME_IS_PRODUCT) return;
if (hasEContainerProp(pc)) return;
log.debug("Adding container mapping for " + getMappedName(pc));
// check if there are not alreadyecontai ner features for the eclass
final EClass eclass;
if (pc.getEntityName() != null) {
eclass =
getPersistenceOptions().getEClassNameStrategy().toEClass(pc. getEntityName(),
getEPackages());
} else {
eclass = EModelResolver.instance().getEClass(pc.getMappedClass());
// DCB: Provide a way to avoid container mappings for a particular
// class. You'd do this if, for example,
// you never load the contained objects except through the containers...
// or, you don't fit the use case
// for which this was put together (i.e., the generated model editing
// code tries to eagerly resolve the
// container)
if (eclass == null
|| eclass.getEAnnotation("http://facet.elver.org/SkipContainerMappings") != null) {
return; // featuremap
if (!NAME_IS_PRODUCT) {
for (EReference eref : eclass.getEAllReferences()) {
if (eref.isContainer()) {
log
.debug("There are container ereferences present, assuming that no separate econta iner columns
are required.");
return;
log.debug("Adding eContainer and econtainerfeatureid properties to " + pc.getClassName());
final Property eContainer = new Property();
eContainer.setName(HbConstants.PROPERTY_ECONTAINER);
eContainer.setMetaAttributes(new HashMap<Object, Object>());
eContainer.setNodeName(eContainer.getName());
eContainer.setPropertyAccessorName(EContainerAccessor.class. getName());
final SimpleValue sv = new SimpleValue(pc.getTable());
sv.setTypeName(EContainerUserType.class.getName());
final Column eccColumn = new Column(HbConstants.COLUMN_ECONTAINER_CLASS);
sv.addColumn(checkColumnExists(pc.getTable(), eccColumn));
final Column ecColumn = new Column(HbConstants.COLUMN_ECONTAINER);
sv.addColumn(checkColumnExists(pc.getTable(), ecColumn));
eContainer.setValue(sv);
pc.addProperty(eContainer);
final Property ecFID = new Property();
ecFID.setName(HbConstants.PROPERTY_ECONTAINER_FEATURE_ID);
ecFID.setMetaAttributes(new HashMap<Object, Object>());
ecFID.setNodeName(ecFID.getName());
ecFID.setPropertyAccessorName(EContainerFeatureIDAccessor.cl ass.getName());
final SimpleValue svfid = new SimpleValue(pc.getTable());
svfid.setTypeName("integer");
final Column ecfColumn = new Column(HbConstants.COLUMN_ECONTAINER_FEATUREID);
svfid.addColumn(checkColumnExists(pc.getTable(), ecfColumn));
ecFID.setValue(svfid);
pc.addProperty(ecFID);
Anthony wrote:
> Martin Taal <mtaal@elver.org> wrote in
> news:f2ml6i$j5i$1@build.eclipse.org:
>> The cause is that transient is true for ProductRegistry.products. I
>> think that this has to do with a performance issue in your case (the
>> products collection is very large). Is that correct?
> YES.
>> Otherwise setting
>> transient to false will ensure that the container is set in the db.
>> Even now if the products are read from the db through the
>> ProductRegistry.products then when loading the products their
>> econtainer should normally be set correctly. Did you try that? Or do
>> you read products independently?
> I load ProductRegistry first,
> and then I load product in another resource as I need to do pagination,
>> In the last case you can get the
>> container from the product.ProductRegistry.
> In fact , the product table has no ProductRegistry , it only have
> field EContainer , I guess they has been merged as one. Right?
>> So in short is it an issue for your app that the econtainer is not
>> stored separately in the econtainer fields in the db?
> In DB the econtainer field is always null.
> Anthony
>> gr. Martin
>> Anthony wrote:
>>> Martin Taal <mtaal@elver.org> wrote in news:f2kh1h$pth$1
>>> @build.eclipse.org:
>>>> Product.productRegistry
>>> Martin,
>>> Product.ProductRegistry :
>>> container:true
>>> containment: false
>>> resolve proxies: true
>>> required: true
>>> lower bound: 1
>>> upper bound: 1
>>> Transient : false
>>> Many : false
>>> EOpposite : products
>>> ProductRegistry.products:
>>> container:false
>>> containment: true
>>> required: false
>>> lower bound: 0
>>> upper bound: -1
>>> Transient : true
>>> Many : true
>>> EOpposite : productRegistry
>>> Regards,
>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84173 is a reply to message #84157] |
Sat, 19 May 2007 12:10   |
Martin,
At this time I am using Teneo 0.7.5, it has only HbDataStore.
So I need to upgrade to 0.8.
Tomorrow I will try it.
Thanks.
Anthony
> the product but it does not do addcontainermapping for this type.
> with the method below. The only change I made is that in this method
> if a isContainer ereference is found no econtainer mapping is added.
> meaningfull. It is not a nice solution but it can help to identify how
> to solve this.
> for eclasses which do not have * am explicit feature which
> points to the container */
> container mapping if (pc.getSuperclass() != null) {
> getMappedName(pc)); // check if there are not alreadyecontai
> eclass =
> ).toEClass(pc.getEntityName(),
> getEPackages());
> } else {
> eclass =
> particular // class. You'd do this if, for example,
> containers... // or, you don't fit the use case
> model editing // code tries to eagerly resolve the
> // container)
> if (eclass == null
> log
> econta iner columns
> are required.");
> return;
(EContainerAccessor.class.g
> etName());
(EContainerFeatureIDAccessor.cla
> ss.getName()); final SimpleValue svfid = new
> SimpleValue(pc.getTable()); svfid.setTypeName("integer");
> ecfColumn));
>> YES.
>>> Otherwise setting
>> pagination,
>> Anthony
>>> gr. Martin
>>>> @build.eclipse.org:
>>>> Martin,
>>>> container:true
>>>> containment: false
>>>> required: true
>>>> lower bound: 1
>>>> upper bound: 1
>>>> Transient : false
>>>> Many : false
>>>> container:false
>>>> containment: true
>>>> required: false
>>>> lower bound: 0
>>>> upper bound: -1
>>>> Transient : true
>>>> Many : true
>>>> Regards,
>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84188 is a reply to message #84173] |
Sun, 20 May 2007 04:04   |
Anthony,
This part of the code did not change that much since 0.7.5. For 0.7.5 you can override the HbDataStore.
gr. Martin
Anthony wrote:
> Martin,
> Thanks.
