Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] ClassCastException retrieving model
Re: [Teneo] ClassCastException retrieving model [message #81237 is a reply to message #81223] |
Wed, 25 April 2007 20:30 |
Martin Taal Messages: 5468 Registered: July 2009 |
Alain,
I am a bit mistified myself also, when you set a breakpoint here: BookImpl.eSet(BookImpl.java:309),
what is the class of the object you get and what is the class instance to which the cast is tried?
Which version of Teneo are you using?
Can you post/send me the hbm mapping? (you can get it by doing dataStore.getMappingXML())
gr. Martin
Alain Picard wrote:
> Martin,
> I just made the changes and did a clean build, started with -clean, but
> to no avail.
> Any other idea?
> Alain
> Martin Taal wrote:
>> Hi Alain,
>> Can you try setting the buddy policy to dependent? Although it is less
>> precise (classloading can take more time) it is the safest to try.
>> gr. Martin
>> Alain Picard wrote:
>>> I am getting acquainted with Teneo and going through the library
>>> editor example (after successfully doing the Tutorial1 part). I have
>>> been able to start the wizard on an empty database and to create a
>>> library with a book and author.
>>> When I restart back from scratch, it attempts to load the content of
>>> the db and fails with the following:
>>> java.lang.ClassCastException:
>>> org.eclipse.example.library.BookCategory cannot be cast to
>>> at org.eclipse.example.library.impl.BookImpl.eSet(BookImpl.java :309)
>>> at
>>> org.eclipse.emf.teneo.hibernate.mapping.property.EAttributeP ropertyHandler.set(EAttributePropertyHandler.java:191)
>>> at
>>> org.hibernate.tuple.entity.AbstractEntityTuplizer.setPropert yValues(AbstractEntityTuplizer.java:337)
>>> at
>>> org.hibernate.persister.entity.AbstractEntityPersister.setPr opertyValues(AbstractEntityPersister.java:3564)
>>> at
>>> org.hibernate.engine.TwoPhaseLoad.initializeEntity(TwoPhaseL oad.java:129)
>>> at
>>> org.hibernate.loader.Loader.initializeEntitiesAndCollections (Loader.java:854)
>>> .....etc
>>> This gives me the idea that I might be dealing with a classloader
>>> problem, since my Hibernate jars are in a different bundle. I have
>>> it's buddy policy set to registered and all of the library projects
>>> have Eclipse-RegisterBuddy: Shared_JARs (the bundle containing
>>> Hibernate).
>>> Does anyone has seen this before and have any clue how to fix it?
>>> Thanks
>>> Alain
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] ClassCastException retrieving model [message #81282 is a reply to message #81237] |
Wed, 25 April 2007 22:19 |
Alain Picard Messages: 266 Registered: July 2009 |
Martin,
I get a org.eclipse.example.library.BookCategory and it is being cast to
BookCategory as the error mentioned:
java.lang.ClassCastException: org.eclipse.example.library.BookCategory
cannot be cast to org.eclipse.example.library.BookCategory
I am using the latest version of Teneo (0.8
emft-teneo-SDK-I200704230019) with EMF (emf-sdo-xsd-SDK-2.3.0M6) under
Eclipse 3.3M6
I am trying to get some trace info to get the class loader tree, but I
am still fighting that battle.
Thanks for your help.
