Home » Eclipse Projects » GEF » Layouts with (occasionally) hidden parts
Layouts with (occasionally) hidden parts [message #78152] Tue, 06 May 2003 20:17 Go to next message
------=_NextPart_000_004A_01C313F3.59DD1E70
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_004B_01C313F3.59DD1E70"
------=_NextPart_001_004B_01C313F3.59DD1E70
Content-Type: text/plain;
charset="iso-8859-1"
I have a need to show/hide certain graphical elements as the user =
clicks, and I would prefer to change their visibility instead of adding =
and removing elements. However, the ToolbarLayout (and, it appears, the =
other "gridded" layouts) don't seem to take visibility into account when =
computing a layout.
If I create 4 elements in a row, all works fine. If I hide one of them, =
there's a "hole":
Figure contents =3D new Figure();
ToolbarLayout layout =3D new ToolbarLayout(ToolbarLayout.HORIZONTAL);
layout.setStretchMinorAxis(true);
layout.setSpacing(3);
contents.setLayoutManager(layout);
Label a =3D new Label("a");
Label b =3D new Label("b");
Label c =3D new Label("c");
Label d =3D new Label("d");
contents.add(a);
contents.add(b);
contents.add(c);
contents.add(d);
This does what you want:=20
But, hide one of the elements and you get a hole:
contents.add(c); c.setVisible(false);=20
Is this a bug?
....Richard
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1170" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>I have a need to show/hide certain =
graphical=20
elements as the user clicks, and I would prefer to change their =
visibility=20
instead of adding and removing elements. However, the ToolbarLayout =
(and, it=20
appears, the other "gridded" layouts) don't seem to take visibility into =
account=20
when computing a layout.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>If I create 4 elements in a row, all =
works fine. If=20
I hide one of them, there's a "hole":</FONT></DIV>
<DIV>
<P><FONT face=3DArial size=3D2>Figure contents =3D new =
Figure();<BR>ToolbarLayout=20
layout =3D new=20
ToolbarLayout(ToolbarLayout.HORIZONTAL);<BR>layout.setStretchMinorAxis(tr=
ue);<BR>layout.setSpacing(3);<BR>contents.setLayoutManager(layout); <BR>La=
bel=20
a =3D new Label("a");<BR>Label b =3D new Label("b");<BR>Label c =3D new=20
Label("c");<BR>Label d =3D new=20
Label("d");<BR>contents.add(a);<BR>contents.add(b);<BR >contents.add(c);<B=
R>contents.add(d);</FONT></P>
<P><FONT face=3DArial size=3D2>This does what you want: </FONT><IMG =
alt=3D"" hspace=3D0=20
src=3D"cid:004401c3142e$06345550$0200a8c0@zen" align=3Dbaseline =
border=3D0></P>
<P><FONT face=3DArial size=3D2>But, hide one of the elements and you get =
a=20
hole:</FONT></P>
<P><FONT face=3DArial size=3D2>contents.add(c); c.setVisible(false); =
<IMG alt=3D""=20
hspace=3D0 src=3D"cid:004501c3142e$063a6fd0$0200a8c0@zen" =
align=3Dbaseline=20
border=3D0></FONT><FONT face=3DArial size=3D2><BR></FONT><FONT =
face=3DArial=20
size=3D2></FONT></P>
<P><FONT face=3DArial size=3D2>Is this a bug?</FONT></P>
<P><FONT face=3DArial size=3D2>...Richard</FONT></P>
<P><FONT face=3DArial size=3D2>&nbsp;</P></FONT></DIV></BODY></HTML>
------=_NextPart_001_004B_01C313F3.59DD1E70--
Content-Type: image/gif;
name="abcd.gif"
Content-ID: <004401c3142e$06345550$0200a8c0@zen>
R0lGODlhMgAWALMAAAAAAMzMzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAA
AAAAACwAAAAAMgAWAAAETDDISau9OOvNu/9gKI5kaZ5oqn6A2aYvGZ+zWHNA buX63lO8m6cWI2KK
oWAFCTxOhBnmc9q8SDvXQBaaxfGWX99NuSqbz+i0es0+RwAAOw==
name="abd.gif"
Content-ID: <004501c3142e$063a6fd0$0200a8c0@zen>
AAAAACwAAAAAMgAWAAAERTDISau9OOvNu/9gKI5kaZ5oqn6A2aYvGZ+zWHNA buU6y8uV2A0jDPFq
xU7Ss5Q0Nc/NM0qcDKE/yhG0XXm/4LB4TC6DIwA7
------=_NextPart_000_004A_01C313F3.59DD1E70--
Re: Layouts with (occasionally) hidden parts [message #78169 is a reply to message #78152] Tue, 06 May 2003 22:06 Go to previous messageGo to next message
I think this is standard behavior. Even SWT's GridLayout does this.