> Anthony
>> to solve this.
>> eclass =
>> getEPackages());
>> } else {
>> eclass =
>> // container)
>> if (eclass == null
>> log
>> econta iner columns
>> are required.");
>> return;
>> etName());
>> ecfColumn));
>>> YES.
>>>> Otherwise setting
>>> pagination,
>>> Anthony
>>>> gr. Martin
>>>>> @build.eclipse.org:
>>>>> Martin,
>>>>> container:true
>>>>> containment: false
>>>>> required: true
>>>>> lower bound: 1
>>>>> upper bound: 1
>>>>> Transient : false
>>>>> Many : false
>>>>> container:false
>>>>> containment: true
>>>>> required: false
>>>>> lower bound: 0
>>>>> upper bound: -1
>>>>> Transient : true
>>>>> Many : true
>>>>> Regards,
>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84220 is a reply to message #84188] |
Sun, 20 May 2007 04:44   |
Martin,
As isContained(),hasEContainerProp(),checkColumnExists() are private
method,HbDataStore's addContainerMapping() cannot be overrided.
Is there another way to work around?
Thanks.
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Thanks.
>> Anthony
>>> in the product but it does not do addcontainermapping for this type.
>>> how to solve this.
>>> called for eclasses which do not have * am explicit feature
>>> which points to the container */
>>> eclass =
>>> y
>>> getEPackages());
>>> } else {
>>> eclass =
>>> // container)
>>> if (eclass == null
>>> log
>>> ereferences
>>> econta iner columns
>>> are required.");
>>> return;
>>> Object>()); eContainer.setNodeName(eContainer.getName());
>>> etName());
>>> ecfColumn));
>>>>> I think that this has to do with a performance issue in your case
>>>>> (the products collection is very large). Is that correct?
>>>> YES.
>>>>> Otherwise setting
>>>>> db. Even now if the products are read from the db through the
>>>>> do you read products independently?
>>>> pagination,
>>>> Anthony
>>>>> gr. Martin
>>>>>> @build.eclipse.org:
>>>>>> Martin,
>>>>>> container:true
>>>>>> containment: false
>>>>>> required: true
>>>>>> lower bound: 1
>>>>>> upper bound: 1
>>>>>> Transient : false
>>>>>> Many : false
>>>>>> container:false
>>>>>> containment: true
>>>>>> required: false
>>>>>> lower bound: 0
>>>>>> upper bound: -1
>>>>>> Transient : true
>>>>>> Many : true
>>>>>> Regards,
>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84235 is a reply to message #84220] |
Sun, 20 May 2007 04:53   |
Anthony,
I would copy these methods also, each of them is only a few lines.
Btw, this is just a workaround to get you going. If you enter a bugzilla for this then I can look at
it more thoroughly for the next build.
gr. Martin
Anthony wrote:
> Martin,
> Thanks.
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thanks.
>>> Anthony
>>>> how to solve this.
>>>> eclass =
>>>> y
>>>> getEPackages());
>>>> } else {
>>>> eclass =
>>>> // container)
>>>> if (eclass == null
>>>> log
>>>> ereferences
>>>> econta iner columns
>>>> are required.");
>>>> return;
>>>> etName());
>>>> ecfColumn));
>>>>> YES.
>>>>>> Otherwise setting
>>>>> pagination,
>>>>> Anthony
>>>>>> gr. Martin
>>>>>>> @build.eclipse.org:
>>>>>>> Martin,
>>>>>>> container:true
>>>>>>> containment: false
>>>>>>> required: true
>>>>>>> lower bound: 1
>>>>>>> upper bound: 1
>>>>>>> Transient : false
>>>>>>> Many : false
>>>>>>> container:false
>>>>>>> containment: true
>>>>>>> required: false
>>>>>>> lower bound: 0
>>>>>>> upper bound: -1
>>>>>>> Transient : true
>>>>>>> Many : true
>>>>>>> Regards,
>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84250 is a reply to message #84235] |
Sun, 20 May 2007 05:01   |
Martin,
OK. (Sorry for the stupid question.I have done that before.)
I will enter a bugzilla later.
Anthony
> Anthony,
> bugzilla for this then I can look at it more thoroughly for the next
> build.
> gr. Martin
> Anthony wrote:
>> Martin,
>> private
>> Thanks.
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thanks.
>>>> Anthony
>>>>> field in the product but it does not do addcontainermapping for
>>>>> this type.
>>>>> method if a isContainer ereference is found no econtainer mapping
>>>>> something meaningfull. It is not a nice solution but it can help
>>>>> eclass =
>>>>> y
>>>>> getEPackages());
>>>>> } else {
>>>>> eclass =
(pc.getMappedClas
>>>>> s
>>>>> the containers... // or, you don't fit the use case
>>>>> // container)
>>>>> if (eclass == null
>>>>> log
>>>>> ereferences
>>>>> econta iner columns
>>>>> are required.");
>>>>> return;
>>>>> Object>());
>>>>> etName());
>>>>> eccColumn));
>>>>> ecColumn));
>>>>> ecFID.setName
>>>>> ; ecFID.setMetaAttributes(new HashMap<Object,
>>>>> Object>()); ecFID.setNodeName(ecFID.getName());
>>>>> ecfColumn));
>>>>>>> ProductRegistry.products. I think that this has to do with a
>>>>>>> performance issue in your case (the products collection is very
>>>>>> YES.
>>>>>>> Otherwise setting
>>>>>>> Or do you read products independently?
>>>>>> pagination,
>>>>>>> not stored separately in the econtainer fields in the db?
>>>>>> Anthony
>>>>>>> gr. Martin
>>>>>>>> @build.eclipse.org:
>>>>>>>> Martin,
>>>>>>>> container:true
>>>>>>>> containment: false
>>>>>>>> required: true
>>>>>>>> lower bound: 1
>>>>>>>> upper bound: 1
>>>>>>>> Transient : false
>>>>>>>> Many : false
>>>>>>>> container:false
>>>>>>>> containment: true
>>>>>>>> required: false
>>>>>>>> lower bound: 0
>>>>>>>> upper bound: -1
>>>>>>>> Transient : true
>>>>>>>> Many : true
>>>>>>>> Regards,
>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84265 is a reply to message #84250] |
Sun, 20 May 2007 05:13   |
Hi Anthony,
No stupid question at all (I forgot myself that these were private when copy-pasting the code in the
previous post), over time I noticed that I should make more and more methods in HbDataStore
protected to facilitate customization, probably these methods are also candidates.
gr. Martin
Anthony wrote:
> Martin,
> Anthony
>> Anthony,
>> build.
