Home » Modeling » TMF (Xtext) » How to generate code using Xtext and Xtend?
How to generate code using Xtext and Xtend? [message #717572] |
Sun, 21 August 2011 12:52 |
Harshani Nawarathna Messages: 9 Registered: August 2011 |
Junior Member |
This a grammar I wrote using Xtext to implement a DSL.
grammar org.processing.pde.Pde with org.eclipse.xtext.common.Terminals
generate pde "http://www.processing.org/pde/Pde"
Pde:
Active | Static;
Active:
method_1=Setup
method_2=Draw
Static:
elements+=AbstractElement*
AbstractElement:
Size | Background | Shape | Fill | ShapeMode | Smooth | Stroke | FrameRate | ColorMode
terminal LPAREN:
terminal RPAREN:
terminal MOUSE_X:
"mouseX"
terminal MOUSE_Y:
"mouseY"
terminal P_MOUSE_X:
"pmouseX"
terminal P_MOUSE_Y:
"pmouseY"
terminal NO_VALUE:
terminal MODE:
"CENTER" | "CORNER"
terminal OPERATOR:
terminal PI_VALUE:
"PI" |"0" | "HALF_PI" | "QUATER_PI" | "TWO_PI"
terminal ROUND_VALUE:
"ROUND"
terminal SQUARE_VALUE:
"SQUARE"
terminal BEVEL_VALUE:
"BEVEL"
terminal CLOSE_VALUE:
"CLOSE"
Corner:
ROUND_VALUE | BEVEL_VALUE
Ending:
ROUND_VALUE | SQUARE_VALUE
PiValuesWithOperations:
PI_VALUE | PI_VALUE OPERATOR PI_VALUE
RadianValue:
"radian" LPAREN degree_value=INT RPAREN
GrayValue:
INT
Position_X:
MOUSE_X| INT | OPERATOR INT | MOUSE_X OPERATOR INT | INT OPERATOR INT | INT OPERATOR MOUSE_X | P_MOUSE_X | P_MOUSE_X OPERATOR MOUSE_X | MOUSE_X OPERATOR P_MOUSE_X | INT OPERATOR P_MOUSE_X | P_MOUSE_X OPERATOR INT
Position_Y:
MOUSE_Y | INT | OPERATOR INT | MOUSE_Y OPERATOR INT | INT OPERATOR INT | INT OPERATOR MOUSE_Y | P_MOUSE_Y | P_MOUSE_Y OPERATOR MOUSE_Y | MOUSE_Y OPERATOR P_MOUSE_Y | INT OPERATOR P_MOUSE_Y | P_MOUSE_Y OPERATOR INT
ColorModeMaxValue:
INT
RedValue:
INT
GreenValue:
INT
BlueValue:
INT
AlphaValue:
INT
HueValue:
INT
SaturationValue:
INT
BrightnessValue:
INT
EndShapeValue:
CLOSE_VALUE | NO_VALUE
Size:
"size" LPAREN height=INT "," width=INT RPAREN ";"
Background:
"background" LPAREN gray_value=GrayValue RPAREN";"
Fill:
{Fill}
"fill" LPAREN gray_value=GrayValue RPAREN ";"
ShapeMode:
"ellipseMode" LPAREN mode_value= MODE RPAREN ";" |
"rectMode" LPAREN mode_value=MODE RPAREN ";" |
"beginShape" LPAREN no_begin_shape_value=NO_VALUE RPAREN ";" |
"endShape" LPAREN no_end_shape_value=EndShapeValue RPAREN ";"
Smooth:
"smooth" LPAREN smooth_value=NO_VALUE RPAREN ";" |
"noSmooth" LPAREN no_smooth_value=NO_VALUE RPAREN ";"
Stroke:
"stroke" LPAREN stroke_value=INT RPAREN";" |
"noStroke" LPAREN no_stroke_value=NO_VALUE RPAREN";" |
"strokeWeight" LPAREN stroke_weight_value=INT RPAREN ";" |
"strokeJoin" LPAREN stroke_corner=Corner RPAREN";" |
"strokeCap" LPAREN stroke_ending=Ending RPAREN";"
Shape:
Rectangle | Ellipse | Point | Line | Triangle | Quad | Arc | Vertex
Point:
"point"LPAREN position_x= Position_X"," position_y=Position_Y RPAREN ";"
Vertex:
"vertex" LPAREN position_x=Position_X "," position_y=Position_Y RPAREN ";"
Line:
"line" LPAREN position_1_x=Position_X "," position_1_y=Position_Y "," position_2_x=Position_X "," position_2_y=Position_Y RPAREN ";"
Rectangle:
"rect" LPAREN top_left_x=Position_X "," top_left_y=Position_Y "," bottom_right_x=Position_X"," bottom_right_y=Position_Y RPAREN ";"
Ellipse:
"ellipse" LPAREN center_x=Position_X "," center_y=Position_Y "," width=INT "," height=INT RPAREN ";"
Triangle:
"traingle" LPAREN position_1_x=Position_X "," position_1_y=Position_Y "," position_2_x=Position_X "," position_2_y=Position_Y "," position_3_x=Position_X "," position_3_y=Position_Y RPAREN ";"
