Home » Modeling » TMF (Xtext) » Unable to incorporate default IValueConverters(extends DefaultTerminalConverters enough?)
Unable to incorporate default IValueConverters [message #716844] Thu, 18 August 2011 15:03 Go to next message
Joey Mink is currently offline Joey MinkFriend
Member
Hi!
Having a blast playing with XText, but I've hit a brick wall I can't seem to surmount. I created a custom IValueConverter, and have it working (please see SOURCE below). However, the default IValueConverters do not seem to be working. For instance, I get parse errors in my generated editor for the ID rule - the only way to bypass the parse error is no prepend ID instances with '^' (please see Example below). Does anyone see my mistake?
Example
For this rule:
Define:
	DefineKeyword
	name = ID
	value = (ID | STRING)
the following syntax results in an error:
Define MY_VAR "value"
yet this syntax parses successfully:
Define ^MY_VAR "value"
SOURCE
Bound my custom IValueConverterService implementation:
public class TplXRuntimeModule extends com.exoanalytic.seas.tplx.AbstractTplXRuntimeModule {
	public Class<? extends IValueConverterService> bindIValueConverterService() {
		return TplXValueConverterService.class;
Extended DefaultTerminalConverters:
public class TplXValueConverterService extends DefaultTerminalConverters
	@ValueConverter(rule = "DEFINE_REFERENCE")
	public IValueConverter<String> defineReferenceValueConverter() {
		return new AbstractNullSafeConverter<String>() {
			protected String internalToValue(String string, INode node)
				throws ValueConverterException {
				return string.startsWith("$") ? string.substring(1) : string;
			protected String internalToString(String value) {
				if (GrammarUtil.getAllKeywords(getGrammar()).contains(value)) {
					return "$"+value;
				return value;
Re: Unable to incorporate default IValueConverters [message #716903 is a reply to message #716844] Thu, 18 August 2011 18:14 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
can you share a complete reproducable grammar?
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Blog : https://www.dietrich-it.de
Re: Unable to incorporate default IValueConverters [message #716911 is a reply to message #716903] Thu, 18 August 2011 18:54 Go to previous messageGo to next message
Member
Christian - thanks for the reply. Please see the attached file.
  • Attachment: TplX.xtext
    (Size: 1.85KB, Downloaded 102 times)
Re: Unable to incorporate default IValueConverters [message #716921 is a reply to message #716911] Thu, 18 August 2011 19:07 Go to previous messageGo to next message
the problem is that DEFINE_REFERENCE hides ID
why not using a Datatype Rule instead of a terminal?
~Christian
Re: Unable to incorporate default IValueConverters [message #716940 is a reply to message #716921] Thu, 18 August 2011 20:56 Go to previous message
Member
Wow, thanks for the detective work. I changed the DEFINE_REFERENCE terminal rule to this Data Type Rule and no other changes were req'd - it simply worked!
DEFINE_REFERENCE returns ecore::EString:
	'$' ID
Woohoo! Oh yeah, I also had to add this to the top of the grammar:
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
Previous Topic:Prevent DirectoryCleaner to clean up 'xtend-gen' directory
Next Topic:problem with deploying plugin developed by xtext
Current Time: Tue Apr 20 02:26:02 GMT 2021
Powered by FUDForum. Page generated in 0.02260 seconds