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> private
>>> Thanks.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thanks.
>>>>> Anthony
>>>>>> this type.
>>>>>> eclass =
>>>>>> y
>>>>>> getEPackages());
>>>>>> } else {
>>>>>> eclass =
> (pc.getMappedClas
>>>>>> s
>>>>>> // container)
>>>>>> if (eclass == null
>>>>>> log
>>>>>> ereferences
>>>>>> econta iner columns
>>>>>> are required.");
>>>>>> return;
>>>>>> Object>());
>>>>>> etName());
>>>>>> eccColumn));
>>>>>> ecColumn));
>>>>>> ecFID.setName
>>>>>> ecfColumn));
>>>>>>> YES.
>>>>>>>> Otherwise setting
>>>>>>> pagination,
>>>>>>> Anthony
>>>>>>>> gr. Martin
>>>>>>>>> @build.eclipse.org:
>>>>>>>>> Martin,
>>>>>>>>> container:true
>>>>>>>>> containment: false
>>>>>>>>> required: true
>>>>>>>>> lower bound: 1
>>>>>>>>> upper bound: 1
>>>>>>>>> Transient : false
>>>>>>>>> Many : false
>>>>>>>>> container:false
>>>>>>>>> containment: true
>>>>>>>>> required: false
>>>>>>>>> lower bound: 0
>>>>>>>>> upper bound: -1
>>>>>>>>> Transient : true
>>>>>>>>> Many : true
>>>>>>>>> Regards,
>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84280 is a reply to message #84265] |
Sun, 20 May 2007 05:44   |
Martin,
agree,'protected' would be better.
isContained() method can be copy, but it need a private member
'referers' and no method(protected or public) could return this member.
Any idea?
( rt.isContainer could be replace with rt.isContainer())
Anthony
> Hi Anthony,
> when copy-pasting the code in the previous post), over time I noticed
> that I should make more and more methods in HbDataStore protected to
> gr. Martin
> Anthony wrote:
>> Martin,
>> Anthony
>>> Anthony,
>>> build.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> private
>>>> Thanks.
>>>> Anthony
>>>>> Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> this type.
>>>>>>> method with the method below. The only change I made is that in
>>>>>>> NAME_IS_PRODUCT with something meaningfull. It is not a nice
>>>>>>> feature which points to the container */
>>>>>>> eclass =
>>>>>>> y
>>>>>>> getEPackages());
>>>>>>> } else {
>>>>>>> eclass =
>> (pc.getMappedClas
>>>>>>> s
>>>>>>> a particular // class. You'd do this if, for example,
>>>>>>> generated model editing // code tries to eagerly
>>>>>>> resolve the // container)
>>>>>>> if (eclass == null
>>>>>>> log
>>>>>>> ereferences
>>>>>>> econta iner columns
>>>>>>> are required.");
>>>>>>> return;
>>>>>>> Object>());
>>>>>>> etName());
>>>>>>> eccColumn));
>>>>>>> ecColumn));
>>>>>>> ecFID.setName
>>>>>>> ecfColumn));
>>>>>>>> YES.
>>>>>>>>> Otherwise setting
>>>>>>>>> the db. Even now if the products are read from the db through
>>>>>>>>> the ProductRegistry.products then when loading the products
>>>>>>>>> their econtainer should normally be set correctly. Did you try
>>>>>>>>> that? Or do you read products independently?
>>>>>>>> pagination,
>>>>>>>> have field EContainer , I guess they has been merged as one.
>>>>>>>> Right?
>>>>>>>> Anthony
>>>>>>>>> gr. Martin
>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>> Martin,
>>>>>>>>>> container:true
>>>>>>>>>> containment: false
>>>>>>>>>> required: true
>>>>>>>>>> lower bound: 1
>>>>>>>>>> upper bound: 1
>>>>>>>>>> Transient : false
>>>>>>>>>> Many : false
>>>>>>>>>> container:false
>>>>>>>>>> containment: true
>>>>>>>>>> required: false
>>>>>>>>>> lower bound: 0
>>>>>>>>>> upper bound: -1
>>>>>>>>>> Transient : true
>>>>>>>>>> Many : true
>>>>>>>>>> Regards,
>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84295 is a reply to message #84280] |
Sun, 20 May 2007 06:13   |
Anthony,
The latest release of Teneo should have a getReferers method.
gr. Martin
Anthony wrote:
> Martin,
> Any idea?
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Anthony
>>>> Anthony,
>>>> build.
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> private
>>>>> Thanks.
>>>>> Anthony
>>>>>> Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Martin,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> this type.
>>>>>>>> eclass =
>>>>>>>> y
>>>>>>>> getEPackages());
>>>>>>>> } else {
>>>>>>>> eclass =
>>> (pc.getMappedClas
>>>>>>>> s
>>>>>>>> if (eclass == null
>>>>>>>> log
>>>>>>>> ereferences
>>>>>>>> econta iner columns
>>>>>>>> are required.");
>>>>>>>> return;
>>>>>>>> Object>());
>>>>>>>> etName());
>>>>>>>> eccColumn));
>>>>>>>> ecColumn));
>>>>>>>> ecFID.setName
>>>>>>>> ecfColumn));
>>>>>>>>> YES.
>>>>>>>>>> Otherwise setting
>>>>>>>>> pagination,
>>>>>>>>> Right?
>>>>>>>>> Anthony
>>>>>>>>>> gr. Martin
>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>> Martin,
>>>>>>>>>>> container:true
>>>>>>>>>>> containment: false
>>>>>>>>>>> required: true
>>>>>>>>>>> lower bound: 1
>>>>>>>>>>> upper bound: 1
>>>>>>>>>>> Transient : false
>>>>>>>>>>> Many : false
>>>>>>>>>>> container:false
>>>>>>>>>>> containment: true
>>>>>>>>>>> required: false
>>>>>>>>>>> lower bound: 0
>>>>>>>>>>> upper bound: -1
>>>>>>>>>>> Transient : true
>>>>>>>>>>> Many : true
>>>>>>>>>>> Regards,
>>>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84310 is a reply to message #84295] |
Sun, 20 May 2007 07:59   |
Martin,
After I use customed HbSessionDataStore , I got en exception said
org.hibernate.MappingException: Unknown entity: SND(my top model class)
BTW, where to input bugzilla and when will next release be ready?