Alain
Here is the mapping info:
<hibernate-mapping>
<class name="org.eclipse.example.library.impl.BookImpl"
entity-name="Book" abstract="false" lazy="false"
discriminator-value="Book" table="`book`">
<meta attribute="eclassName">Book</meta>
<meta
attribute="epackage">http:///org/eclipse/example/library.ecore</meta>
<id type="long" name="e_id" column="e_id"
access=" org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rPropertyHandler ">
<meta attribute="syntheticId">true</meta>
<generator class="native"/>
</id>
<discriminator column="`dtype`" type="string"/>
<version name="e_version" column="e_version"
access=" org.eclipse.emf.teneo.hibernate.mapping.property.VersionProp ertyHandler ">
<meta attribute="syntheticVersion">true</meta>
</version>
<property name="title" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="java.lang.String">
<column not-null="false" unique="false" name="`title`"/>
</property>
<property name="pages" lazy="false" insert="true" update="true"
not-null="false" unique="false" type="int">
<column not-null="false" unique="false" name="`pages`"/>
</property>
<property name="category" lazy="false" not-null="false" insert="true"
update="true" unique="false">
<column not-null="false" unique="false" name="`category`"/>
<type name="org.eclipse.emf.teneo.hibernate.mapping.ENumUserType" >
<param name="enumClass">org.eclipse.example.library.BookCategory</param >
</type>
</property>
<many-to-one name="author" entity-name="Writer"
cascade="merge,persist,save-update,lock,refresh" lazy="false"
insert="false" update="false" not-null="false">
<column not-null="false" unique="false" name="`book_author_e_id`"/>
</many-to-one>
</class>
<class name="org.eclipse.example.library.impl.LibraryImpl"
entity-name="Library" abstract="false" lazy="false"
discriminator-value="Library" table="`library`">
<meta attribute="eclassName">Library</meta>
<meta
</id>
</version>
<property name="name" lazy="false" insert="true" update="true"
<column not-null="false" unique="false" name="`name`"/>
</property>
<list name="writers" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`library_writers_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`library_writers_idx`"/>
<one-to-many entity-name="Writer"/>
</list>
<list name="books" lazy="true" cascade="all,delete-orphan">
<key update="true">
<column name="`library_books_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`library_books_idx`"/>
<one-to-many entity-name="Book"/>
</list>
</class>
<class name="org.eclipse.example.library.impl.WriterImpl"
entity-name="Writer" abstract="false" lazy="false"
discriminator-value="Writer" table="`writer`">
<meta attribute="eclassName">Writer</meta>
<meta
</id>
</version>
</property>
cascade="merge,persist,save-update,lock,refresh">
<key update="true">
<column name="`book_author_e_id`" not-null="false" unique="false"/>
</key>
<list-index column="`writer_books_idx`"/>
</list>
</class>
</hibernate-mapping>
Martin Taal wrote:
> Alain,
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> but to no avail.
>> Any other idea?
>> Alain
>> Martin Taal wrote:
>>> Hi Alain,
>>> less precise (classloading can take more time) it is the safest to try.
>>> gr. Martin
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> .....etc
>>>> Hibernate).
>>>> Thanks
>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #81298 is a reply to message #81282] |
Thu, 26 April 2007 04:48 |
Alain,
I am not sure why this does not work but I can give you some more background information for you to
look at. At your breakpoint in the BookImpl.eSet you can get the classloader from both the
BookCategory class used for the cast as well as the classloader (getClassLoader() method on the
class itself). The same can be done for the class of the passed object. In the debugger you can try
to walk through the classloader hierarchy to see if the two classloaders are related.
The (BookCategory) class of the passed object in the eSet is loaded in the EnumUserType class in the
setParameterValues method. This is done when you initialize the datastore. As a default teneo uses
the ContextClassLoaderStrategy (see org.eclipse.emf.teneo.classloader) which uses the following to
load the class:
Thread.currentThread().getContextClassLoader()
I do not know how/when the second classloader (which reads its own BookCategory) comes into play. To
analyse this it could help to put a static initializer block in the BookCategory class with a
breakpoint (or print the stack trace) and then see when this is executed (twice).
It seems that the initialization of the datastore uses a classloader which is not related to the
classloader which later reads the library model again for your plugins.
gr. Martin
Alain Picard wrote:
> Martin,
> Eclipse 3.3M6
> Alain
> <hibernate-mapping>
> <meta
> </id>
> </version>
> </property>
> </property>
> insert="true" update="true" unique="false">
> <type
> <param
> </type>
> </property>
> </many-to-one>
> </class>
> <meta
> </id>
> </version>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> <meta
> </id>
> </version>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> Martin Taal wrote:
>> Alain,
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> but to no avail.
>>> Any other idea?
>>> Alain
>>> Martin Taal wrote:
>>>> Hi Alain,
>>>> gr. Martin
>>>>> have been able to start the wizard on an empty database and to
>>>>> create a library with a book and author.
>>>>> of the db and fails with the following:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> .....etc
>>>>> Hibernate).
>>>>> Thanks
>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #81343 is a reply to message #81298] |
Thu, 26 April 2007 20:37 |
Martin,
Here is what I am getting (in order):
In static init of BookCategory.