Try the following...
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.*;
public class LayoutVisibilityTest {
Shell shell = new Shell();
GridLayout layout = new GridLayout();
layout.numColumns = 3;
shell.setLayout(layout);
Button b1 = new Button(shell, SWT.PUSH);
b1.setText("First");
Button b2 = new Button(shell, SWT.PUSH);
b2.setText("Second");
b2.setVisible(false);
Button b3 = new Button(shell, SWT.PUSH);
b3.setText("Third");
shell.pack();
shell.open();
Display display = Display.getDefault();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
You'll notice the second button is not visible, but there is a space
there for it. Are you using GEF or just Draw2d? If you're using GEF,
you can filter your model based on their visibility. Consider this...
You have a container object in your model. (I'll call it Container
because I'm very unoriginal.)
You have child objects A, B, C, D -- just like you described. These
child models have methods isVisible() and setVisible(boolean).
Your container's edit part is ContainerEditPart (more unoriginality).
In ContainerEditPart.getModelChildren(), you return a list of only those
children that are visible.
Now, when the user clicks to make an element visible/invisible, you just
set that element's model to reflect the appropriate visibility and fire
a model change. The ContainerEditPart would listen to the model and
call refreshChildren() when that type of property change occurs.
Now, if you're using Draw2d, I just typed up this scenario for no
reason. ;) Either way, I hope this helps.
Eric
> computing a layout.
> there's a "hole":
> Figure contents = new Figure();
> ToolbarLayout layout = new ToolbarLayout(ToolbarLayout.HORIZONTAL);
> Label a = new Label("a");
> Label b = new Label("b");
> Label c = new Label("c");
> Label d = new Label("d");
> contents.add(a);
> contents.add(b);
> contents.add(c);
> contents.add(d);
> Is this a bug?
> ...Richard
Re: Layouts with (occasionally) hidden parts [message #78184 is a reply to message #78152] Tue, 06 May 2003 23:15 Go to previous messageGo to next message
------=_NextPart_000_00B8_01C31425.56CF0860
boundary="----=_NextPart_001_00B9_01C31425.56CF0860"
------=_NextPart_001_00B9_01C31425.56CF0860
The behavior is undefined. If you want the behavior changed, please =
open a bugzilla, preferably with a patch to the layoutmanager you need =
changed :-)
"Richard Clark" <rdclark@nextquestion.net> wrote in message =
news:b99j9b$3rp$1@rogue.oti.com...
computing a layout.
If I create 4 elements in a row, all works fine. If I hide one of =
contents.add(a);
contents.add(b);
contents.add(c);
contents.add(d);
Is this a bug?