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
member.
>> Any idea?
>> Anthony
>>> Hi Anthony,
noticed
candidates.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Anthony
>>>>> Anthony,
next
>>>>> build.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> private
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> Thanks.
>>>>>>>> Anthony
for
>>>>>>>>> this type.
in
only
a
>>>>>>>>> eclass =
>>>>>>>>> y
>>>>>>>>> getEPackages());
>>>>>>>>> } else {
>>>>>>>>> eclass =
>>>> (pc.getMappedClas
>>>>>>>>> s
for
example,
through
>>>>>>>>> if (eclass == null
>>>>>>>>> log
>>>>>>>>> ereferences
separate
>>>>>>>>> econta iner columns
>>>>>>>>> are required.");
>>>>>>>>> return;
>>>>>>>>> Object>());
>>>>>>>>> etName());
>>>>>>>>> eccColumn));
>>>>>>>>> ecColumn));
>>>>>>>>> ecFID.setName
>>>>>>>>> ecfColumn));
>>>>>>>>>> YES.
>>>>>>>>>>> Otherwise setting
through
try
>>>>>>>>>> pagination,
>>>>>>>>>> Right?
is
>>>>>>>>>> Anthony
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>> Martin,
>>>>>>>>>>>> container:true
>>>>>>>>>>>> containment: false
>>>>>>>>>>>> required: true
>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>> Transient : false
>>>>>>>>>>>> Many : false
>>>>>>>>>>>> container:false
>>>>>>>>>>>> containment: true
>>>>>>>>>>>> required: false
>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>> Transient : true
>>>>>>>>>>>> Many : true
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84327 is a reply to message #84310] |
Sun, 20 May 2007 08:05   |
Anthony,
Can you post the complete stacktrace?
Which version of Teneo are you using?
Bugzilla can be entered here:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT
I had hoped to do a next release this week but it will be a few weeks later.
gr. Martin
Anthony wrote:
> Martin,
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
> member.
>>> Any idea?
>>> Anthony
>>>> Hi Anthony,
> noticed
> candidates.
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Anthony
>>>>>> Anthony,
> next
>>>>>> build.
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Martin,
>>>>>>> private
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> Anthony,
>>>>>>>> gr. Martin
>>>>>>>> Anthony wrote:
>>>>>>>>> Martin,
>>>>>>>>> Thanks.
>>>>>>>>> Anthony
> for
>>>>>>>>>> this type.
> in
> only
> a
>>>>>>>>>> eclass =
>>>>>>>>>> y
>>>>>>>>>> getEPackages());
>>>>>>>>>> } else {
>>>>>>>>>> eclass =
>>>>> (pc.getMappedClas
>>>>>>>>>> s
> for
> example,
> through
>>>>>>>>>> if (eclass == null
>>>>>>>>>> log
>>>>>>>>>> ereferences
> separate
>>>>>>>>>> econta iner columns
>>>>>>>>>> are required.");
>>>>>>>>>> return;
>>>>>>>>>> Object>());
>>>>>>>>>> etName());
>>>>>>>>>> eccColumn));
>>>>>>>>>> ecColumn));
>>>>>>>>>> ecFID.setName
>>>>>>>>>> ecfColumn));
>>>>>>>>>>> YES.
>>>>>>>>>>>> Otherwise setting
> through
> try
>>>>>>>>>>> pagination,
>>>>>>>>>>> Right?
> is
>>>>>>>>>>> Anthony
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>> container:true
>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>> required: true
>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>> container:false
>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>> required: false
>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #84345 is a reply to message #84327] |
Sun, 20 May 2007 10:36   |
Martin,
Now I am using 0.8.
Just a few minutes ago , I try it again(after clear schema and mapping
file) and it's OK .
It seems that the previous exception was caused by other reason.
I will input a bugzilla.
Thanks.
Anthony
> Anthony,
> later.
> gr. Martin
> Anthony wrote:
>> Martin,
>> class)
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>> member.
>>>> Any idea?
>>>> Anthony
>>>>> Hi Anthony,
>> noticed
>> candidates.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> lines. Btw, this is just a workaround to get you going. If you
>>>>>>> enter a bugzilla for this then I can look at it more thoroughly
>>>>>>> for the
>> next
>>>>>>> build.
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> private
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>>> gr. Martin
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Martin,
>>>>>>>>>> HbDataStore.
>>>>>>>>>> Thanks.
>>>>>>>>>> Anthony
>>>>>>>>>>> econtainer field in the product but it does not do
>>>>>>>>>>> addcontainermapping
>> for
>>>>>>>>>>> this type.
>> in
>>>>>>>>>>> econtainer mapping is added. Also you need to replace the
>>>>>>>>>>> code NAME_IS_PRODUCT with something meaningfull. It is not a
>> only
>>>>>>>>>>> have
>> a
>>>>>>>>>>> eclass =
>>>>>>>>>>> y
>>>>>>>>>>> getEPackages());
>>>>>>>>>>> } else {
>>>>>>>>>>> eclass =
>>>>>> (pc.getMappedClas
>>>>>>>>>>> s
>> for
>> example,
>> through
>>>>>>>>>>> case // for which this was put together (i.e., the
>>>>>>>>>>> if (eclass == null
>>>>>>>>>>> log
>>>>>>>>>>> ereferences
>> separate
>>>>>>>>>>> econta iner columns
>>>>>>>>>>> are required.");
>>>>>>>>>>> return;
>>>>>>>>>>> pc.getClassName());
>>>>>>>>>>> ; eContainer.setMetaAttributes(new HashMap<Object,
>>>>>>>>>>> Object>());
>>>>>>>>>>> etName());
>>>>>>>>>>> eccColumn));
>>>>>>>>>>> ecColumn));
>>>>>>>>>>> ecFID.setName
>>>>>>>>>>> ecfColumn));
>>>>>>>>>>>>> a performance issue in your case (the products collection
>>>>>>>>>>>> YES.
>>>>>>>>>>>>> Otherwise setting
>>>>>>>>>>>>> in the db. Even now if the products are read from the db
>> through
>>>>>>>>>>>>> products their econtainer should normally be set
>>>>>>>>>>>>> correctly. Did you
>> try
>>>>>>>>>>>> pagination,
>>>>>>>>>>>> only have field EContainer , I guess they has been merged
>>>>>>>>>>>> as one. Right?
