| FWD: what can cause removeNotify to be called twice [message #81993] |
Wed, 04 June 2003 10:25 |
Forwarded Question:
I've noticed a bug where an editpart gets its removeNotify called twice. The
first time seems to be when its parent is removed, the second time seems to
be when it is removed from its parent. The second time its called result in
a stack like this...
org.eclipse.gef.editparts.AbstractEditPart.getRoot(AbstractE ditPart.java:575
org.eclipse.gef.editparts.AbstractEditPart.getViewer(Abstrac tEditPart.java:6
27)
org.eclipse.gef.editparts.AbstractEditPart.unregisterModel(A bstractEditPart.
java:1073)
org.eclipse.gef.editparts.AbstractEditPart.unregister(Abstra ctEditPart.java:
1055)
org.eclipse.gef.editparts.AbstractEditPart.removeNotify(Abst ractEditPart.jav
a:882)
I'm able to avoid this NPE by overiding removeNofify and calling
super.removeNofify () only when its called the 1st time. Are you aware of
such a bug?
RESPONSE:
When an editpart's parent is deleted, it and all of its children are
deactivated and should no longer be listening to the model. So, if for some
reason the editpart is also removed from the parent, the parent should not
receive notification, and should not refreshChildren(). Removing children
from a container that was deleted seems like it might not be necessary.
FUDForum. Page generated in 0.02754 seconds
