Re: export question [message #707552 is a reply to message #707468] |
Mon, 01 August 2011 19:56 |
We do version control the .settings directory for the following reasons:
- We keep as much configuration as possible on the project level. A
workspace-level configuration of things like compiler settings,
formatter or auto save actions is not possible in our case as most of
our engineers work on different projects having different needs.
- We use Maven and some projects prefer m2eclipse and some the maven-
eclipse-plugin. Whether the .classpath files are checked in is
therefore a permanent discussion...
- In a large project we use the maven-eclipse-plugin not only to
configure the .classpath but also to add/ensure some config files
like jdt prefs. In that case we have a Hudson job doing the
eclipse:eclipse and a check-in regularly so that our team just
consumes the results.
Back to your questions: I think there is no final answer. It depends on
how your team wants to work and which other (build) tools you use.
Take care,
Michael
FUDForum. Page generated in 0.05051 seconds