>>>>>>>>>>>>> econtainer
>> is
>>>>>>>>>>>> Anthony
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>>> container:true
>>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>>> required: true
>>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>>> container:false
>>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>>> required: false
>>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #84361 is a reply to message #84327] |
Sun, 20 May 2007 10:57  |
Martin :
bug# is 187984 .
Anthony
> Anthony,
> later.
> gr. Martin
> Anthony wrote:
>> Martin,
>> class)
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>> member.
>>>> Any idea?
>>>> Anthony
>>>>> Hi Anthony,
>> noticed
>> candidates.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> for the
>> next
>>>>>>> build.
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> private
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>>> gr. Martin
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Martin,
>>>>>>>>>> HbDataStore.
>>>>>>>>>> Thanks.
>>>>>>>>>> Anthony
>>>>>>>>>>> addcontainermapping
>> for
>>>>>>>>>>> this type.
>> in
>> only
>>>>>>>>>>> have
>> a
>>>>>>>>>>> eclass =
>>>>>>>>>>> y
>>>>>>>>>>> getEPackages());
>>>>>>>>>>> } else {
>>>>>>>>>>> eclass =
>>>>>> (pc.getMappedClas
>>>>>>>>>>> s
>> for
>> example,
>> through
>>>>>>>>>>> if (eclass == null
>>>>>>>>>>> log
>>>>>>>>>>> ereferences
>> separate
>>>>>>>>>>> econta iner columns
>>>>>>>>>>> are required.");
>>>>>>>>>>> return;
>>>>>>>>>>> pc.getClassName());
>>>>>>>>>>> eContainer.setName
>>>>>>>>>>> Object>());
>>>>>>>>>>> etName());
>>>>>>>>>>> eccColumn));
>>>>>>>>>>> ecColumn));
>>>>>>>>>>> ecFID.setName
>>>>>>>>>>> ecfColumn));
>>>>>>>>>>>> YES.
>>>>>>>>>>>>> Otherwise setting
>> through
>>>>>>>>>>>>> correctly. Did you
>> try
>>>>>>>>>>>> pagination,
>>>>>>>>>>>> as one. Right?
>>>>>>>>>>>>> econtainer
>> is
>>>>>>>>>>>> Anthony
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>>> container:true
>>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>>> required: true
>>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>>> container:false
>>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>>> required: false
>>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606726 is a reply to message #83921] |
Hi Anthony,
gr. Martin
Anthony wrote:
> contained object.
> Is it the reason?
> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606727 is a reply to message #83936] |
Martin,
2.
Thanks.
Anthony
> Hi Anthony,
> gr. Martin
> Anthony wrote:
>> the
>> contained object.
>> Is it the reason?
>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606728 is a reply to message #83949] |
Anthony
> Martin,
all
> 2.
> Thanks.
> Anthony
>> Hi Anthony,
it
resource?
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> the
>>> contained object.
>>> Is it the reason?
>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606729 is a reply to message #83949] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> 2.
> Thanks.
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Hi,
>>> the
>>> contained object.
>>> Is it the reason?
>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606730 is a reply to message #83979] |
Martin,
Best regard,
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> all
>> resource
>> 2.
>> Thanks.
>> Anthony
>>> Hi Anthony,
>>> same resource?
>>> gr. Martin
>>> Anthony wrote:
>>>> Hi,
>>>> the
>>>> contained object.
>>>> Is it the reason?
>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606731 is a reply to message #83994] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Best regard,
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> all
>>> resource
>>> 2.
>>> Thanks.
>>> Anthony
>>>> Hi Anthony,
>>>> same resource?
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Hi,
>>>>> the
>>>>> contained object.
>>>>> Is it the reason?
>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606732 is a reply to message #84009] |
Martin,
</property>
</many-to-one>
</subclass>
pertyHandler">
</id>
Handler">
</version>
</property>
</class>
Anthony
> Anthony,
> econtainer)?
> use. gr. Martin
> Anthony wrote:
>> Martin,
>> Best regard,
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> that all
>>>> resource
>>>> 2.
>>>> Thanks.
>>>> Anthony
>>>>> Hi Anthony,
>>>>> the same resource?
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Hi,
>>>>>> null.
>>>>>> init the
>>>>>> contained object.
>>>>>> Is it the reason?
>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606733 is a reply to message #84023] |
gr. Martin
Anthony wrote:
> Martin,
> </property>
> </many-to-one>
> </subclass>
> pertyHandler">
> </id>
> Handler">
> </version>
> </property>
> </class>
> Anthony
>> Anthony,
>> econtainer)?
>> use. gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Best regard,
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> that all
>>>>> resource
>>>>> 2.
>>>>> Thanks.
>>>>> Anthony
>>>>>> Hi Anthony,
>>>>>> the same resource?
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Hi,
>>>>>>> null.
>>>>>>> init the
>>>>>>> contained object.
>>>>>>> Is it the reason?
>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606741 is a reply to message #84142] |
eclass =
getEPackages());
} else {
// container)
if (eclass == null
log
are required.");
return;
> YES.
>> Otherwise setting
> Anthony
>> gr. Martin
>>> @build.eclipse.org:
>>> Martin,
>>> container:true
>>> containment: false
>>> required: true
>>> lower bound: 1
>>> upper bound: 1
>>> Transient : false
>>> Many : false
>>> container:false
>>> containment: true
>>> required: false
>>> lower bound: 0
>>> upper bound: -1
>>> Transient : true
>>> Many : true
>>> Regards,
>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606742 is a reply to message #84157] |
Martin,
Thanks.
Anthony
> to solve this.
> eclass =
> getEPackages());
> } else {
> eclass =
> // container)
> if (eclass == null
> log
> econta iner columns
> are required.");
> return;
> etName());
> ecfColumn));
>> YES.
>>> Otherwise setting
>> pagination,
>> Anthony
>>> gr. Martin
>>>> @build.eclipse.org:
>>>> Martin,
>>>> container:true
>>>> containment: false
>>>> required: true
>>>> lower bound: 1
>>>> upper bound: 1
>>>> Transient : false
>>>> Many : false
>>>> container:false
>>>> containment: true
>>>> required: false
>>>> lower bound: 0
>>>> upper bound: -1
>>>> Transient : true
>>>> Many : true
>>>> Regards,
>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606743 is a reply to message #84173] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Thanks.