CL:org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@90d0ea
In ENumUserType with enumClassName of:
then it goes to get the classForName:
Thread.getContextClassLoader() line: 1314 [local variables unavailable]
ContextClassLoaderStrategy.getClassLoader() line: 32
ClassLoaderResolver.getClassLoader() line: 59
ClassLoaderResolver.classForName(String) line: 51
ENumUserType.setParameterValues(Properties) line: 175
with Thread.getContextClassLoader() returning the following
contextClassLoader:
org.eclipse.core.runtime.internal.adaptor.ContextFinder@d82aff
with parent: sun.misc.Launcher$AppClassLoader@1a7bf11
with parent: sun.misc.Launcher$ExtClassLoader@1f12c4e
with parent: null
Then later in BookImpl eSet i get the following (where the CL matched
the one reported in the static constructor):
BookCaterogy CL:
parent: org.eclipse.osgi.baseadaptor.BaseAdaptor$ParentClassLoader@16917ee
parent: null
The message in the BookCategory static constructor is only called once
at the beginning of this trace.
Also when you mentioned:
> In the debugger you can try to walk through the
Is there any way to walk the complete classloader hierarchy starting
from the root. What I am getting doesn't even agree on a root.
Alain
Martin Taal wrote:
> Alain,
> background information for you to look at. At your breakpoint in the
> BookImpl.eSet you can get the classloader from both the BookCategory
> method on the class itself). The same can be done for the class of the
> passed object. In the debugger you can try to walk through the
> the EnumUserType class in the setParameterValues method. This is done
> when you initialize the datastore. As a default teneo uses the
> uses the following to load the class:
> BookCategory) comes into play. To analyse this it could help to put a
> static initializer block in the BookCategory class with a breakpoint (or
> which is not related to the classloader which later reads the library
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> to BookCategory as the error mentioned:
>> Eclipse 3.3M6
>> Alain
>> <hibernate-mapping>
>> <meta
>> </id>
>> </version>
>> update="true" not-null="false" unique="false" type="java.lang.String">
>> </property>
>> update="true" not-null="false" unique="false" type="int">
>> </property>
>> <type
>> <param
>> </type>
>> </property>
>> </many-to-one>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> Martin Taal wrote:
>>> Alain,
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> but to no avail.
>>>> Any other idea?
>>>> Alain
>>>> Martin Taal wrote:
>>>>> Hi Alain,
>>>>> try.
>>>>> gr. Martin
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> .....etc
>>>>>> projects have Eclipse-RegisterBuddy: Shared_JARs (the bundle
>>>>>> containing Hibernate).
>>>>>> Thanks
>>>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #81379 is a reply to message #81343] |
Fri, 27 April 2007 12:33 |
Hi Alain,
Hmm where do you initialise the datastore (in which plugin)?
Teneo can be set to use another classloader you can do this by calling the method:
ClassLoaderResolver.setClassLoaderStrategy(ClassLoaderStrate gy classLoaderStrategy)
with your own ClassLoaderStrategy before initializing the datastore.
The ClassLoaderStrategy is a simple interface which returns the classloader which you want to use.
As a default Teneo uses the ContextClassLoaderStrategy but there is also the
ClassClassLoaderStrategy which uses the classloader of the calling class.
gr. Martin
Alain Picard wrote:
> Martin,
> contextClassLoader:
> with parent: null
> BookCaterogy CL:
> parent: null
> Thanks
> Alain
> Martin Taal wrote:
>> Alain,
>> which uses the following to load the class:
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> under Eclipse 3.3M6
>>> I am still fighting that battle.
>>> Alain
>>> <hibernate-mapping>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> </many-to-one>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> <key update="true">
>>> </key>
>>> </list>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list>
>>> </class>
>>> Martin Taal wrote:
>>>> Alain,
>>>> gr. Martin
>>>> Alain Picard wrote:
>>>>> Martin,
>>>>> but to no avail.
>>>>> Any other idea?
>>>>> Alain
>>>>> Martin Taal wrote:
>>>>>> Hi Alain,
>>>>>> try.
>>>>>> gr. Martin
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> .....etc
>>>>>>> have it's buddy policy set to registered and all of the library
>>>>>>> Thanks
>>>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #81436 is a reply to message #81379] |
Sun, 29 April 2007 22:32 |
Martin,
Finally got it figured out.
