Home » Eclipse Projects » GEF » [Draw2D] Setting Label size
[Draw2D] Setting Label size [message #81181] Tue, 27 May 2003 13:50 Go to next message
Originally posted by: a_shishkov.yahoo.com
I have been using the following code to set the size of a Label such that it
is the minimum size needed for the label to fit all its text. It worked
fine with a draw2d.jar from a few months ago, but I have recently updated to
the latest jar and the code throws an exception.
Figure panel = new Figure();
Label label = new Label("Hello Label");
panel.add(label);
label.setOpaque(true);
label.setBackgroundColor(ColorConstants.white);
label.setLocation(new Point(x, y));
label.setSize(label.getPreferredSize());
If I don't call setSize on the label it would come up a lot larger than the
text. With the new draw2d.jar I get the following exception on the setSize
line:
at org.eclipse.draw2d.FigureUtilities.setFont(FigureUtilities.j ava:252)
org.eclipse.draw2d.FigureUtilities.getTextDimension(FigureUt ilities.java:78)
org.eclipse.draw2d.FigureUtilities.getTextExtents(FigureUtil ities.java:131)
at org.eclipse.draw2d.Label.calculateTextSize(Label.java:215)
at org.eclipse.draw2d.Label.getTextSize(Label.java:406)
at org.eclipse.draw2d.Label.getPreferredSize(Label.java:284)
at org.eclipse.draw2d.Figure.getPreferredSize(Figure.java:620)
I am not using a layout manager because I need complete control over the
size and position of some other figures in the same panel. Why can't I get
the preferred size of the label using the latest draw2d.jar? Is there any
other way I can set the size of my label to fit all the text, but no more?
Thank you for any help.
Angel
Re: [Draw2D] Setting Label size [message #81197 is a reply to message #81181] Tue, 27 May 2003 16:48 Go to previous message
You shouldn't be setting the size of a Figure. The parent's layout manager
should do that when it lays out.
You are getting this error because the Label does no know what font to use
when measuring its text. If you add the label to its parent, it will then
be able to obtain its parent's font, and the error will not occur. This
didn't show up earlier because of a bug in FigureUtilities where it would
use some random font whenever NULL was passed in.
"Angel Shishkov" <a_shishkov@yahoo.com> wrote in message
news:bb08ej$cbd$1@rogue.oti.com...
> Hello,
it
to
> panel.add(label);
the
> line:
> java.lang.NullPointerException
> at
> at
> Angel
Previous Topic:ComboBoxPropertyDescriptor
Next Topic:PaletteCreationTool and PaletteTemplateEntry
Current Time: Sun Nov 09 18:35:59 EST 2025
Powered by FUDForum. Page generated in 0.04476 seconds