Quad:
"quad" LPAREN position_1_x=Position_X "," position_1_y=Position_Y "," position_2_x=Position_X "," position_2_y=Position_Y "," position_3_x=Position_X "," position_3_y=Position_Y "," position_4_x=Position_X "," position_4_y=Position_Y RPAREN ";"
Arc:
"arc" LPAREN position_x=Position_X "," position_y=Position_Y "," width=INT "," height=INT "," start= PiValuesWithOperations "," stop= PiValuesWithOperations RPAREN";" |
"arc" LPAREN position_x=Position_X "," position_y=Position_Y "," width=INT "," height=INT "," start_r= RadianValue "," stop_r=RadianValue RPAREN";"
FrameRate:
"frameRate"LPAREN frame_rate_value=INT RPAREN";"
ColorMode:
RGBColorMode | HSBColorMode
RGBColorMode:
"colorMode" LPAREN color_mode="RGB" "," color_mode_max_value=ColorModeMaxValue RPAREN";"
|"colorMode" LPAREN color_mode="RGB" "," red_value=RedValue "," green_value=GreenValue "," blue_value=BlueValue ("," alpha_value=AlphaValue)? RPAREN";"
HSBColorMode:
"colorMode" LPAREN color_mode="HSB" "," hue_value=HueValue "," saturation_value=SaturationValue "," brightness_value=BrightnessValue RPAREN";"
Setup:
"void" space=NO_VALUE "setup" LPAREN RPAREN "{"
Draw:
"void" space=NO_VALUE "draw" LPAREN RPAREN "{"
shapes+=Shape*
It can help me to suggest code as in the "test.pde" file mentioned below when I run "org.processing.pde" (my project) in a new eclipse runtime.This is the syntax of programming language "Processing" and I'm currently working on building code suggestion for the language using Xtext.
void setup(){
size(200,200);
void draw(){
ellipse(50,50,80,80);
Now I want to generate a "src-gen/test.java" file according to my "test.pde" file as mentioned below and it will act as the pre-compiler code.
import processing.core.*;
public class Test extends PApplet {
public void setup(){
size(200,200);
public void draw(){
static public void main(String args[]) {
PApplet.main(new String[] { "--bgcolor=#ECE9D8", "a" });
As I found Xtend can generate that code for me. I went through the Xtext team's video's at vimeo, Xtext reference document. I couldn't find any other tutorials for Xtend to proceed with. I'm still clueless how to start coding the Xtend file.
Can someone please help me to start.
Thanks in advance.
[Updated on: Sun, 21 August 2011 12:54] Report message to a moderator
Re: How to generate code using Xtext and Xtend? [message #717592 is a reply to message #717588] |
Sun, 21 August 2011 15:00 |
since this is your metamodel you should of cource know it much better than me.
it is your decision on how to process the model / what to do.
never the less here a partial solutuin that fits your needs
class MyDslGenerator implements IGenerator {
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
fsa.generateFile("Test.java", '''
«FOR active : resource.allContentsIterable.filter(typeof(Active))»
«FOR e : active.method_1.elements»
«e.compile»
«ENDFOR»
public void draw(){
«FOR e : active.method_2.shapes»
«e.compile»
«ENDFOR»
«ENDFOR»
def dispatch compile(AbstractElement e) {
//TODO
def dispatch compile(Size e) {
size(«e.width»,«e.height»);
def dispatch compile(Ellipse e) {
ellipse(«e.center_x»,«e.center_y»,«e.width»,«e.height»);
~Christian
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Current Time: Tue Apr 23 16:14:29 GMT 2024
Powered by FUDForum. Page generated in 0.03757 seconds