I had to hack the java.lang.ClassLoader to implement a registry
( http://www.javaworld.com/javaworld/javaqa/2003-07/02-qa-0725 -classsrc2.html)
in order to understand what was happening. (Many other failed attempts
before)
Here is what I got:
[org.eclipse.example.library.BookCategory]:
loaded by
[org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader(org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@1201ad7)]
from
[file:/C:/eclipse/workspace/library/bin/org/eclipse/example/ library/BookCategory.class]
and then:
loaded by
[org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader(org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@1e7258e)]
from
[jar:file:/C:/eclipse/products/emft-teneo-ex-7423/eclipse/pl ugins/org.eclipse.emf.teneo.tutorial_0.8.0.v200704230019.jar !/org/eclipse/example/library/BookCategory.class]
Guess I had the example jar installed and getting in the way from my
original library project and that was also the reason i could only see 1
call to the static block in BookCategory.
Now I need to understand why I am getting a large number of empty "My
Library" under the single truly populated one.
Do you have any clue?
Alain
Martin Taal wrote:
> Hi Alain,
> the method:
> the ClassClassLoaderStrategy which uses the classloader of the calling
> class.
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> unavailable] ContextClassLoaderStrategy.getClassLoader() line: 32
>> contextClassLoader:
>> with parent: null
>> BookCaterogy CL:
>> parent:
>> parent: null
>> Thanks
>> Alain
>> Martin Taal wrote:
>>> Alain,
>>> the passed object. In the debugger you can try to walk through the
>>> in the EnumUserType class in the setParameterValues method. This is
>>> done when you initialize the datastore. As a default teneo uses the
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> cast to BookCategory as the error mentioned:
>>>> under Eclipse 3.3M6
>>>> Alain
>>>> <hibernate-mapping>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </property>
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> </many-to-one>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> <key update="true">
>>>> </key>
>>>> </list>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> </class>
>>>> Martin Taal wrote:
>>>>> Alain,
>>>>> gr. Martin
>>>>> Alain Picard wrote:
>>>>>> Martin,
>>>>>> -clean, but to no avail.
>>>>>> Any other idea?
>>>>>> Alain
>>>>>> Martin Taal wrote:
>>>>>>> Hi Alain,
>>>>>>> to try.
>>>>>>> gr. Martin
>>>>>>>> content of the db and fails with the following:
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> .....etc
>>>>>>>> classloader problem, since my Hibernate jars are in a different
>>>>>>>> bundle. I have it's buddy policy set to registered and all of
>>>>>>>> the library projects have Eclipse-RegisterBuddy: Shared_JARs
>>>>>>>> (the bundle containing Hibernate).
>>>>>>>> Thanks
>>>>>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #81450 is a reply to message #81436] |
Mon, 30 April 2007 07:39 |
Hi Alain,
Thanks for the link, interesting article. It is a pity that java does not make this easier in the
standard sdk.
I am not sure what you do so I can not really answer the question why you get many empty libraries.
Maybe it is related to code which automatically creates a root object (a library) to prevent the
database from being empty (just guessing here).
gr. Martin
Alain Picard wrote:
> Martin,
> before)
> Here is what I got:
> loaded by
> from
> and then:
> loaded by
> from
> Thanks
> Alain
> Martin Taal wrote:
>> Hi Alain,
>> the method:
>> also the ClassClassLoaderStrategy which uses the classloader of the
>> calling class.
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> ENumUserType.setParameterValues(Properties) line: 175 with
>>> contextClassLoader:
>>> with parent: null
>>> BookCaterogy CL:
>>> parent:
>>> parent: null
>>> once at the beginning of this trace.
>>> Thanks
>>> Alain
>>> Martin Taal wrote:
>>>> Alain,
>>>> executed (twice).
>>>> gr. Martin
>>>> Alain Picard wrote:
>>>>> Martin,
>>>>> under Eclipse 3.3M6
>>>>> but I am still fighting that battle.
>>>>> Alain
>>>>> <hibernate-mapping>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </property>
>>>>> name="`category`"/>
>>>>> <type
>>>>> <param
>>>>> </type>
>>>>> </property>
>>>>> </many-to-one>
>>>>> </class>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> <key update="true">
>>>>> </key>
>>>>> </list>
>>>>> <key update="true">
>>>>> </key>
>>>>> </list>
>>>>> </class>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> </list>
>>>>> </class>
>>>>> Martin Taal wrote:
>>>>>> Alain,
>>>>>> gr. Martin
>>>>>> Alain Picard wrote:
>>>>>>> Martin,
>>>>>>> Any other idea?