> Anthony
>> to solve this.
>> eclass =
>> getEPackages());
>> } else {
>> eclass =
>> // container)
>> if (eclass == null
>> log
>> econta iner columns
>> are required.");
>> return;
>> etName());
>> ecfColumn));
>>> YES.
>>>> Otherwise setting
>>> pagination,
>>> Anthony
>>>> gr. Martin
>>>>> @build.eclipse.org:
>>>>> Martin,
>>>>> container:true
>>>>> containment: false
>>>>> required: true
>>>>> lower bound: 1
>>>>> upper bound: 1
>>>>> Transient : false
>>>>> Many : false
>>>>> container:false
>>>>> containment: true
>>>>> required: false
>>>>> lower bound: 0
>>>>> upper bound: -1
>>>>> Transient : true
>>>>> Many : true
>>>>> Regards,
>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606745 is a reply to message #84188] |
Martin,
Thanks.
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Thanks.
>> Anthony
>>> how to solve this.
>>> eclass =
>>> y
>>> getEPackages());
>>> } else {
>>> eclass =
>>> // container)
>>> if (eclass == null
>>> log
>>> ereferences
>>> econta iner columns
>>> are required.");
>>> return;
>>> etName());
>>> ecfColumn));
>>>> YES.
>>>>> Otherwise setting
>>>> pagination,
>>>> Anthony
>>>>> gr. Martin
>>>>>> @build.eclipse.org:
>>>>>> Martin,
>>>>>> container:true
>>>>>> containment: false
>>>>>> required: true
>>>>>> lower bound: 1
>>>>>> upper bound: 1
>>>>>> Transient : false
>>>>>> Many : false
>>>>>> container:false
>>>>>> containment: true
>>>>>> required: false
>>>>>> lower bound: 0
>>>>>> upper bound: -1
>>>>>> Transient : true
>>>>>> Many : true
>>>>>> Regards,
>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606746 is a reply to message #84220] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Thanks.
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Thanks.
>>> Anthony
>>>> how to solve this.
>>>> eclass =
>>>> y
>>>> getEPackages());
>>>> } else {
>>>> eclass =
>>>> // container)
>>>> if (eclass == null
>>>> log
>>>> ereferences
>>>> econta iner columns
>>>> are required.");
>>>> return;
>>>> etName());
>>>> ecfColumn));
>>>>> YES.
>>>>>> Otherwise setting
>>>>> pagination,
>>>>> Anthony
>>>>>> gr. Martin
>>>>>>> @build.eclipse.org:
>>>>>>> Martin,
>>>>>>> container:true
>>>>>>> containment: false
>>>>>>> required: true
>>>>>>> lower bound: 1
>>>>>>> upper bound: 1
>>>>>>> Transient : false
>>>>>>> Many : false
>>>>>>> container:false
>>>>>>> containment: true
>>>>>>> required: false
>>>>>>> lower bound: 0
>>>>>>> upper bound: -1
>>>>>>> Transient : true
>>>>>>> Many : true
>>>>>>> Regards,
>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606747 is a reply to message #84235] |
Martin,
Anthony
> Anthony,
> build.
> gr. Martin
> Anthony wrote:
>> Martin,
>> private
>> Thanks.
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Thanks.
>>>> Anthony
>>>>> this type.
>>>>> eclass =
>>>>> y
>>>>> getEPackages());
>>>>> } else {
>>>>> eclass =
(pc.getMappedClas
>>>>> s
>>>>> // container)
>>>>> if (eclass == null
>>>>> log
>>>>> ereferences
>>>>> econta iner columns
>>>>> are required.");
>>>>> return;
>>>>> Object>());
>>>>> etName());
>>>>> eccColumn));
>>>>> ecColumn));
>>>>> ecFID.setName
>>>>> ecfColumn));
>>>>>> YES.
>>>>>>> Otherwise setting
>>>>>> pagination,
>>>>>> Anthony
>>>>>>> gr. Martin
>>>>>>>> @build.eclipse.org:
>>>>>>>> Martin,
>>>>>>>> container:true
>>>>>>>> containment: false
>>>>>>>> required: true
>>>>>>>> lower bound: 1
>>>>>>>> upper bound: 1
>>>>>>>> Transient : false
>>>>>>>> Many : false
>>>>>>>> container:false
>>>>>>>> containment: true
>>>>>>>> required: false
>>>>>>>> lower bound: 0
>>>>>>>> upper bound: -1
>>>>>>>> Transient : true
>>>>>>>> Many : true
>>>>>>>> Regards,
>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606748 is a reply to message #84250] |
Hi Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Anthony
>> Anthony,
>> build.
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> private
>>> Thanks.
>>> Anthony
>>>> Anthony,
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Thanks.
>>>>> Anthony
>>>>>> this type.
>>>>>> eclass =
>>>>>> y
>>>>>> getEPackages());
>>>>>> } else {
>>>>>> eclass =
> (pc.getMappedClas
>>>>>> s
>>>>>> // container)
>>>>>> if (eclass == null
>>>>>> log
>>>>>> ereferences
>>>>>> econta iner columns
>>>>>> are required.");
>>>>>> return;
>>>>>> Object>());
>>>>>> etName());
>>>>>> eccColumn));
>>>>>> ecColumn));
>>>>>> ecFID.setName
>>>>>> ecfColumn));
>>>>>>> YES.
>>>>>>>> Otherwise setting
>>>>>>> pagination,
>>>>>>> Anthony
>>>>>>>> gr. Martin
>>>>>>>>> @build.eclipse.org:
>>>>>>>>> Martin,
>>>>>>>>> container:true
>>>>>>>>> containment: false
>>>>>>>>> required: true
>>>>>>>>> lower bound: 1
>>>>>>>>> upper bound: 1
>>>>>>>>> Transient : false
>>>>>>>>> Many : false
>>>>>>>>> container:false
>>>>>>>>> containment: true
>>>>>>>>> required: false
>>>>>>>>> lower bound: 0
>>>>>>>>> upper bound: -1
>>>>>>>>> Transient : true
>>>>>>>>> Many : true
>>>>>>>>> Regards,
>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606749 is a reply to message #84265] |
Martin,
Any idea?
Anthony
> Hi Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
>> Anthony
>>> Anthony,
>>> build.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> private
>>>> Thanks.
>>>> Anthony
>>>>> Anthony,
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> this type.