...Richard
<HTML><HEAD>
<META content=3D"MSHTML 6.00.2723.2500" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>The behavior is undefined.&nbsp; If you =
want the=20
behavior changed, please open a bugzilla, preferably with a patch to the =
layoutmanager you need changed :-)</FONT></DIV>
<DIV>"Richard Clark" &lt;<A=20
href=3D"mailto:rdclark@nextquestion.net">rdclark@nextquestion.net</A>&gt;=
wrote in=20
message <A=20
href=3D"news:b99j9b$3rp$1@rogue.oti.com">news:b99j9b$3rp$1@rogue.oti.com<=
/A>...</DIV>
<BLOCKQUOTE dir=3Dltr=20
graphical=20
visibility=20
(and, it=20
appears, the other "gridded" layouts) don't seem to take visibility =
into=20
account when computing a layout.</FONT></DIV>
works fine.=20
If I hide one of them, there's a "hole":</FONT></DIV>
<DIV>
layout =3D new=20
bel=20
a =3D new Label("a");<BR>Label b =3D new Label("b");<BR>Label c =3D =
new=20
alt=3D""=20
hspace=3D0 src=3D"cid:00b201c31446$ddab4080$6401a8c0@porrada" =
align=3Dbaseline=20
border=3D0></P>
<P><FONT face=3DArial size=3D2>But, hide one of the elements and you =
get a=20
hole:</FONT></P>
<IMG alt=3D""=20
hspace=3D0 src=3D"cid:00b301c31446$ddacc720$6401a8c0@porrada" =
align=3Dbaseline=20
face=3DArial=20
<P><FONT face=3DArial =
size=3D2>&nbsp;</P></FONT></DIV></BLOCKQUOTE></BODY ></HTML>
------=_NextPart_001_00B9_01C31425.56CF0860--
name="abcd.gif"
Content-ID: <00b201c31446$ddab4080$6401a8c0@porrada>
name="abd.gif"
Content-ID: <00b301c31446$ddacc720$6401a8c0@porrada>
------=_NextPart_000_00B8_01C31425.56CF0860--
Re: Layouts with (occasionally) hidden parts [message #78198 is a reply to message #78169] Tue, 06 May 2003 23:44 Go to previous messageGo to next message
I'm using GEF, so I could use a ContainerEditPart.
I'm actually editing a form for a command with multiple parameters (some
optional), and want to show the entry fields for all the parameters when the
part is selected and hide the unused optional parameters when it's
deselected. Since there are a great many of these, and I was feeling
concerned about the sheer number of EditParts floating around in memory, I
was thinking of having one EditPart for the whole command (with its
parameters) and doing the pieces in draw2d. But I'll give the
ContainerEditPart approach a shot and look at the time/memory performance.
Re: The hole in a GridLayout -- it's a 2d layout so I could rationalize this
as "hiding the part in a row shouldn't remove a grid cell, as other parallel
rows could be affected" (and the same for columns). It's harder to say what
a 1-dimensional layout such as ToolbarLayout should do, but it feels
intuitively right that an invisible cell (and the spacer immediately to its
left) should take up no space. The same principle applies to a menu --
deleting a menu command pulls the following commands up to fill the space.
I'll do as Randy suggested and file a bugzilla entry with a patch so the
powers that be can see what seems right. :)
Thanks for the answer, I'll run with the pure-GEF approach and see how it
turns out.
....Richard
Re: Layouts with (occasionally) hidden parts [message #78227 is a reply to message #78198] Wed, 07 May 2003 00:59 Go to previous messageGo to next message
The approach I described will remove and deactivate the unneeded edit
parts in refreshChildren().
> turns out.
> ...Richard
Re: Layouts with (occasionally) hidden parts [message #78338 is a reply to message #78198] Wed, 07 May 2003 11:40 Go to previous message
news:b99vdr$9g3$1@rogue.oti.com...
the
You are not the first to display a "node" with multiple "attributes". I'm
curious to know when GEF users decide to use an EditPart to display these
sub-attributes, versus just having a single EditPart that has multiple
figures in it, each displaying one of the sub-properties. I guess it boils
down to the extent to which the user can edit an "attribute". Can they
delete it? Can they drag it to another node? Is keyboard access a high
priority so you want to be able to move up/down among attributes?
If you don't use editparts, you can still use the mouse to direct edit the
individual properties, and you could still use F2 to invoke cell editing on
the first parameter, with maybe TAB key or DOWN_ARROW to switch to others?
this
parallel
what
its
> turns out.
> ...Richard
Previous Topic:Bug in AbstractConnectionCreationTool reactivation?
Next Topic:draw2d.text
Current Time: Sat Nov 08 04:04:44 EST 2025
Powered by FUDForum. Page generated in 0.05250 seconds