>>>>>>> Alain
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Alain,
>>>>>>>> is less precise (classloading can take more time) it is the
>>>>>>>> safest to try.
>>>>>>>> gr. Martin
>>>>>>>>> library editor example (after successfully doing the Tutorial1
>>>>>>>>> part). I have been able to start the wizard on an empty
>>>>>>>>> database and to create a library with a book and author.
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> .....etc
>>>>>>>>> Thanks
>>>>>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #81601 is a reply to message #81450] |
Mon, 30 April 2007 13:30 |
Martin,
I guess it was due to the error situation and I kept creating empty root
objects as I kept testing somehow. I cleaned them from the database and
all is well now.
I am now getting closer to doing some real world tests very soon. :)
Alain
Martin Taal wrote:
> Hi Alain,
> not make this easier in the standard sdk.
> you get many empty libraries. Maybe it is related to code which
> automatically creates a root object (a library) to prevent the database
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> before)
>> Here is what I got:
>> loaded by
>> from
>> and then:
>> loaded by
>> from
>> 1 call to the static block in BookCategory.
>> Thanks
>> Alain
>> Martin Taal wrote:
>>> Hi Alain,
>>> calling the method:
>>> calling class.
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> 32 ClassLoaderResolver.getClassLoader() line: 59
>>>> contextClassLoader:
>>>> with parent: null
>>>> matched the one reported in the static constructor):
>>>> BookCaterogy CL:
>>>> parent:
>>>> parent: null
>>>> Thanks
>>>> Alain
>>>> Martin Taal wrote:
>>>>> Alain,
>>>>> (getClassLoader() method on the class itself). The same can be done
>>>>> for the class of the passed object. In the debugger you can try to
>>>>> executed (twice).
>>>>> classloader which is not related to the classloader which later
>>>>> gr. Martin
>>>>> Alain Picard wrote:
>>>>>> Martin,
>>>>>> under Eclipse 3.3M6
>>>>>> Alain
>>>>>> <hibernate-mapping>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </property>
>>>>>> name="`category`"/>
>>>>>> <type
>>>>>> <param
>>>>>> </type>
>>>>>> </property>
>>>>>> </many-to-one>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> <key update="true">
>>>>>> </key>
>>>>>> </list>
>>>>>> <key update="true">
>>>>>> </key>
>>>>>> </list>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> <key update="true">
>>>>>> unique="false"/>
>>>>>> </key>
>>>>>> </list>
>>>>>> </class>
>>>>>> Martin Taal wrote:
>>>>>>> Alain,
>>>>>>> gr. Martin
>>>>>>> Alain Picard wrote:
>>>>>>>> Martin,
>>>>>>>> Any other idea?
>>>>>>>> Alain
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi Alain,
>>>>>>>>> safest to try.
>>>>>>>>> gr. Martin
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> .....etc
>>>>>>>>>> different bundle. I have it's buddy policy set to registered
>>>>>>>>>> and all of the library projects have Eclipse-RegisterBuddy:
>>>>>>>>>> Shared_JARs (the bundle containing Hibernate).
>>>>>>>>>> Thanks
>>>>>>>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #605066 is a reply to message #81223] |
Alain,
gr. Martin
Alain Picard wrote:
> Martin,
> to no avail.
> Any other idea?
> Alain
> Martin Taal wrote:
>> Hi Alain,
>> gr. Martin
>>> at
>>> at
>>> at
>>> at
>>> at
>>> .....etc
>>> Hibernate).
>>> Thanks
>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #605079 is a reply to message #81237] |
Martin,
Eclipse 3.3M6
Alain
<hibernate-mapping>
<meta
</id>
</version>
</property>
</property>
</type>
</property>
</many-to-one>
</class>
<meta
</id>
</version>
</property>
<key update="true">
</key>
</list>
<key update="true">
</key>
</list>
</class>
<meta
</id>
</version>
</property>
<key update="true">
</key>
</list>
</class>
Martin Taal wrote:
> Alain,
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> but to no avail.
>> Any other idea?