>>>>>>> eclass =
>>>>>>> y
>>>>>>> getEPackages());
>>>>>>> } else {
>>>>>>> eclass =
>> (pc.getMappedClas
>>>>>>> s
>>>>>>> if (eclass == null
>>>>>>> log
>>>>>>> ereferences
>>>>>>> econta iner columns
>>>>>>> are required.");
>>>>>>> return;
>>>>>>> Object>());
>>>>>>> etName());
>>>>>>> eccColumn));
>>>>>>> ecColumn));
>>>>>>> ecFID.setName
>>>>>>> ecfColumn));
>>>>>>>> YES.
>>>>>>>>> Otherwise setting
>>>>>>>> pagination,
>>>>>>>> Right?
>>>>>>>> Anthony
>>>>>>>>> gr. Martin
>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>> Martin,
>>>>>>>>>> container:true
>>>>>>>>>> containment: false
>>>>>>>>>> required: true
>>>>>>>>>> lower bound: 1
>>>>>>>>>> upper bound: 1
>>>>>>>>>> Transient : false
>>>>>>>>>> Many : false
>>>>>>>>>> container:false
>>>>>>>>>> containment: true
>>>>>>>>>> required: false
>>>>>>>>>> lower bound: 0
>>>>>>>>>> upper bound: -1
>>>>>>>>>> Transient : true
>>>>>>>>>> Many : true
>>>>>>>>>> Regards,
>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606750 is a reply to message #84280] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Any idea?
> Anthony
>> Hi Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
>>> Anthony
>>>> Anthony,
>>>> build.
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> private
>>>>> Thanks.
>>>>> Anthony
>>>>>> Anthony,
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Martin,
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> this type.
>>>>>>>> eclass =
>>>>>>>> y
>>>>>>>> getEPackages());
>>>>>>>> } else {
>>>>>>>> eclass =
>>> (pc.getMappedClas
>>>>>>>> s
>>>>>>>> if (eclass == null
>>>>>>>> log
>>>>>>>> ereferences
>>>>>>>> econta iner columns
>>>>>>>> are required.");
>>>>>>>> return;
>>>>>>>> Object>());
>>>>>>>> etName());
>>>>>>>> eccColumn));
>>>>>>>> ecColumn));
>>>>>>>> ecFID.setName
>>>>>>>> ecfColumn));
>>>>>>>>> YES.
>>>>>>>>>> Otherwise setting
>>>>>>>>> pagination,
>>>>>>>>> Right?
>>>>>>>>> Anthony
>>>>>>>>>> gr. Martin
>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>> Martin,
>>>>>>>>>>> container:true
>>>>>>>>>>> containment: false
>>>>>>>>>>> required: true
>>>>>>>>>>> lower bound: 1
>>>>>>>>>>> upper bound: 1
>>>>>>>>>>> Transient : false
>>>>>>>>>>> Many : false
>>>>>>>>>>> container:false
>>>>>>>>>>> containment: true
>>>>>>>>>>> required: false
>>>>>>>>>>> lower bound: 0
>>>>>>>>>>> upper bound: -1
>>>>>>>>>>> Transient : true
>>>>>>>>>>> Many : true
>>>>>>>>>>> Regards,
>>>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606751 is a reply to message #84295] |
Martin,
Anthony
> Anthony,
> gr. Martin
> Anthony wrote:
>> Martin,
member.
>> Any idea?
>> Anthony
>>> Hi Anthony,
noticed
candidates.
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>>>> Anthony
>>>>> Anthony,
next
>>>>> build.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> private
>>>>>> Thanks.
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> Thanks.
>>>>>>>> Anthony
for
>>>>>>>>> this type.
in
only
a
>>>>>>>>> eclass =
>>>>>>>>> y
>>>>>>>>> getEPackages());
>>>>>>>>> } else {
>>>>>>>>> eclass =
>>>> (pc.getMappedClas
>>>>>>>>> s
for
example,
through
>>>>>>>>> if (eclass == null
>>>>>>>>> log
>>>>>>>>> ereferences
separate
>>>>>>>>> econta iner columns
>>>>>>>>> are required.");
>>>>>>>>> return;
>>>>>>>>> Object>());
>>>>>>>>> etName());
>>>>>>>>> eccColumn));
>>>>>>>>> ecColumn));
>>>>>>>>> ecFID.setName
>>>>>>>>> ecfColumn));
>>>>>>>>>> YES.
>>>>>>>>>>> Otherwise setting
through
try
>>>>>>>>>> pagination,
>>>>>>>>>> Right?
is
>>>>>>>>>> Anthony
>>>>>>>>>>> gr. Martin
>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>> Martin,
>>>>>>>>>>>> container:true
>>>>>>>>>>>> containment: false
>>>>>>>>>>>> required: true
>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>> Transient : false
>>>>>>>>>>>> Many : false
>>>>>>>>>>>> container:false
>>>>>>>>>>>> containment: true
>>>>>>>>>>>> required: false
>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>> Transient : true
>>>>>>>>>>>> Many : true
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606752 is a reply to message #84310] |
Anthony,
gr. Martin
Anthony wrote:
> Martin,
> Anthony
>> Anthony,
>> gr. Martin
>> Anthony wrote:
>>> Martin,
> member.
>>> Any idea?
>>> Anthony
>>>> Hi Anthony,
> noticed
> candidates.
>>>> gr. Martin
>>>> Anthony wrote:
>>>>> Martin,
>>>>> Anthony
>>>>>> Anthony,
> next
>>>>>> build.
>>>>>> gr. Martin
>>>>>> Anthony wrote:
>>>>>>> Martin,
>>>>>>> private
>>>>>>> Thanks.
>>>>>>> Anthony
>>>>>>>> Anthony,
>>>>>>>> gr. Martin
>>>>>>>> Anthony wrote:
>>>>>>>>> Martin,
>>>>>>>>> Thanks.
>>>>>>>>> Anthony
> for
>>>>>>>>>> this type.
> in
> only
> a
>>>>>>>>>> eclass =
>>>>>>>>>> y
>>>>>>>>>> getEPackages());
>>>>>>>>>> } else {
>>>>>>>>>> eclass =
>>>>> (pc.getMappedClas
>>>>>>>>>> s
> for
> example,
> through
>>>>>>>>>> if (eclass == null
>>>>>>>>>> log
>>>>>>>>>> ereferences
> separate
>>>>>>>>>> econta iner columns
>>>>>>>>>> are required.");
>>>>>>>>>> return;
>>>>>>>>>> Object>());
>>>>>>>>>> etName());
>>>>>>>>>> eccColumn));
>>>>>>>>>> ecColumn));
>>>>>>>>>> ecFID.setName
>>>>>>>>>> ecfColumn));
>>>>>>>>>>> YES.
