unable to load class using sample.http.registry [message #72929] |
Sat, 09 September 2006 23:54 |
Originally posted by: bendevlists.gmail.com
I have been trying to get the sample.http.registry to function. I am using
Tomcat 5.5.17. The output of the ss on the console gives me the following:
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.100.200607211737
Fragments=8
1 ACTIVE org.eclipse.equinox.common_3.2.0.200607211737
2 ACTIVE org.eclipse.update.configurator_3.2.0.200607211737
3 ACTIVE
org.eclipse.equinox.servlet.bridge.http_3.2.0.200607211737
4 ACTIVE org.eclipse.equinox.http.registry_3.2.0.200607211737
7 ACTIVE org.eclipse.equinox.registry_3.2.100.200607211737
8 RESOLVED
org.eclipse.equinox.servlet.bridge.extensionbundle_3.2.0
Master=0
10 RESOLVED org.eclipse.osgi.services_3.1.100.200607211737
19 RESOLVED sample.http_1.0.0
20 ACTIVE sample.http.registry_1.0.0
When going to /ext/helloworld I receive the following error:
description The server encountered an internal error () that prevented it
from fulfilling this request.
exception
javax.servlet.ServletException: Plug-in sample.http.registry was unable to
load class sample.http.registry.HelloWorldServlet.
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.initializeDelegate(ServletManager.java:166)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:135)
org.eclipse.equinox.servlet.bridge.http.internal.ServletRegi stration.handleRequest(ServletRegistration.java:78)
org.eclipse.equinox.servlet.bridge.http.internal.ProxyServle t.processAlias(ProxyServlet.java:107)
org.eclipse.equinox.servlet.bridge.http.internal.ProxyServle t.service(ProxyServlet.java:57)
javax.servlet.http.HttpServlet.service(HttpServlet.java:802)
org.eclipse.equinox.servlet.bridge.launcher.BridgeServlet.se rvice(BridgeServlet.java:95)
root cause
org.eclipse.core.runtime.CoreException: Plug-in sample.http.registry was
unable to load class sample.http.registry.HelloWorldServlet.
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:178)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:787)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.initializeDelegate(ServletManager.java:156)
I have put the directory sample.http.registry within the
WEB-INF/platform/plugins/
Any help will be appreciated, or a guide on setting up the
sample.http.registry example.
I am also looking for any tutorials or references for using Equinox within
a servlet enviroment and working with current servlets I have.
Re: unable to load class using sample.http.registry [message #72981 is a reply to message #72929] |
Mon, 11 September 2006 02:34 |
Originally posted by: skaegi.sympatico.ca
Hi Ben,
It looks like you've configuration is fine.
I'm going to guess that it might be something wrong with the
sample.http.registry bundle itself.
I wonder if you created the bundle by repackaging the folder?
The zip contains the actual project and the paths are wrong if used as a
bundle. (e.g. the classes are in /bin)
You should still be able to access helloworld.html as coincidentally its in
the right place.
I've enclosed an exported bundle based on the project that I've just
verified works. (...it's just 2KB)
-Simon
"Ben" <bendevlists@gmail.com> wrote in message
news:80b31d1fd5b453b099113d41aa5d955e$1@www.eclipse.org...
> id State Bundle
> Fragments=8
> 3 ACTIVE
> 8 RESOLVED
> Master=0
> exception
ervlet.java:57)
let.java:95)
> root cause
leExtension(ConfigurationElementHandle.java:51)
ervlet.java:57)
let.java:95)
Re: unable to load class using sample.http.registry [message #73144 is a reply to message #72929] |
Fri, 15 September 2006 08:27 |
Originally posted by: ridcully560.yahoo.com
I've been trying to use that sample, too. But when I load it to my
eclipse, or try to rebuild the structure for my own projects, eclipse
always tells me, that the extension-points
"org.eclipse.equinox.http.registry.servlets" and
"org.eclipse.equinox.http.registry.recources" are unknown.
Any idea what might be wrong (Eclipse 3.2 and the plugins from
eclipse-equinox-3.2.zip are installed).
Johannes
Re: unable to load class using sample.http.registry [message #73162 is a reply to message #73144] |
Fri, 15 September 2006 09:22 |
got it working - my fault: I simply forgot the incubator-bundles
(another new install of eclipse).
Johannes
Johannes schrieb:
> Hello,
> Johannes
FUDForum. Page generated in 0.03069 seconds