>> Alain
>> Martin Taal wrote:
>>> Hi Alain,
>>> gr. Martin
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> .....etc
>>>> Hibernate).
>>>> Thanks
>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #605084 is a reply to message #81282] |
Alain,
load the class:
gr. Martin
Alain Picard wrote:
> Martin,
> Eclipse 3.3M6
> Alain
> <hibernate-mapping>
> <meta
> </id>
> </version>
> </property>
> </property>
> <type
> <param
> </type>
> </property>
> </many-to-one>
> </class>
> <meta
> </id>
> </version>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> <meta
> </id>
> </version>
> </property>
> <key update="true">
> unique="false"/>
> </key>
> </list>
> </class>
> Martin Taal wrote:
>> Alain,
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> but to no avail.
>>> Any other idea?
>>> Alain
>>> Martin Taal wrote:
>>>> Hi Alain,
>>>> gr. Martin
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> .....etc
>>>>> Hibernate).
>>>>> Thanks
>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #605098 is a reply to message #81298] |
Martin,
contextClassLoader:
with parent: null
BookCaterogy CL:
parent: null
Alain
Martin Taal wrote:
> Alain,
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> Eclipse 3.3M6
>> Alain
>> <hibernate-mapping>
>> <meta
>> </id>
>> </version>
>> </property>
>> </property>
>> <type
>> <param
>> </type>
>> </property>
>> </many-to-one>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> <meta
>> </id>
>> </version>
>> </property>
>> <key update="true">
>> unique="false"/>
>> </key>
>> </list>
>> </class>
>> Martin Taal wrote:
>>> Alain,
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> but to no avail.
>>>> Any other idea?
>>>> Alain
>>>> Martin Taal wrote:
>>>>> Hi Alain,
>>>>> try.
>>>>> gr. Martin
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> .....etc
>>>>>> Thanks
>>>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #605109 is a reply to message #81343] |
Hi Alain,
gr. Martin
Alain Picard wrote:
> Martin,
> contextClassLoader:
> with parent: null
> BookCaterogy CL:
> parent: null
> Thanks
> Alain
> Martin Taal wrote:
>> Alain,
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> under Eclipse 3.3M6
>>> Alain
>>> <hibernate-mapping>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> </property>
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> </many-to-one>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> <key update="true">
>>> </key>
>>> </list>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list>
>>> </class>
>>> <meta
>>> </id>
>>> </version>
>>> </property>
>>> <key update="true">
>>> unique="false"/>
>>> </key>
>>> </list>
>>> </class>
>>> Martin Taal wrote:
>>>> Alain,
>>>> gr. Martin
>>>> Alain Picard wrote:
>>>>> Martin,
>>>>> but to no avail.
>>>>> Any other idea?
>>>>> Alain
>>>>> Martin Taal wrote:
>>>>>> Hi Alain,
>>>>>> try.
>>>>>> gr. Martin
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> at
>>>>>>> .....etc
>>>>>>> Thanks
>>>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #605123 is a reply to message #81379] |
Martin,
before)
Here is what I got:
loaded by
from
and then:
loaded by
from
Alain
Martin Taal wrote:
> Hi Alain,
> the method:
> class.
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> contextClassLoader:
>> with parent: null
>> BookCaterogy CL:
>> parent:
>> parent: null
>> Thanks
>> Alain
>> Martin Taal wrote:
>>> Alain,
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> under Eclipse 3.3M6
>>>> Alain
>>>> <hibernate-mapping>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> </property>
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> </many-to-one>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> <key update="true">
>>>> </key>
>>>> </list>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> </class>
>>>> <meta
>>>> </id>
>>>> </version>
>>>> </property>
>>>> <key update="true">
>>>> unique="false"/>
>>>> </key>
>>>> </list>
>>>> </class>
>>>> Martin Taal wrote:
>>>>> Alain,
>>>>> gr. Martin
>>>>> Alain Picard wrote:
>>>>>> Martin,
>>>>>> Any other idea?
>>>>>> Alain
>>>>>> Martin Taal wrote:
>>>>>>> Hi Alain,
>>>>>>> to try.