>>>>>>>>>>>> Otherwise setting
> through
> try
>>>>>>>>>>> pagination,
>>>>>>>>>>> Right?
> is
>>>>>>>>>>> Anthony
>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>> container:true
>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>> required: true
>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>> container:false
>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>> required: false
>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>> Anthony
The Netherlands
Re: [Teneo] eContainer has not been saved? [message #606753 is a reply to message #84327] |
Martin,
Now I am using 0.8.
file) and it's OK .
Thanks.
Anthony
> Anthony,
> later.
> gr. Martin
> Anthony wrote:
>> Martin,
>> class)
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>> member.
>>>> Any idea?
>>>> Anthony
>>>>> Hi Anthony,
>> noticed
>> candidates.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> for the
>> next
>>>>>>> build.
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> private
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>>> gr. Martin
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Martin,
>>>>>>>>>> HbDataStore.
>>>>>>>>>> Thanks.
>>>>>>>>>> Anthony
>>>>>>>>>>> addcontainermapping
>> for
>>>>>>>>>>> this type.
>> in
>> only
>>>>>>>>>>> have
>> a
>>>>>>>>>>> eclass =
>>>>>>>>>>> y
>>>>>>>>>>> getEPackages());
>>>>>>>>>>> } else {
>>>>>>>>>>> eclass =
>>>>>> (pc.getMappedClas
>>>>>>>>>>> s
>> for
>> example,
>> through
>>>>>>>>>>> if (eclass == null
>>>>>>>>>>> log
>>>>>>>>>>> ereferences
>> separate
>>>>>>>>>>> econta iner columns
>>>>>>>>>>> are required.");
>>>>>>>>>>> return;
>>>>>>>>>>> pc.getClassName());
>>>>>>>>>>> Object>());
>>>>>>>>>>> etName());
>>>>>>>>>>> eccColumn));
>>>>>>>>>>> ecColumn));
>>>>>>>>>>> ecFID.setName
>>>>>>>>>>> ecfColumn));
>>>>>>>>>>>> YES.
>>>>>>>>>>>>> Otherwise setting
>> through
>>>>>>>>>>>>> correctly. Did you
>> try
>>>>>>>>>>>> pagination,
>>>>>>>>>>>> as one. Right?
>>>>>>>>>>>>> econtainer
>> is
>>>>>>>>>>>> Anthony
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>>> container:true
>>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>>> required: true
>>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>>> container:false
>>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>>> required: false
>>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Anthony
Re: [Teneo] eContainer has not been saved? [message #606754 is a reply to message #84327] |
Martin :
bug# is 187984 .
Anthony
> Anthony,
> later.
> gr. Martin
> Anthony wrote:
>> Martin,
>> class)
>> Anthony
>>> Anthony,
>>> gr. Martin
>>> Anthony wrote:
>>>> Martin,
>> member.
>>>> Any idea?
>>>> Anthony
>>>>> Hi Anthony,
>> noticed
>> candidates.
>>>>> gr. Martin
>>>>> Anthony wrote:
>>>>>> Martin,
>>>>>> Anthony
>>>>>>> Anthony,
>>>>>>> for the
>> next
>>>>>>> build.
>>>>>>> gr. Martin
>>>>>>> Anthony wrote:
>>>>>>>> Martin,
>>>>>>>> private
>>>>>>>> Thanks.
>>>>>>>> Anthony
>>>>>>>>> Anthony,
>>>>>>>>> gr. Martin
>>>>>>>>> Anthony wrote:
>>>>>>>>>> Martin,
>>>>>>>>>> HbDataStore.
>>>>>>>>>> Thanks.
>>>>>>>>>> Anthony
>>>>>>>>>>> addcontainermapping
>> for
>>>>>>>>>>> this type.
>> in
>> only
>>>>>>>>>>> have
>> a
>>>>>>>>>>> eclass =
>>>>>>>>>>> y
>>>>>>>>>>> getEPackages());
>>>>>>>>>>> } else {
>>>>>>>>>>> eclass =
>>>>>> (pc.getMappedClas
>>>>>>>>>>> s
>> for
>> example,
>> through
>>>>>>>>>>> if (eclass == null
>>>>>>>>>>> log
>>>>>>>>>>> ereferences
>> separate
>>>>>>>>>>> econta iner columns
>>>>>>>>>>> are required.");
>>>>>>>>>>> return;
>>>>>>>>>>> pc.getClassName());
>>>>>>>>>>> eContainer.setName
>>>>>>>>>>> Object>());
>>>>>>>>>>> etName());
>>>>>>>>>>> eccColumn));
>>>>>>>>>>> ecColumn));
>>>>>>>>>>> ecFID.setName
>>>>>>>>>>> ecfColumn));
>>>>>>>>>>>> YES.
>>>>>>>>>>>>> Otherwise setting
>> through
>>>>>>>>>>>>> correctly. Did you
>> try
>>>>>>>>>>>> pagination,
>>>>>>>>>>>> as one. Right?
>>>>>>>>>>>>> econtainer
>> is
>>>>>>>>>>>> Anthony
>>>>>>>>>>>>> gr. Martin
>>>>>>>>>>>>>> @build.eclipse.org:
>>>>>>>>>>>>>> Martin,
>>>>>>>>>>>>>> container:true
>>>>>>>>>>>>>> containment: false
>>>>>>>>>>>>>> required: true
>>>>>>>>>>>>>> lower bound: 1
>>>>>>>>>>>>>> upper bound: 1
>>>>>>>>>>>>>> Transient : false
>>>>>>>>>>>>>> Many : false
>>>>>>>>>>>>>> container:false
>>>>>>>>>>>>>> containment: true
>>>>>>>>>>>>>> required: false
>>>>>>>>>>>>>> lower bound: 0
>>>>>>>>>>>>>> upper bound: -1
>>>>>>>>>>>>>> Transient : true
>>>>>>>>>>>>>> Many : true
>>>>>>>>>>>>>> Regards,
>>>>>>>>>>>>>> Anthony
Current Time: Fri Jan 22 14:23:18 GMT 2021
Powered by FUDForum. Page generated in 0.04592 seconds
