Home » Archived » XML Schema Definition (XSD) » Generate XML File option missing
Generate XML File option missing [message #76904] Fri, 30 January 2009 23:28 Go to next message
Originally posted by: nospam.pookmail.com
I downloaded and installed the JEE edition of Ganymede Eclipse on 1/29.
After editing an XSD file I right-clicked on the file, expecting to see
the "Generate" menu option so I could select "XML File" from the
sub-menu to create a file from the schema. The option is not there.
What do I need to add to get this back? It was there in prior versions.
Any help is appreciated.
T
Re: Generate XML File option missing [message #76921 is a reply to message #76904] Sat, 31 January 2009 08:08 Go to previous messageGo to next message
Todd,
Please don't cross post the same question as separate postings to
multiple groups. If you must cross post, use a single posting. In this
case, WTP is the right place to ask because they provide that
functionality so I can't really help explain why it would go missing...
> see the "Generate" menu option so I could select "XML File" from the
> T
Re: Generate XML File option missing [message #76935 is a reply to message #76921] Sat, 31 January 2009 13:40 Go to previous message
I apologize for the cross-post but really did not know which group to
post to. There are so many groups and there no descriptions on what
should go where.
So far no response at WTP...
Thanks.
Ed Merks wrote:
> Todd,
>> Thanks,
>> T
Re: Generate XML File option missing [message #603614 is a reply to message #76904] Sat, 31 January 2009 08:08 Go to previous message
Todd,
> T
Re: Generate XML File option missing [message #603619 is a reply to message #76921] Sat, 31 January 2009 13:40 Go to previous message
should go where.
Thanks.
Ed Merks wrote:
> Todd,
>> Thanks,
>> T
Previous Topic:Generate XML File option missing
Next Topic:Foregrownd color issue at "=" sign
Current Time: Tue Jul 22 15:38:28 EDT 2025
Powered by FUDForum. Page generated in 0.03680 seconds