>>>>>>> gr. Martin
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> at
>>>>>>>> .....etc
>>>>>>>> Thanks
>>>>>>>> Alain
Re: [Teneo] ClassCastException retrieving model [message #605130 is a reply to message #81436] |
Hi Alain,
standard sdk.
gr. Martin
Alain Picard wrote:
> Martin,
> before)
> Here is what I got:
> loaded by
> from
> and then:
> loaded by
> from
> Thanks
> Alain
> Martin Taal wrote:
>> Hi Alain,
>> the method:
>> calling class.
>> gr. Martin
>> Alain Picard wrote:
>>> Martin,
>>> contextClassLoader:
>>> with parent: null
>>> BookCaterogy CL:
>>> parent:
>>> parent: null
>>> Thanks
>>> Alain
>>> Martin Taal wrote:
>>>> Alain,
>>>> executed (twice).
>>>> gr. Martin
>>>> Alain Picard wrote:
>>>>> Martin,
>>>>> under Eclipse 3.3M6
>>>>> Alain
>>>>> <hibernate-mapping>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> </property>
>>>>> name="`category`"/>
>>>>> <type
>>>>> <param
>>>>> </type>
>>>>> </property>
>>>>> </many-to-one>
>>>>> </class>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> <key update="true">
>>>>> </key>
>>>>> </list>
>>>>> <key update="true">
>>>>> </key>
>>>>> </list>
>>>>> </class>
>>>>> <meta
>>>>> </id>
>>>>> </version>
>>>>> </property>
>>>>> <key update="true">
>>>>> unique="false"/>
>>>>> </key>
>>>>> </list>
>>>>> </class>
>>>>> Martin Taal wrote:
>>>>>> Alain,
>>>>>> gr. Martin
>>>>>> Alain Picard wrote:
>>>>>>> Martin,
>>>>>>> Any other idea?
>>>>>>> Alain
>>>>>>> Martin Taal wrote:
>>>>>>>> Hi Alain,
>>>>>>>> safest to try.
>>>>>>>> gr. Martin
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> at
>>>>>>>>> .....etc
>>>>>>>>> Thanks
>>>>>>>>> Alain
The Netherlands
Re: [Teneo] ClassCastException retrieving model [message #605168 is a reply to message #81450] |
Martin,
all is well now.
Alain
Martin Taal wrote:
> Hi Alain,
> gr. Martin
> Alain Picard wrote:
>> Martin,
>> before)
>> Here is what I got:
>> loaded by
>> from
>> and then:
>> loaded by
>> from
>> Thanks
>> Alain
>> Martin Taal wrote:
>>> Hi Alain,
>>> calling the method:
>>> calling class.
>>> gr. Martin
>>> Alain Picard wrote:
>>>> Martin,
>>>> contextClassLoader:
>>>> with parent: null
>>>> BookCaterogy CL:
>>>> parent:
>>>> parent: null
>>>> Thanks
>>>> Alain
>>>> Martin Taal wrote:
>>>>> Alain,
>>>>> executed (twice).
>>>>> gr. Martin
>>>>> Alain Picard wrote:
>>>>>> Martin,
>>>>>> under Eclipse 3.3M6
>>>>>> Alain
>>>>>> <hibernate-mapping>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> </property>
>>>>>> name="`category`"/>
>>>>>> <type
>>>>>> <param
>>>>>> </type>
>>>>>> </property>
>>>>>> </many-to-one>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> <key update="true">
>>>>>> </key>
>>>>>> </list>
>>>>>> <key update="true">
>>>>>> </key>
>>>>>> </list>
>>>>>> </class>
>>>>>> <meta
>>>>>> </id>
>>>>>> </version>
>>>>>> </property>
>>>>>> <key update="true">
>>>>>> unique="false"/>
>>>>>> </key>
>>>>>> </list>
>>>>>> </class>
>>>>>> Martin Taal wrote:
>>>>>>> Alain,
>>>>>>> gr. Martin
>>>>>>> Alain Picard wrote:
>>>>>>>> Martin,
>>>>>>>> Any other idea?
>>>>>>>> Alain
>>>>>>>> Martin Taal wrote:
>>>>>>>>> Hi Alain,
>>>>>>>>> safest to try.
>>>>>>>>> gr. Martin
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> at
>>>>>>>>>> .....etc
>>>>>>>>>> Thanks
>>>>>>>>>> Alain
Current Time: Thu Apr 25 01:29:19 GMT 2024
Powered by FUDForum. Page generated in 0.05069 seconds
